R10 / 7 / 3 OVF assist feature
Dareshooter Veteran Member • Posts: 5,842
Reading through the specs of the R10 I noted there is feature called OVF assist hitherto only found on the R3. Do any R3 users here use this feature and if so what are advantages/ disadvantages of OVF assist ?
Canon EOS R10
MaStErPsX
MaStErPsX Regular Member • Posts: 203
Re: R10 / 7 / 3 OVF assist feature
It's OVF simulation : https://www.dpreview.com/articles/2575223440/canon-eos-r3-s-ovf-simulation-what-it-is-and-why-it-matters , better dynamic but no more exposure simulation
 MaStErPsX's gear list:MaStErPsX's gear list
Canon EOS R6 Mark II Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4.0-7.1 IS STM Canon RF 85mm F2 Macro IS STM +6 more
OP Dareshooter Veteran Member • Posts: 5,842
Thank you. I’ve read that but  I was curious about actual user experience as I haven’t seen any comments about it anywhere so I was wondering if it is a feature that’s gone unnoticed maybe because it’s confused with exposure simulation .
cfieldgate Regular Member • Posts: 475
I like it on my R3, but having played with the Picture Styles I have managed to set up a much more ‘true to life’ view using the standard EVF mode which provides the benefit of Exposure Simulation. It’s not quite as nice but it’s acceptable to me.
 cfieldgate's gear list:cfieldgate's gear list
Canon EOS-1D X Mark II Canon EOS R3 Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 300mm f/2.8L IS II USM +6 more
Tazz93
Tazz93 Veteran Member • Posts: 3,473
OVF assist feature
Just spent a week with an R3 and honestly couldn't find a use for the feature. I'm sure there was more to it, but when I enabled it it just felt like a brighter display. I only gave it a few minutes of use before moving on. As the other poster stated, the standard exposure sim is way more useful and I found I was missing more perfect exposures with OVF Assist on.
I wouldn't expect to see this feature combined with Exposure Sim in the future either. I guess the idea is to give you a higher dynamic range to see what the shadows "could" look like to an extent. Because the normal Exposure Sim is a direct representation of the actual image (in a lower dynamic range) adding Exposure Sim to the OVF Assist would not be representative of the image, so its likely disabled on purpose to avoid an inaccurate representation on the image.
IMO, this one is like Dual Pixel RAW, interesting feature, but no real use.
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
Re: OVF assist feature
My understanding is that OVF Simulation presents a wider dynamic range, possibly based on HEIF as opposed to the Jpeg you get with the EVFs normally. So you should be able to see into the shadows better and the highlights transitions should be smoother. Neither of these views are therefore going to be ‘true’ to what you get when shooting RAW and post processing in your chosen application 😀
Tazz93
Yep, that's my understanding too (but I don't know what file format its trying to mimic). The fact that they will not be a true representation of the output is why I wouldn't expect it to ever have an exposure sim attached to it.
However, if Canon moved to HEIF as their standard rather than Jpeg, I see no reason why Exposure Simulation for wide dynamic range EVFs would not be possible in future cameras.
Thanks all. From your collective experience’s it doesn’t seem like a feature that I’d find useful because I’d rather see in an EVF what the camera will actually deliver . I have an R10 on pre-order and when it arrives I’ll try it out for myself just out of curiosity 😊
Tim Kamppinen Regular Member • Posts: 152
The real world use case is when shooting with flash against a bright background such as a window or at sunset and finding that your subject is a complete silhouette in the viewfinder and you cannot see their face. This makes timing your shots and even focusing accurately very difficult, and is a fairly common occurrence for me as a wedding photographer.
At least, I really hope it fixes that issue. I don’t have an R3 and I didn’t see anyone talking about that use case in the reviews. But hopefully if it’s going to be in the R7/10 they might add it to the R5 via firmware.
Mike Engles Senior Member • Posts: 2,573
That would be useful in severely back lit situations as it would be easier to see dark areas, for reasons of framing. It can be done in Picture Styles, but also by using AUTO ISO, no simulation and exposure comp..
Possibly that is what this mode does in essence. Also a greater load on an already overloaded battery?
Possibly it bypasses Picture Styles and is very likely a higher bit format than 8 bit. If you rely on JPEG and the Picture Styles than that could be a problem.
It should be closer to 14 bit raw, at 10 bit HEIF than 8 bit JPEG with an arbitrary Picture style.
Sittatunga Veteran Member • Posts: 5,406
I don't think it's trying to mimic any file format. It's for the people who grew up with SLRs and DSLRs and rangefinder cameras.  The name suggests it's trying to mimic an optical viewfinder, which is great for people using studio flash,  or outdoors wearing sunglasses, or trying to recover an unnatural amount of shadow detail.
Tazz93
Flash shooting could be a great use case for the feature, because flash shooting effectively negates exposure sim anyway. That said, it wasn't a big difference in the dynamic range shown, but still I do believe your use case is a very valid one. Thanks.
Tazz93
I didn't try it in a severely backlit scene but it should lend itself well to that. However, like I said in the previous post, its not a significant difference in DR (for the limited use where I tried it). So we are talking about subtle differences.
R2D2 Forum Pro • Posts: 26,531
Does anyone know if the autofocus utilizes this “altered” view when focusing?
It would be similar to what I do now by turning “Exp simulation” off to improve AF (works especially well in darker environments).
That would be the biggest benefit for me.
R2
The question is why do Picture style and Exposure Simulation affect AF.?
Why would the AF sensors be interested in what happens on the EVF?
Was it the case with DSLRs also?
In the case of Exposure Simulation (or its disabling) at least, the camera indeed uses that image to calculate autofocus.  I haven't tried changing the Picture Style however to try to reproduce this effect though.
IDK, maybe because we're interested in it too?
To tell you the truth, I never paid any attention.  I noticed the effect right away with my R5 however.  I've never seen any "official" info from Canon, any of their Explorers of Light, or anything on the Web regarding this either.  I have been trying to spread the word around here though.
It takes just a couple of minutes in a darkened room to verify.
R2
