Canon EF 70 - 200 mm f/2.8L USM Lens (Black & White) in Canon M50
Started 9 months ago | Questions
akrain New Member • Posts: 1
I'm planning to buy a Canon EF 70 - 200 mm f/2.8L USM Lens for my Canon M50.
Will Canon EF 70 - 200 mm f/2.8L USM Lens (Black & White) lens fit in Canon M50 , If we put full frame lenses on APS-C, sensor camera will it be far away than a full frame?
Please tell me will this lens suit the camera and will this give better results ?
xtam667 Regular Member • Posts: 307
Re: Canon EF 70 - 200 mm f/2.8L USM Lens (Black & White) in Canon M50
You will need an EF to M adapter to fit it. It is a very good lens and will work fine on the M50. However, it is very big and heavy compared to native M lenses. Because of the crop factor it will behave like a 112 - 320 mm lens on full frame.
A better balanced option is the EF 70-200 f4 lens. I have the Mk I version with IS (Image Stabilization) and it works well. Much smaller and lighter than the f2.8 version but still I feel it is too big on an M camera.
Will it give better results? It depends on what do you use now and what are you after. Both are really very good lenses. Whenever I do not like the results I get I know it is not the lens's fault.
thunder storm Forum Pro • Posts: 10,139
Get the f/2.8 mark II.  This lens will give you way better results than ef-m lenses. You will need an adapter.
On a full frame camera the lens will give you less reach, but more shallow depth of field, making it very nice for portraits.
45 is more than enough, but 500.000 isn't
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
