M6 mk ii vs. R7 for the video
Tomsop Junior Member • Posts: 39
I understand this being a forum for the M line people want to justify staying with the M.  I have M lenses too.  However considering the switch and most people don't talk about video.  I want to use the camera for multiple things including video.  I don't know much about the specs other than they say the 30P and 24P is oversampled on the r7 and the only 4K mode on the M6 mk. ii is 30P.  I also notice almost no one posts examples of videos and it is hard to find any representations of quality video of M6 mk. ii on YouTube.
Are people staying with M6 and are happy with the quality of their 4k video?  Are others relying on video as the reason to leave the m6 mk. II?
I also want to know if the video on the R7 is really that good - I was not impressed with the ice rink examples they posted in the reviews.  I may have to wait to see people posting video with the R7 - is anyone vary familiar with video specs between different cameras able to weigh in on this?
Canon EOS M6 Ricoh Caplio R7
nnowak Veteran Member • Posts: 9,074
Re: M6 mk ii vs. R7 for the video
10
The M6 II uses line skipping and pixel binning when shooting 4k video.  A bunch of the data is just thrown away.  Both the R10 and R7 are reading out the entire sensor and then downscaling to 4k.  Both the R10 and R7 are capable of capturing higher quality video than the M6 II.  The difference comes down to the much faster sensor readout speeds of the R10 and R7.
istscott
istscott Regular Member • Posts: 467
Only a small handful of people had access to the R7. All we can do is comment on specifications.
If you plan on doing anything hand-held, the R7 clearly has an advantage with its sensor stabilization.
If you care about recording internally for more than 30 minutes per clip, the R7 is the clear option. I have a workaround on the M6ii, but it would negate the price difference between the two cameras (Atomos Ninja V).
Personally I'm fine with the M6ii's 4k quality, but I'm coming from using the M50. At the very least it's a step up from the M50 when the M50 is used at 1080p to get DPAF. Not going to spend the time finding examples out there, but the M6ii's pixel binned approach is noticeably less sharp than cameras that take higher than 4k and down sample. The benefit the M6ii gets is that rolling shutter seems fine compared to Sony's aps-c which have a lot of wobble/jello at 4k when panned or have fast moving subjects in the frame.
The only 4k mode being 30p on the M6ii relates to HDMI out. Canon added firmware to correct their mishap by initially not including 24p. I personally use 30p so can't recall specifics and I'm typing this out on a phone.
Would I keep using the M6ii, yes. Do I want some of the things the R7 has, yes. Is it worth $1500... Depends.
In my opinion anything you are not impressed with seeing about the R7, you would be less impressed with the M6ii.
What do I do? Most of my indoor video is recorded with the M6ii and an Atomos Ninja V. The Ninja V is the thing recording. I use h.265 HEVC in 8-bit 4:2:0 and it feels fine to me, but I'm not trying to push the footage. Pretty sure the R7 has that codec, but not sure on how it works in practice. Another reason I'm curious about the R7. Saving my video projects adds up fast in storage. Little things like this help. I Franky don't know how these people manage 10-bit 4:2:2 prores or whatever unless they trash their projects afterward.
M6ii's 4k footage adds up fast storage wise, and again, has a 30 minute per clip limiter.
Another likely win for the R7 is the battery used compared to the M6ii's LP-E17. I'd expect longer mobile video sessions to some degree, but the R7 is powering more stuff, so not sure (EVF, IBIS)
One thing I don't know about the R7 but would like to know is if the dual SD card slots are capable of doing duplicate recording of video. I doubt it given Canon's track record on that feature but if it does then that would be a very welcome feature for serious video work.
The 16mm f/2.8 makes RF kinda interesting, but it is lacking something like the 11-22mm right now.
