Canon R3, inconsistent exposure
Horrgakx
Horrgakx Regular Member • Posts: 387
Hi all. I shot my first big shoot with the R3 but I got very inconsistent results. Most noticeably with the exposure between frames, sometimes up to 2 stops either over or under. Has anyone seen this, or have any tips for improving consistency?
The settings are below, trying to stick to relevant ones;
  • Raw format
  • Aperture Priority
  • Auto White Balance
  • Manual ISO
  • Auto Lighting Optimiser; Standard
  • Highlight Tone Priority; Off
  • Anti-flicker shoot; Disabled
  • Metering Mode; Partial
  • White Balance; Auto
  • Drive Mode; Single
  • Shutter Mode; Electronic
  • Firmware: 1.1.1
Thanks in advance.
 Horrgakx's gear list:Horrgakx's gear list
Canon EOS-1D Mark III Canon EOS-1Ds Mark III Canon EOS-1D X Mark II Canon EOS R3 Canon EF 28-300mm f/3.5-5.6L IS USM +3 more
cfieldgate Regular Member • Posts: 476
Re: Canon R3, inconsistent exposure
Partial metering only uses a small part of the frame at the centre of the FOV. Can you show us some examples?
 cfieldgate's gear list:cfieldgate's gear list
Canon EOS-1D X Mark II Canon EOS R3 Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 300mm f/2.8L IS II USM +6 more
Neil Schofield Contributing Member • Posts: 744
You don’t say what lens you are using, but it could be the lens contacts that need cleaning
Dareshooter Veteran Member • Posts: 5,842
ALO and partial metering might be contributing to your issues but with any photos with exif it’s just a hunch .Also what software are you using for converting your Raw’s ?
Horrgakx
OP Horrgakx Regular Member • Posts: 387
Thanks for your reply - I was getting the same result with 3x lenses;
  • Canon EF 16-35 f2.8L IS mk3
  • Canon EF 24-70 f2.8L USM mk2
  • Canon EF 70-200 f2.8L IS USM mk2
But thinking about it, perhaps the Partial metering mode might be largely the culprit.  I'll try full Evaluative metering.
Horrgakx
Yes I think the Partial metering mode might be largely the culprit. I'll try full Evaluative metering.
I'm using Lightroom with the latest Camera RAW.
Horrgakx
I think that the Partial metering mode might be largely the culprit. I'll try full Evaluative metering.
As a long time 1 series shooter, it’s disappointing that Canon saw fit to drop the spot/partial metering based on the focus point for the R3. As Canon’s current flagship mirrorless camera I would have expected it to have this feature.
That said, I have found Evaluative metering to be pretty good and am used to compensating for specific subjects that require it. At least I can configure the R3 to set Exposure Compensation the same way as I have it on my remaining 1DX II.
ALO is not recognised by third party converters so your exposures could look different from the rendering in Canons DPP. ALO has it’s uses for jpeg shooting but should really be disabled when shooting Raw combined with third party converters .
