Hi, my v3 list from October 2020 needed an update. Here we go.
Just because I've done it for myself, I share with you the list of all NATIVE EF-M lenses I found:
8 Canon lenses (with AF):
All Canon lenses are relatively budget-friendly, and well build for this range. Outside the 22mm and the 32mm, all are stabilized. They are meant to be light and compact (all are under 300g.). As a direct consequence the zooms are on the slow side.
- 11-22mm f/4-5.6 IS STM compact for 18-35mm équiv. (a bit shorter compared to the 18-55), stabilized, great optical quality. 220g.
- 15-45MM F/3.5-6.3 IS STM smaller than the 18-55, but full plastic build. 130g.
- 18-55mm f/3.5-5.6 IS STM original kit lens for the M, full metal finish. 210g
- 55-200mm f/4.5-6.3 IS STM Optically, a good step above the 18-55 kit. Sharper and more homogenous 260g
- 18-150mm f/4.5-6.3 IS STM kit superzoom, versatile and compact for this focal length. 300g
- 22mm pancake f/2.0 STM tack sharp and very light. Weak points: visible vignette wide open (easily corrected, especially with the 24mp sensor) and no IS. 105g.
- 28mm f/3.5 Macro IS STM. First EF-M macro lens. 1:1 ratio and x1.2 with "super macro" mode. two led imbedded for additional lighting when you nearly touch your subject. Compact, 130g.
- 32mm f/1.4 STM the brightest EF-M from Canon. The sharpest too. No IS. 235g. (My favorite!)
3 Sigma lenses (with AF):
Three affordable f/1.4 primes with AF, designed for mirrorless APSC. All of them are a welcome addition to the EF-M system. All three are relatively affordable for this type of lenses and got good reputation across the mounts they are available on (Sony E, MFT, Leica TL).
- 16mm f/1.4 DC DN, no IS, 405g A bit bigger and on the heavy side compared to the original canon EF-M "rules".
- 30mm f/1.4 DC DN, no IS, 265g
- 56mm f/1.4 DC DN, no IS, 281g
1 Tamron lens (with AF):
- Tamron 18-200mm f/3.5-6.3 Di III VC tested by Dustin Abott : the biggest size to keep a balanced camera (with M1), optically good for the category, useful all-in-one. 460g.
3 Viltrox lenses (with AF):
Designed for mirrorless APSC.
- 23mm f/1.4 STM, +/-260g
- 33mm f/1.4 STM, 270g
- 56mm f/1.4 STM, 290g
16 Samyang/Rokinon lenses (Manual focus only):
full manual: focus ring, aperture ring, no electronic contacts = no exifs. Usually, good optical quality/cost ratio.
Designed for APSC mirrorless:
- 8mm f/2.8 UMC II fisheye very compact 260g.
- 12mm f/2 NCS CS UGA fast and compact, test reports very good optical quality for the cost. Personal test: same sharpness as Canon 11-22mm. 260g.
- 21mm f/1.4 ED AS UMC CS, compact 275g.
- 35mm f/1.2 ED AS UMC CS, 420g.
- 50mm f/1.2 AS UMC CS, 375g.
- 85mm F1.8 ED UMC CS, 344g.
- 300mm f/6.3 ED UMC CS mirror design, very compact for a 300mm, 318g.
EF-M mount but designed for APSC reflex:
- 10mm f/2.8 ED AS NCS CS, 580g
- 16mm f/2 ED AS UMC CS, 583g
EF-M mount but designed for FF reflex:
- 12mm f/2.8, 400g.
- 14mm f/2.8 Mk2, 649g
- 20mm f/1.8 ED AS UMC, 497g
- 50mm f/1.4, 700g.
- 85mm f/1.4 Mk2, 548g
- 100mm f/2.8 macro, 700g.
- 135mm f/2 ED UMC, 210mm f/2 pour less than 600$...but no AF. 830g.
2 Kipon/Handevision Ibelux lens (Manual focus only):
Manual lens designed for APSC mirrorless.
- 40mm f/0.85 big, heavy, expensive, but a unique look on the pictures.
- 40mm f/0.85 mark II (the mark III has been released but for EOS R only it seems).
3 ZY Optics/Mitakon lenses (Manual focus only):
- 35mm f/0.95 Speedmaster Mark II, 460g.
- 20mm f/2 Creator, macro x4-x4,5 230g.
- 85mm f/2.8 Creator, macro x1-x5 750g.
4 LAOWA lenses (Manual focus only):
- 4mm f/2.8 fisheye, 135g, the widest EF-M lens.
