This post is about the Polaroid J-66 that I converted a couple months ago.
Polaroid J-66 converted to use modern 120 roll film.
The J-66 is not a good one to convert, but that is what I bought earlier this year, as explained in my first post, so I worked on it anyway to see how it would do. This camera was made to use Polaroid 3000 ISO instant picture film. The shutter, a pneumatic type, is controlled by the light meter, the "electric eye", as it was called then. In this photo, the light sensor /meter is to the right of the lens, and it is covered by a light blocking cover that I made out of plastic. My intention was to reduce the amount of light getting to the meter so as to cause slower shutter speeds. Polaroid made a similar cover, with diagonal slits, for the same purpose, in order to use their color film, which was much slower. I was trying to get my camera to be compatible with 400 ISO 120 film. It worked, but with mixed results.
Polaroid J-66 converted to use modern120 roll film.
This photo shows the back open with just backing paper on the spools. A new roll of film would be set in the right chamber. I did a lot of trial and error with this camera, trying to get the paper to "flow" easily from right to left, to the take-up spool. This is my final configuration. The spool on the right is just set in there unattached, with the wood "wheels" acting as spacers. At first, and for various trial fittings. I had the spool attached to short spindles, with springs for spacers. It had a lot of drag, and could hang up near the latter part of the paper. Eventually I tried it like this and it worked fairly well.
When I converted that model 800 camera back in the early 1990s, I didn't make a viewing window to see the frame numbers on the backing paper. Big difference. I used a sacrifice roll of film to count revolutions of the winder wheel, which was doable, but not convenient, nor accurate. I had a little overlapping in the few rolls I used. Generally, it worked, but with mixed results. It was just awkward. This time, I cut holes through two plates, this cover, and the film pressure plate on the other side, and glued on a little oval of translucent plastic. This is much better, of course. To see the numbers and other markings on the paper, I open this door just for that, then close it when done.
This is an earlier photo, from April, in the early part of conversion. It shows my first configuration for the right chamber, which I later discarded. I included this photo to show the frame I put in there to frame a photo. The inside dimensions are 5.5cm x 7cm. I made it narrower than 6cm on the short sides so as to have rails for the film to lay on. Without it, the film might sag down a little if not held taught, and it could happen, ruining the focus. In this photo, the frame is green, my first painting. I later painted it black after I bought some. In this camera, the luan fits ok behind the bellows. For the 95A, it is different--not quite as much room. I had to use thinner material, some plastic from a plastic clipboard. For the J-66, my first thought was the luan, and I used that. I used super glue gel to glue it in at the corners, and a bit in some other places. I later found that the 5.5 x 6 cm frame size worked ok. It is not too long. I wanted a rectangle, instead of 6cm square, and decided on what I used. For my 95A, I use a size of 5.5cm x 9cm, and that didn't work--too long. Frames overlapped. I had to make a new one, same size as for the J-66. By the way, I removead the heavy rollers to reduce weight.
Polaroid J-66.
In this photo, the light meter is showing, and the needle in the window on top, which has a light half and a dark half. The lens ring on the front can be turned to adjust exposure, by changing the aperture. I happened to get the user manual with this camera, but they can be found online. Adjusting exposure can be a little tricky, but wasn't too bad. I got some pictures. This camera was made for fast film, to be hand-held usually, so it wasn't equipped with a cable release socket. The shutter is cocked with that lever on the left, and then the shutter button pushed. This can cause camera shake. The pneumatic shutter has a bit of delay, so I was counting on that to "cover" for any shake. A sturdy tripod is necessary.
My first roll, of only two used, had mixed results, and so did the second. Nothing real sharp, but close enough. My computer did some sharpening. I tried different exposures, from "N" for normal, to wide open. I might have overdone it a little, or developed too long. Somewhat dark. My 2nd roll had some frames blurred, and/or underexposed. I'm used to digital now days, although I used film for decades. Now, I just push a button. On the Polaroid, I forgot some times to advance the film, and got multiple exposures--ruined some frames. Takes a little getting used to. I used caffinol for developer, at 12 min for those rolls. I used one roll in the 95A, and developed for 11 min; still too long I believe. Anyway, here are some photos from the J-66.
Old feed mill and store.
This was my 2nd scan and better.
Big old house not far away.
I use Photoshop Elements to work on photos. I tried different scans and treatments. This one is fairly good, although I got some streaks at the bottom. I got some streaking and other elements in all this. Sharpening with the computer is necessary. The J-66 has a plastic lens.
Old church.
I guess that will do for now. I'm into the 2nd roll on the 95A, with the shorter frame inside.
Friday morning: I want to add a little more to this. After I did the conversion, I looked up film to buy online, and found that there is modern 120 film in 3200 ISO. It is too expensive for me, but I thought that it would work about right for this camera, without the cover over the light meter. It was made for 3000 ISO, so it seemed plausible that the cover could be removed and the camera used hand-held, and exposure could be set by the light meter needle indicator as originally intended. I won't be doing that. A couple nights ago I looked up 3200 ISO film reviews, and found some for Ilford. Reviewers said it is actually 1000 ISO, with a lot of latitude, and can be shot at 6400 ISO and even beyond. Seems far-fetched to me, but they did it I guess. If it is not a true 3200 ISO, I don't know if it would work in this J-66, as it was originally set up. If it is a true 1000 ISO film, seems that this would throw off exposures, since the camera was made for 3000 ISO. Of course the exposure could be manipulated by changing the aperture, but a person couldn't go strictly by what the light meter needle shows. That's my thinking. A person would have to do some trial and error to see how it worked out. I'll skip it.
