SH-1 for documentation
Henry Falkner
Henry Falkner Forum Pro • Posts: 15,899
Recently I decided to revive an amateur radio transmitter-receiver, which was no longer turning on. A quick Google search showed up a major reason: After two decades, the CPU backup battery might be dead.
This started me on a hunt for a suitable battery, and a way to fit it. I am in the habit of taking photos of how it was before the repair attempt, then the part I need to replace:
The SH-1 can be set for close-ups. The built-in lens is suited for the close-up feature in the SCENE modes. My E-M10 Mark II and Mark IV also have that scene mode, but the lenses I have don't support it.
Back to my problem - nobody knows how the manufacturer Yaesu attached the solder tags to the battery. My super market New World still stocks that battery after 20 years, but soldering copper tags on a new battery blows it up.
Jaycar has a battery holder that matches the solder islands in my FT847 transceiver -
But it needs a thicker battery with a different type number -
Documentation as shown above saves me time when going back to some gear I have not used for years.
The SH-1 can take 16 MP shots, which allows to read part numbers on whole circuit boards, and it can do close-ups without changing lenses.
In addition it does our radio club guest speakers without irritating them, or the audience, with the mechanical shutter I use by default on my E-M10s -
The E-M10s do have a silent shutter, but they distract with their bigger size.
The grab shots above and below are from our radio club newsletter I edit, 'The 29-ER'.
If you have an Olympus SH-50 and SH-1 (I have), or SH-2 (I stuffed mine), or SH-3 (Japan only), don't ditch it!
Those pocket zooms might do a better job for technical documentation than your smart phone, at least in some instances.
Henry
Henry Falkner - E-M10 Mark II and Mark IV, SH-1, SH-50
http://www.pbase.com/hfalkner
 Henry Falkner's gear list:Henry Falkner's gear list
Olympus SP-570 UZ Olympus SH-50 Olympus Stylus SH-1 Olympus OM-D E-M10 II Olympus OM-D E-M10 IV +1 more
Olympus OM-D E-M10 Olympus SH-50 Olympus Stylus SH-1 Olympus Stylus SH-2 Olympus Stylus SH-3
Smaug01
MOD Smaug01 Veteran Member • Posts: 6,966
Thanks for sharing
FYI - The original battery tabs were spot-welded on; possibly by Yaesu.
Did your battery replacement solve the problem? I thought those batteries were only used to keep the clock running and retain the memories while the radio is un-powered...
Those lithium metal batteries have a 10-12 year shelf life, so the thicker CR2032 will likely not get you anything beyond what a CR2016 would have with half its capacity.
That CR20xx family is a very popular one for coin lithium metal cells. I have rifle scopes with lit reticles that use them, keyless entry car remotes, and even the Casio watches with advertised 10 year battery life use the thinner ones.
-Jeremy (KC9ZHE) "Zippy Hot Electrons"
"Rudeness is the weak man's imitation of strength."
-Eric Hofer
 Smaug01's gear list:Smaug01's gear list
Panasonic Lumix DMC-TS30 Ricoh GR III Olympus OM-D E-M10 III Nikon Z5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +25 more
Ken Croft Senior Member • Posts: 1,803
Re: SH-1 for documentation
The tags are not soldered they are spot welded. I am a model aircraft flyer using electric motors for power and we weld tags on our LiOn cells when ever we build a new flight pack. You can find a suitable battery powered spot welder expressly designed for welding onto cells at HobbyKing or AliExpress. You can see videos on how to use them on youTube.
Ken C
The Stylus1 [&1s] also has a useful mode called Super Macro. I use it quite often for recording details when I strip down electronics. Here is just such a picture.
Taken with Stylus1s in super macro mode. [Radio control transmitter mother board].
Ken C
Henry Falkner
OP Henry Falkner Forum Pro • Posts: 15,899
Re: Thanks for sharing
I forgot the user reply that says you have to do a full reset to avoid the 'dead-CPU' syndrome. Found the reply again where I saved it, but other stuff happened since then that was more urgent, like completing our tax return.
You are correct. The original CPU battery lasted 20 years at least, so I am not complaining.
Probably not, but my point is, there is a battery holder available for it that fits the Yaesu.
And they are still available 20 years later.
Sorry or the lateness of the reply. As I said - other stuff happened. Still, if I can get that FT-847 going again, I will have VHF, UHF and HF in the same set again.
Thanks for coming back to me.
Henry
Henry Falkner
Thanks for the battery-welding info. Might look into this.
The Super Micro is what I used on the SH-1. It is in the E-M10s as well, but you need lenses it can talk to.
Sorry for the delay in answering.
Henry