- 9mm f/2.8 Zero-D, 215g, AFAIK, the widest EF-M orthogonal lens.
- 33mm f/0.95 CF APO Argus,
- 65mm f/2.8 2x Ultra Macro APO, the most powerful native macro lens for EF-M, 335g
17 7artisans lenses (Manual focus only):
Manual "retro" lenses designed for APSC mirrorless. Compact and fast primes.
- 7.5mm f/2.8, fisheye, 275g
- 7.5mm f/2.8 mark II, fisheye, 265g
- 12mm f/2.8, 295g
- 18mm f/6.3, 49g (bodycap style, fixed aperture and focus)
- 25mm f/0.95, 582g.
- 25mm f/1.8, 143g
- 35mm f/1.2, 150g
- 35mm f/1.2, Mark II 150g
- 35mm f/1.4, 228g
- 35mm f/2, 320g
- 35mm f/0.95, 650g
- 50mm f/0.95, 420g.
- 50mm f/1.8, 220g
- 55mm f/1.4, 272g
- 55mm f/1.4 Mark II, 358g
- 60mm f/2.8 Macro x1-x3, 550g
- 60mm f/2.8 Macro II x1 339g.
4 Sainsonic/Kamlan lenses (Manual focus only):
Manual lens designed for APSC mirrorless. Affordable.
- 8mm f/3.0 fisheye, 245g.
- 28mm f/1.4 384g.
- 50mm f/1.1 250g.
- 50mm f/1.1 MkII 600g.
13 MEIKE lenses (Manual focus only):
Found on Amazon, most for less than 100$
- 6-11mm f/3.5, fisheye zoom, 541g.
- 6.5mm f/2, circular fisheye, 300g.
- 7.5mm f/2.8 fisheye, 260g
- 8mm f/3.5, Fisheye, 590g.
- 12mm f/2.8, 360g.
- 25mm f/0.95, more expensive (650$), heavier 540g.
- 25mm f/1.8, 190g.
- 25mm f/2.8, 220g.
- 28mm f/2.8, pancake, 106g.
- 35mm f/1.4, 220g.
- 35mm f/1.7, 180g.
- 50mm f/1.7, 309g.
- 50mm f/2.0, 190g.
7 TTartisan lenses (Manual focus only):
- 7.5mm f/2, 370g. fisheye
- 17mm f/1.4, 248g.
- 23mm f/1.4, 222g.
- 35mm f/1.4, 180g.
- 40mm f/2.8 macro
- 50mm f/1.2, 336g.
- 50mm f/0.95 411g.
1 Rock Star lens (Manual focus only):
Found on Amazon for less than 100$
- 10mm f/8 fisheye, 80g. (bodycap style)
1 LENSBABY lens (Manual focus only):
- 28mm f/3.5 Trio pancake lens with 3 selectable optical effects
1 Brightin Star lens (Manual focus only):
- 12mm f/2.0 (Samyang 12 f/2.0 alternative)
1 Tokina lens (Manual focus only):
- 400mm f/8 N II S, 545g. Light and affordable mirror lens.
That's it... 85 native lenses. 15 with autofocus.
Do not forget the EF/EF-S lenses that can be useful and compact enough to work well with the M bodies, with full AF capabilities:
- EF-S 24mm f/2.8 STM Pancake, 230g w/ canon adapter
- EF 28mm f/2.8 IS USM, 365g w/ canon adapter
- EF-S 35mm f/2.8 Macro IS STM, 295g w/ canon adapter
- EF 35mm F/2.0, 445g w/ canon adapter
- EF 40mm f/2.8 STM pancake, 235g w/ canon adapter
- EF 50mm f/1.8 STM, 265g w/ canon adapter
- EF 50mm f/2.5 macro, 385g w/ canon adapter
- EF-S 60mm f/2.8 Macro USM, 440g w/ canon adapter
- EF 85mm f/1.8 USM 530g w/ canon adapter
- EF 100mm f/2.0 USM 565g w/ canon adapter
There's also a Viltrox Speed Booster EF-EOS M2.
This adapter let you use your EF lenses while retaining near original field of view (x1.13 crop only) and adding 1 stop of light.
For those interested in variable neutral density filters with EF lenses, there is the Meike MK-EFTM-C, an EF to EF-M adapter with an integrated drop-in variable neutral density (VND) filter.
I didn't list the equivalent ciné lenses (rokinon, meike, …) but there are few anamorphic lenses :
3 Sirui ciné lenses :
- 24 mm F2.8 1.33x
- 35 mm F1.8 1.33x
- 75 mm F1.8 1.33x