I used Arista-Edu 400 ISO film, two rolls, in this camera, and developed with caffinol.
Polaroid 95A
Polaroid 95A
I finished the 2nd roll (120 film) with this camera yesterday and developed the film last night. Both the 1st and 2nd rolls did not come out right. I don't know what caused the problems. I did the conversion about the same as for the J66, yet the 95A won't do full frames, except on the last frame. When advancing film, I go by the numbers on the backing paper. The viewing window is lined up with the bottom row, for 6x9 cm photos, same as it is on the J-66, yet they overlap. I thought the longer frame I put in, the first one, caused that, but I replaced it with a shorter frame, same as for the J-66, and get the same results. I don't know what caused the dark clouding along the top and bottom of the film strip. There are vertical smudges too, top and bottom, and some squiggly smudges. Seems that these would be caused during development, but I used the same processing tank and reel that I did with film from the J-66, and the film I used in my twin lens Yashica back in 2014. I didn't get that stuff in all those other rolls, just those from this camera. Mystery. I wonder why the last frame comes out full size, but not the others.
The first frame on this 2nd roll was a view of the Stanford courthouse, a vertical, yet I got only the bottom and some of the street, which was not supposed to be in there. Seems like the framing of the viewfinders (front and back) is off, but they look ok. This camera has a rear viewfinder on top of the camera that is flipped up to use. The front viewfinder is a wire frame that gets pulled out from behind the front standard. Both are lined up on a subject to frame it. They seem to me to be ok. I opened the back and looked through the lens as I worked the shutter, at the top speed of 1/100 sec, which I used for the last four frames, and it seemed to be working ok. I even use the Bulb mode to stop it, to look at the aperture. I can't get proper photos with this camera, so i will have to give it up and quit wasting money on it. The camera looks decent, but something is not right. I don't see how my modifications can cause any of this, because I did the same for the J-66. Back in 1990, I modified the Polaroid 800, and made the frame as long as I could, and images did not overlap, except when I didn't wind far enough. I had to count turns on that one. Images were clear and distinct, and full. This 95A is a mystery. I guess I'm done with it.
Here is a photo of the latter part of the negative strip, and two sections of it. I had the strip on a light box and used a digital camera. I'm putting negative images here.
I got the car in the viewing frame, yet the picture frame has only part of it, and some blank space.
Two photos overlapped. Dark smudging top and bottom.
Frames 5, 6, & 7, right to left.
Latter half. That full height light section on the far right happened too, on both rolls.
Update--July 6
I found out why my film was getting fogged along the top and bottom. I had removed a part and left two tiny screw holes, and one other hole between them, and light was coming in. I overlooked those, until a couple days ago when I was looking over the camera. The screw holes were near the ends of the film take-up spool, and the 3rd hole, for some kind of pin, was near the lower screw hole. I plugged them with black silicone sealer, and eliminated that problem. I'm not sure why my images were overlapping. My viewing window is not quite center, but it isn't on the J-66 either, yet images don't overlap on that camera. To advance film, I get the frame number in the center of the viewing window, and that number is supposed to be in the center of the picture. If the window is not centered, that could shift the images a little, but there should still be the same space between them, with no overlapping. The bellows are different for these cameras, and that might have some effect. I made some tests using 35mm film in this 95A. I am out of 120, and didn't want to use a whole roll anyway, just short sections, 4-4.5 inches. So I sacrificed a roll of 35m. An image gets centered, as I expected. Maybe it comes out too long to avoid overlapping, on this 95A. I have a frame length of 7cm., same as on the J-66. On that 800 I used to have, I made images that were a bit over 10 cm long, but on that camera I didn't go by the numbers on the paper. I counted turns of the advance wheel. The bellows on that camera is the same as on the 95A I think, and the bodies are the same. This overlapping issue on the 95A doesn't make sense. I could replace my frame I put inside with a shorter one, maybe 6 cm long, but shouldn't have to. It should work with the 7 cm length. Maybe I'll figure it out. I might make an adjustment on the viewing window, and might try another roll. Those type cameras made a picture that was 3 1/4" x 4 1/4" (paper size). Actual image size was 2 7/8" x 3 3/4". Here is a close approximation of one, from a photo I made with the J-66.
Old mill in Stanford, Ky
I made this sample with a white border, but made a copy with a black border so it would show up on this white background. That J-66 has a simple meniscus lens made of plastic, and it was intended for images of this size, not enlargements. The 95A has a better, 3 piece, lens made of glass. I don't know how good it is, but it ought to be a lot better than that meniscus plastic lens, so I'd like to get that camera working right. I'll probably tinker with it a little more.
