Fuji Xf35mm f2 R wr vs Fuji Xc35mm f2
Started 10 months ago | Questions
void_and_null New Member • Posts: 15
I am getting the Xe4 without kit lens(xf27mm) since it isnt available in my place. Now I am stuck with what lens I should get with it for landscape and street photography. I am not sure about the differene between Xf35mm r wr and Xc35mm.
Would like some suggestions on which to buy with the camera. This is my first camera so I dont have any other lens and so I am looking for a lens that would do just fine on everyday basis.
Mimsy89 Junior Member • Posts: 32
Re: Fuji Xf35mm f2 R wr vs Fuji Xc35mm f2
I’ve had both but only have the xc currently. Optically, the lenses are supposed to be the same so the image quality is exactly the same
The xf Lens is weather sealed, made of metal and has an aperture ring
The xc lens is plastic. Not weather sealed and doesn’t have an aperture ring.
As they are the same optically you need to decide what’s more important to you. Arguably the xf makes more sense for future proofing if you ever get a weather sealed body and I am a big fan of aperture rings on lenses.
But I personally love how light a setup my x-e4 and xc 35 is. Since you don’t lose out in image quality you can use the savings towards other gear or towards getting out somewhere to take photos
hope that helps
 Mimsy89's gear list:Mimsy89's gear list
Pentax MX-1 Sony RX10 IV Ricoh GR III Fujifilm X100V Fujifilm FinePix S5 Pro +4 more
(unknown member) Regular Member • Posts: 201
Personally, I would opt for the better quality XF version. It might be more expensive, however, you can still pick up a used version for a reasonable price.
john Clinch
john Clinch Veteran Member • Posts: 4,755
Are you sure you don’t want the 18 55 zoom? Or the lighter wider one 15-45?
For me 35mm is quite a narrow field of view for landscape on apsc. If you really want a prime I would go wider say 23mm or even 18mm. It’s all of course personal preference
Dem Bell Senior Member • Posts: 1,091
Have you considered the XF23 f2? Also, the XC15-45 is slow but cheap, very versatile and surprisingly good optically at the wide angle.
Personally, I sometimes find even the XF27 f2.8 a bit too long for everyday use, especially indoors. Having said that, film cameras often came with a standard 50 mm lens (similar angle of view to the 35 mm lens on Fuji X) and many people used them for everything.
bastibe
bastibe Senior Member • Posts: 1,236
If you don't want a zoom, the XC 35 is a great match for your X-E4!
Use it, love it, learn with it, and if you later want to swap it for a different lens, you won't lose much money if you choose to sell it.
(That said, I would generally advice any beginner to start out with a zoom lens; maybe a used 18-55 or 16-50, in addition to the prime, just to get some variety and try out different focal lengths. )
 bastibe's gear list:bastibe's gear list
Ricoh GR III Fujifilm X-Pro2 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +5 more
DK Photo Regular Member • Posts: 264
Get a kit zoom
Such as the 18-55mmF2.8-4.