There is a lot more I could say like the different screen articulation, headphone jack on the R7, etc... But I do see the R7 as a complete video work upgrade not considering size differences if that's a requirement. The M6ii would be better on a gimbal IMO... But the R7 would need one in fewer cases.
bisquefire Junior Member • Posts: 27
Ill stick with my M6mii; considering the weight of the R7 and the lenses. Then considering the cost of the R7 and the cost of the R lenses; I will definitely stick with the M6mii. Some out there may have a suite of EF lenses they can adapt to the R, or have lenses they would trade to fill the money gaps. I purchased the M6mii within the last few years, and filled out the lens list, as I had been using long zoom point and shoots since film died out. I was not interested in going to a full frame or other camera because of the lenses and the weight. The point and shoot was fine for my needs. However, even the one inch sensor point and shoots were lacking in some areas thus the move to the M6mii
 bisquefire's gear list:bisquefire's gear list
Panasonic FZ1000 Canon EOS M6 II Canon EF-M 22mm f/2 STM Tamron 18-200mm F3.5-6.3 Di II VC Canon EF-M 15-45mm F3.5-6.3 IS STM +1 more
istscott
I did get a response from Canon USA's YouTube channel account regarding recording video to both SD cards at the same time. I asked in various ways like email but they were the only one to respond with helpful information. Anyways, they said it can do the video recording with the two SD card slots at the same time. Nice! It can also use them in series where one card is filled and it automatically switches to the other one.
For me, having an instant video backup with an in camera recording is a big feature. Very tempting.
RLight Senior Member • Posts: 4,416
The R7 oversamples 4K, the M6 II does not, it bins pixels.
The R7 has multiple format and codec support, the M6 II does not.
The R7 has C-LOG, the M6 II does not.
The R7 has IBIS, which gives aided IS and corrects for tilt and rotation, the M6 II does not...
Not to mention the R7 has much longer video recording limits...
Now is the M6 II capable with video? Absolutely. It's got Canon's DPAF, Canon's colors and really good 1080P output not to mention the 4K even though binned, has fast readout which for 4K, is a big deal as rolling shutter can ruin that lovely 4K.
Put it this way, compared to Sony and Fuji the M6 II leaves em in the dust. Sony has poor SOOC colors and readout speeds. Fuji hunts in video AF, even the new X-H2 the early firmware still hunts, bad, per the Fuji forum, just as the X-T4 and others do. But as much as the M6 II leaves competition in the dust, the M6 II gets left in the dust by the R7. Much of your poor first impression is likely due to sample footage being compressed for web viewing. I have no doubt the R7 is a video powerhouse. Also, keep in mind that pre-release cameras like the R7, may have limited post-processing options until major vendors produce support. Any footage coming out of pre-prod cameras, may have limited or no grading performed. SOOC essentially which in the video world for best results, well, best results are graded ones.
Now the M6 II is no slouch, I'm very happy with it's output as a general consumer, it just "does it" vs other solutions like say the Sony you need to grade (and color match) your footage and be careful of rolling shutter or the Fuji you need to watch your AF / shoot MF. But yes, the R7 resolves the arguably intentional cripples Canon put in the M6 II as a consumer grade product. The R7 is more geared towards video pros, absolutely.
I'm staying with the M as the R7/10 are much larger, and their lenses footprint in native crop format is, ho hum. And given Canon's track record towards crop glass (EF-S anyone?), I wouldn't count on Canon giving the R7 or R10 the glass consumers want.
Now video and birding are huge reasons to go R7/R10. But as a general shooter? The M system is smaller, cheaper, and has access to more compact, powerful glass. So long as you don't want a fast zoom. Those do better on FF R's though in all honesty. I've adapted and also looked at similar offerings like the Sony 16-55 f/2.8G, there's only so much you can "cheat" physics. A faster zoom will be a larger one, there's just no way around it. Well, except for Canon's PowerShots where the optical formula is even more optimized for virtually zero flange distance and is self-collapsing. But that's not a MILC anymore, that's a point and shoot. And Canon will probably never make that aggressive of a point and shoot ever again.
 RLight's gear list:RLight's gear list
Canon EOS R3 Canon EOS R50 Canon RF 28-70mm F2L USM Canon RF-S 18-45mm Canon RF-S 55-210mm F5.0-7.1 IS STM
mstMuc
mstMuc Regular Member • Posts: 103
R7 is the more capable camera because it’s using the latest digic chip and algorithms.
It’s just: do you really need the difference?
At least if social media is target then the differences are negligible …
Different CMOS chip I gather too, probably faster readout version of the 90D sensor with IBIS. That and DIGIC X.
There's a little more than compute alone going on here.
KoolKool Regular Member • Posts: 263
if you want APS-C camera that shoot sharp and vibrant 4K video, you better stay away from Canon in first place.
