R10 / 7 / 3 OVF assist feature
Mike Engles Senior Member • Posts: 2,573
Re: R10 / 7 / 3 OVF assist feature
I did notice this when I first got my R5 last September..
DSLRs had AF sensors in the OVF which must read off the bottom of the prism, like the metering.Perhaps the R5 does no AF from the sensor, but does what DSLRs did, reading off the EVF screen. Otherwise why the dependence on exposure and Picture style. Live view seemed not to use the OVF AF, it was independent and the DSLR AF had to be adjusted to match Live view.
It also might explain how Canon recalibrated my R,5 to my lenses.Not wholly successful, but they can do a DSLR style AFMA, as the Canon tech suggested to me, but would not call it that.
It is possible that the R3 and its juniors work completely differently from the R5 and R6.
Tazz93
Tazz93 Veteran Member • Posts: 3,473
R2D2 wrote:
Does anyone know if the autofocus utilizes this “altered” view when focusing?
It would be similar to what I do now by turning “Exp simulation” off to improve AF (works especially well in darker environments).
That would be the biggest benefit for me.
R2
On my R5, exposure matters as far as AF. Underexposed shots will have poor AF in low light. I do find that a normal exposure in low light works just as good as exposure sim off on the R5, so I tend to never underexpose.
I didn't test that when I had an R3 in my hands, but I'd assume it is the same. It worked very, very similar to the R5. Unfortunately, I didn't use the OVF assist enough to determine if it would work better in low light, but I'd assume that would be like the exposure sim off on the R5.
I would guess that The R5/R6 need the exposure to be good in order to "see". Remember they (and I believe the R3), use a single image processing pipeline, meaning what you see is what the camera sees. The Nikon, which has two different feeds for the EVF and sensor recording, could potentially get around the problem but I'm not sure if that is the case.
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
They must be reading from the EVF if they have to 'see', like a DSLR reads from the bottom of the prism / focussing screen.
Goodmeme Forum Member • Posts: 52
It's a bit late for this, but I'll add my 2 cents...
Speaking as a long-time DSLR holdout, who loves the experience of taking pictures and being in the moment, not just the end result...the OVF (essentially HDR) simulation feature is brilliant.
I don't need exposure simulation, but I do want to see the scene I'm shooting as naturally as possible. Previously that meant using a mirror. But having used an R3 for a brief time, I would say that the viewfinder experience is better than using my 5D4. I'm gutted the new R6 has the same lower res EVF as its predecessor, as with the OVF simulation, 5.76m dots EVF is a good experience.
I shoot raw and am quite happy adjusting for exposure rather than potentially over-exposing in camera and losing highlights etc. Even in snow I will only mildly adjust exp. by say, +1, and am happy with what I get once its processed. Metering is amazing these days, unless you shoot jpeg, turn on the OVF simulation.
 Goodmeme's gear list:Goodmeme's gear list
Canon EOS 5D Mark IV Canon EOS R6 Canon EF 20mm f/2.8 USM Canon EF 35mm F2.0 Canon EF 35mm F1.4L USM +8 more
KLO82 Senior Member • Posts: 1,527
cfieldgate wrote:
I like it on my R3, but having played with the Picture Styles I have managed to set up a much more ‘true to life’ view using the standard EVF mode which provides the benefit of Exposure Simulation. It’s not quite as nice but it’s acceptable to me.
Can you share your picture style settings?
From my understanding, a good way to get realistic looking outputs is to set HDR PQ and Highlight Tone Priority enabled. You will get raw and/ or HEIF files only. You can convert them to Jpeg to get photos that will look close to what you saw with your own eyes, but within the constraints of SDR display/ print. You will get exposure simulation as well as realistic looking output, unlike OVF simulation which by definition will not provide exposure simulation. OVF simulation takes the advantage of HDR display, so it cannot show you how the output will look on SDR display/ print.
 KLO82's gear list:KLO82's gear list
Canon EOS RP Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 24-70mm F2.8L II USM Canon RF 35mm F1.8 IS STM Macro
itsallBb2me Senior Member • Posts: 2,123
My standard setup is the R7 with the RF 100–400mm telephoto. I have the OVF Sim assigned to a button where it toggles on and off. This allows me to “brighten” a scene which is dark in the viewfinder without changing exposure settings. This can be very helpful for judging composition and focus point location, and is very welcome when I am simply using the camera and lens as a telescope. BTW, the view this gives me toggled on does appear to be identical to the result I would obtain with a standard HDR shot. Useful, but I would not set it on full-time in the menus.
 itsallBb2me's gear list:itsallBb2me's gear list
Canon EOS R7 Canon RF 50mm F1.8 STM Canon RF 100-400mm F5.6-8 IS USM Canon RF-S 18-150mm F3.5-6.3 IS STM Apple iPad Pro +2 more
