Where is the successor to the original EOS R?
Started 9 months ago | Questions
Trent Severn Regular Member • Posts: 141
So many new mirror-less camera body releases since the original EOS R, but I haven't heard much when (or if) a direct successor is coming.
I don't want/need a pro body, and I don't want a crop sensor. Does Canon expect us to upgrade to the R5/R6?
For the most part, I'm mostly fine with the R, but it's auto-focus system is definitely looking quite dated.
I'm basically looking for the same R body + updated focusing system (that every other newer R-body camera seems to have), and a faster sensor readout fo a more useable silent/electronic shutter (without the banding/stretching artifacts). Everything else can pretty much stay the same.
 Trent Severn's gear list:Trent Severn's gear list
Canon EOS 500D Canon EOS 6D Canon EOS R Canon EF 50mm F1.8 II Canon EF 100mm f/2.0 USM +8 more
MikeJ9116 Veteran Member • Posts: 6,955
Re: Where is the successor to the original EOS R?
Now that APS-C has come to the R system I think there is a good chance the R will be replaced with a body the is also a replacement for the RP. I think its price will land between $1,500-$2,000. My guess is that it will have an updated version of its current 30mp sensor in a similar manner like the R7 and R10 have updated versions of the 32mp and 24mp sensors. Also, it will have the Digic X processor and the same AF as the R7/R10 which is the same as the R3 among other improvements.
OP Trent Severn Regular Member • Posts: 141
With Canon's mirrorless lineup more or less fleshed out, I feel the R has a fairly narrow range to fit into without cannibalizing sales from other models. Both the pricing and feature-set has to fit between the R7 and R6.
Craig Smith Contributing Member • Posts: 500
Canon is starting to run out of ranking numbers.
R3, R5, R6, R7, R10
Does the R become the R8?
Does the RP becomes the R9?
 Craig Smith's gear list:Craig Smith's gear list
Canon EOS R6 Canon RF 24-105mm F4L IS USM Canon EOS RP Canon EOS R7 Canon 70-300 F4-5.6 IS II +3 more
BirdShooter7 Veteran Member • Posts: 9,127
My guess is that you might be waiting for a while.  It sounds like Canon has many cameras in the works and I haven’t heard a hint of an R replacement.
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
R3, R5, R6, R7, R10
That seems as good a guess as any.
yerach
yerach Regular Member • Posts: 353
12
i'm dreadfully sorry to grief you, but yes, the "successor" to the r was the r5, take it or leave it, the r was a camera that didn't hold a place in canon's lineup (thus wasn't numbered), it was a testbed for creating a proper mirrorless system, skipping nikon-like flops, they merely took 5d iv tech and reorganized it in the most daring way they possibly could allow themselves to, shipped out the thing, and waited to see what happens, what they learned from this "experiment" brought about the r5/r6, which were, are, and i suppose will be for quite a while, some of the most well rounded, well planned out bodies around, once they were released, the r5 filled the 5d series position (as the number implies), thus replacing the r, which is essentially a mirrorless 5d iv, and the r6 replaced the 6d series respectively, though far higher-end, as that is the nature of mirrorless and the current market.
that is not to say the r isn't a good camera, it is, as is the 5d iv, and especially for the bargain price they can be found at now.
i am suspecting the r1 "flagship" thing might just knock the whole range's pricing a notch down, as a 7k$+ body will need to be something out of this world to compete with the 6k$ a1 and the 5.5k$ z9, but i wouldn't count on it.
your request list sounds a bit like a r5 mk ii at sub 2k$, that's not happening any time soon if that's your concern...
i personally am hoping for something to be a "ff rp successor", and i think that's a little more likely to happen.
canon at hand nikon at heart
 yerach's gear list:yerach's gear list
Canon EOS R5 Canon RF 28-70mm F2L USM Canon RF 70-200mm F2.8L IS USM
TimP111 Regular Member • Posts: 168
would have thought the R and RP just become obsolete and we have R1,R3,R5,R6,R7,R10 for the foreseeable future
iShootWideOpen
iShootWideOpen Regular Member • Posts: 428
Just get an R6. I came from a 5D4 (same sensor as the R) and have used my buddies Eos-R on a few occasions before getting into the R system. In terms of resolution I can't really tell a difference. What I can tell though is better dynamic range, much better high ISO, and quantum leaps advancement in AF.
 iShootWideOpen's gear list:iShootWideOpen's gear list
Canon EOS R5 Canon EOS R6 Canon EF 50mm f/1.2L USM Canon EF 85mm F1.2L II USM Canon EF 135mm F2L USM +10 more
Lost99999 Regular Member • Posts: 336
I think they indeed need ( perhaps in 1- 2 years ) a successor.
In Europe the R6 is 2300 euro for the body, the R is 1600 and RP is 1000 euro. So having a full frame range starting with a 2300 euro body will not lure in many people moving into full frame ( and being motivated to buy RF lenses ).
In my view the RP was always more a 6dii replacement.
with the wide range of less expensive FF RF lenses, i would expect also FF R bodies in the 1000 and 1500 price bracket.
Canon could even ‘reuse’ the exact R7 and R10 bodies and fit FF sensors. Drop a bit the FPS rate and you have a RP and R mark ii !
keep also in mind the typical life span of 1D, 5D, 6D and 7D is 4-6 years !