KEG
KEG Veteran Member • Posts: 4,909
Haven't done any real comparision but 4K output from my EOS R and M6 mk II look really nice on my 13" MacBook Air screen
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
All in all, it comes down to what you are willing to spend, or what you can justify.
ntsan Senior Member • Posts: 1,029
R7 is beg to different since it's oversampling from 7k so way theroratically it should be shaper than any other apsc with only 24mp.
Anyway I pre-ordered the R7 for video as the little brother to the R5c and C70 we got. M6ii 4k is really not usable if you want to punch in 150% in post, it just way too soft!
On the 5k iMac screen u can tell the difference between pixel binned vs supersampled 4k easily.
 ntsan's gear list:ntsan's gear list
Nikon Coolpix 5400 Canon EOS R5 Canon EOS R7 Sigma 18-35mm F1.8 DC HSM Art Canon RF 50mm F1.8 STM +4 more
KEG
Did a quick comparision between R and M6ii, R thankfully wins due to ALL-I but the output from EOS M6 looks very good and is pretty sharp on my 65" 4K tv.
KEG
R Video Regular Member • Posts: 241
I was looking forward to the R10 but once the specs were released I decided to wait however many years it will take for Canon to stop crippling its cameras' video specs. The M6ii has 120fps but sound is disabled and autofocus is disabled. After several years waiting for this R10, which seems to be the only successor to the M6ii to come out (the R7 is much more expensive so I don't see it as an M6ii replacement), there's still no improvement in the 120fps area. Sound is still disabled and from the looks of the clips on Youtube it seems that autofocus is still disabled too. It still only provides an in-camera render at 30fps - there's no access to the original 120fps recording. This is disappointing when I have 4 other cameras that record in 120fps and let me have all those frames to work with. And one of those cameras is 7 years old.
Then there's 4K60 - yes it's nice that they finally put it in there after only having 4K30 in the M6ii, but it's cropped massively. It's nice that it's an honest 4K this time instead of the lie that was the 4K on the M6ii, but that crop at 60fps is giant and a deal breaker for me.
Markr041 Forum Pro • Posts: 10,078
M6 mk ii 4K Videos: They are Good
Day:
Night (spectacular):
I shoot Canon R5 8K RAW videos too.
 Markr041's gear list:Markr041's gear list
Panasonic ZS100 Olympus TG-5 Canon EOS M Panasonic Lumix DMC-GH4 Nikon Z6 +5 more
KEG
Shouldn't people actually wait for production R10s and R7s before they get declared a winner in 4K, I have both EOS R and M6 mk II and the R is better due to ALL-I in my opinion.
KEG
KEG
Re: M6 mk ii 4K Videos: They are Good
Markr041 wrote:
Day:
1440p at least looks pretty nice and sharp.
KEG
A Sharma New Member • Posts: 7
I own and enjoy both the M6 II and R7, but I've been using the R7 exclusively for stills (for birding mostly). Although I'm not much of a videographer, once a week I'm asked to shoot some training videos for a dog agility class, and I've generally used the M6 II mostly because of my greater familiarity with it. But today for the first time, I decided to shoot with the R7, using the same 18-150 mm kit I use for the M6 II. In addition to animal subject tracking, the oversampled image quality was distinctly better, which actually surprised me. Moreover,  improved co-ordination between the lens IS and the R7 IBIS was noticeable. I didn't have much use for the 4k60p (vs 4k30p), but that might also be an advantage. That said, I'm pretty sure that no one in the class cares about the difference, since the videos are intended only for training purposes
Larry Rexley Senior Member • Posts: 1,238
Thanks for reactivating the thread and sharing your experiences. It's good to hear some real-world first impressions of the difference. Great to hear improvements with coordination of the 18-150 as well.
The M6ii is limited in 4k video by the speed (generation) of its processors, so it's not a big surprise the R7 would produce better oversampled video.
If they can put out more RF-S lenses for the R7, at least the counterpart to the EF-M 11-22mm f4-5.6 IS STM, the R7 would become much more tempting to some of us. The 11-22 is a popular vlogging lens for the M6ii and M50ii and kind of a staple zoom to go with the 18-150.
 Larry Rexley's gear list:Larry Rexley's gear list
Canon EOS M6 II Canon EOS M200 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +21 more
