Canon R5C and Weebill S
Started 9 months ago | Questions
Kees Timmer Regular Member • Posts: 106
I am using my R5 with the RF24-105mm on a Weebill S for video work. This combination can be nicely balanced. Is this also possible with the R5C? Are there any forum members having experience with this combination?
Canon EOS R5 Canon EOS R5 C
Mprelude91 New Member • Posts: 1
Re: Canon R5C and Weebill S
I can check next weekend for you when I’m back home if you’re still looking for an answer! I’ve got my r5c and my 24-105 f4L with me on the road but the Weebill is at home
Tom_ant1 New Member • Posts: 1
Hi Kees,
I am just wanted to chech if you found out about the Canon R5C and being able to use it on the Weebill S? I would appreciate any info on this.
Ephemeris
Ephemeris Senior Member • Posts: 1,186
Id appreciate any feedback on using this with the normal R5.
OP Kees Timmer Regular Member • Posts: 106
Tom_ant1 wrote:
Hi Kees,
Hi Tom,
No info so far about the R5C on the Weebill S. I still hope some users on this forum will share their experience. However, I am very satisfied with my R5 as B-cam for my C200. So R5C has low priority.
I only have experience with the R5 and the RF24-105mm f/4 on the Weebill S. As indicated earlier this is a nice combination: balancing is easy and gimbal movements are smooth. I didn't try other lenses with the R5 on the Weebill S.
Ephemeris
Thanks most appreciated. Likely we would use the same lens so very helpful.