 Lost99999's gear list:Lost99999's gear list
Canon EOS RP Canon EF 200mm f/2.8L II USM Canon RF 24-105mm F4L IS USM Canon RF 50mm F1.8 STM Canon RF 16mm F2.8 STM
Peter Kwok
Peter Kwok Senior Member • Posts: 2,635
There will never be a successor to the original EOS R
If you want a FF, 30+ Mpix, no IBIS, x0D build level, priced lower than R6, then forget about it.
The original R was meant to be a demo to showcase Canon's new RF mount and especially the insanely fast 28-70 F2, 50 & 85 F1.2 lens.  Its purpose is to stop users from switching to Sony. With a recycled sensor from the 5Dmk4, it got to the market fast enough.  It bought Canon time to develop the R5 & R6 with IBIS & a new DigicX processor chip for fast readout.  It did its job.  There is no need for Canon to do this again.
After releasing the crop body R7 & R10, there may be a RP replacement as the bottom FF.  So, you can get the more expensive but less MPixel R6, or wait for an RP replacement which may or may not come.
Peter Kwok
Click here for my PBase gallery
WYSIWYG - If you don't like what you get, try to see differently.
 Peter Kwok's gear list:Peter Kwok's gear list
Canon EOS 5DS Canon EOS R5 Canon EF 16-35mm F4L IS USM Canon RF 14-35mm F4L IS USM Canon EOS M6 +8 more
tkbslc Forum Pro • Posts: 17,522
Maybe the RP2?
Honestly, there wasn't a whole lot of real difference between R and RP.  So if the RP replacement hits with a modern sensor and IBIS, that's probably as good an EOS R replacement for most people like me.  I don't shoot action and I think I've used burst shutter mode like 5 times in 10 years.    Have no interest in tracking the eyes on flying squirrels at 100 meters or taking 30fps bursts of rhythm gymnasts.  Just want a solid travel, portrait, architecture, studio, macro camera.
Gam3r01 Contributing Member • Posts: 572
I believe the R did its job well, entering canon into the RF mount and a full scale commitment to mirrorless, but that does not mean it deserves or needs a replacement.
Canons lineup is getting filled out, there simply itsnt room or a need for the R replacement these days.
Youve got your high end FF R3/R5, the more economical FF R6, and the two new APSC models. The only thing missing is an entry level FF model, which will likely replace *both* the R and RP at the same time.
Canon does not need 5 tiers of FF bodies. Sticking with their high end R3/R5 (R1?), enthusiast FF R6, and an entry level FF body (TBD) is plenty.
The R was a venture into mirrorless, a sidegraded 5DIV, its replacement was the R5.
 Gam3r01's gear list:Gam3r01's gear list
Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 16mm F2.8 STM
Leigh A. Wax Senior Member • Posts: 1,621
IMO it will be the R6 Mark-2
Canon used a 20Mp sensor in the R6 because that was only current tech sensor on hand at the time, to fill the gap.
I believe an R6-2 will eventually be placed as a less expensive sibling to the R5 like the 6D was to the 5D series-----Maybe a 36MP???
The introduction of the R10, & R7 indicate that Canon is working to bring the R/RF lineup to "mirror" (no pun intended) their former, highly successful DSLR lineup.
I won't be shocked if this happens. As time passes it seems Canon is following much of the same strategy in the R system as they did in the EF system. This would mean no FF cameras priced under the top APS-C model. I can see their bottom R FF camera just being a smidge above the R7. Also, it looks like the R7 is the only APS-C camera to get an Rx designation. The all other APS-C cameras will be Rxx or Rxxx.
lumenite Senior Member • Posts: 1,208
R3, R5, R6, R7, R10
In my opinion, it would be better if R7 were called as R9. R7 is in a little lower position than 7D, but a little upper position than x0D. If it had been the case, the successors to R and RP could have found their sits between R6 and R9.
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
Kokopelli_Rocks
Kokopelli_Rocks Veteran Member • Posts: 3,661
I think the R was a production prototype for the R series
I agree. I see the are as a prototype test camera for the R system. I do not see Canon coming out with a direct replacement. I think the next two cameras from Canon will be an RP replacement that will probably be called the R8 or R9, and the much anticipated R1. I don't believe Canon plans a high res R5, I would guess it would have it's own number like an R4.
Pretty sure the original R will fade into history once the parts supply of 5D IV sensors is exhausted.
 Kokopelli_Rocks's gear list:Kokopelli_Rocks's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Sigma 14mm F1.8 Art Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM +15 more
Jack Calypso Senior Member • Posts: 1,094
I think there is still room for something slotted between the R6 and R5. Would that be an R 5½ ?
Kokopelli_Rocks
No doubt there will be a R6 MKII, MKIII, R5 MKII, MKIII eventually and ....
eventually a R3 MKII..., a R7 MK... R1.... I don't see any of these II series for at least two years. I also think we will see a RP replaced with an R# designation. We will also probably see an R4 eventually. I strongly doubt we will ever see a R replacement.
KEG
KEG Veteran Member • Posts: 4,909
The line up will be
R1
R3
R5s
R5c
R5 mk II
R5 mk I
R6 mk II
R6 mk I
R7
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
