Shooting Roses - color issues - Canon 90D
Started 10 months ago | Discussions
Crotonmark Contributing Member • Posts: 933
I have a canon 90D and shoot RAW and JPG. This spring I’ve been shooting roses on a rose bush. I’ve shot at all times during the day and under all lighting conditions
Here is my problem and my question.
my images are coming out of the camera incorrectly reflecting the rose’s color.
they are too red compared to the actual color. Also two roses next to each other are different colors
Is there a menu setting that affects this? It’s not white balance as that is correct.
any suggestions welcome
thanks
mark
Digirame Forum Pro • Posts: 41,858
Re: Shooting Roses - color issues - Canon 90D
Mark, you might want to post this on the other forum, where you'll find more users of the Canon 90D. I've been happy with the colors I get from my Canon T7i (800D) camera. But I've been only taking them as out-of-the-camera JPEGs. Here's an example of a really bright red rose. The white balance was set to cloudy during a rainstorm.
What do your red roses look like?  Do the out-of-the-camera JPEGs look much different than the RAW images that you post process?
I see that about 20 minutes ago, you posted this on the correct forum for the Canon 90D. You might want to post them some samples. From there maybe you can describe for them all, what is seen in the mage compared to what you remember them actually looking like.
OP Crotonmark Contributing Member • Posts: 933
Thanks. I put this here by accident but you are always so helpful.
the jpeg and the RAW color is not much different but neither matches reality
I thought there might be a color setting I’m missing.
Yea thanks. I fat fingered the forum I chose on my iPad.
I didn’t think posting would help
they would just tell me they’re not sharp enough (and for once that’s not my concern).
mocha123 Senior Member • Posts: 2,497
Hi Crotonmark,
It can be fairly expensive to colour calibrate both your camera and your Monitor which you view your pictures on but it's the only way to get close to seeing on screen what you're seeing in real life situations.
 mocha123's gear list:mocha123's gear list
Canon EOS 70D Canon EOS 7D Mark II Canon EF 100mm f/2.0 USM Tamron SP 70-300mm F4-5.6 Di VC USD Sigma 17-50mm F2.8 EX DC OS HSM +3 more
