Rear lens of Olympus 100-400: How to clean?
Started 10 months ago | Discussions
Peter Heckert2
Peter Heckert2 Senior Member • Posts: 1,030
The rear lens of the Olympus 100-400 is really deep inside and the opening is very tight.
What is the recommended way to clean this, if ever required?
Is there a recommended way or are there special tools for this?
It is even difficult to inspect.
 Peter Heckert2's gear list:Peter Heckert2's gear list
Olympus E-M5 III Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Olympus 100-400mm F5.0-6.3 IS
Jan Krux Contributing Member • Posts: 576
Re: Rear lens of Olympus 100-400: How to clean?
I use a blower for that - every now and then. Mostly more than fine. The rear plastic cap is not that tight to not let in a bit of dust. But didn't have a problem yet. As you said the lens is very deep in the barrel it is very unlikely that severe fatty dirt gets in there.
I do own the lens for nearly 2 years and it serves me very good even on dusty trips into the bush in South Africa and Botswana. So don't worry too much.
cheers, Jan
 Jan Krux's gear list:Jan Krux's gear list
Olympus 100-400mm F5.0-6.3 IS Olympus E-1 Olympus E-5 Olympus E-M1 II Olympus E-M1 III +5 more
glassoholic
glassoholic Veteran Member • Posts: 7,641
I get a craft paintbrush wooden handle (for safety) and turn it around and wrap a microfibre cloth 2 layers thick around the wooden end and then insert and clean. Either with or without a drop of ROR or Eclipse cleaning fluid on the cloth. Recently I discovered Zeiss Pre Moistened Lens Cleaning Cloths... not to be confused with the Zeiss individual lens/ spectacle cleaning cloths found in supermarkets and chemists. The afore mentioned, as pictured below, can also be wrapped around the wooden handle as they are quite large. They clean superbly and almost always without any residue or streaking which then needs buffing with a microfibre.
Addicted To Glass
M43 equivalence: "Twice the fun with half the weight"
"You are a long time dead" -
Credit to whoever said that first and my wife for saying it to me... Make the best you can of every day!
Dave in Wales
Dave in Wales Contributing Member • Posts: 901
Re: No way.
In over 60 years at this nonsense, I have never-ever, ever found the need to go anywhere near a rear element of any lens I've owned, and that must run into hundreds.
The front element might get a puff, but very, very rarely.
glassoholic
Re: No way.
The OP did say "if required", and I agree, that well recessed rear elements usually go years before cleaning is required. A friend of mine bought a well used but optically good Canon EF 400mm f5.6. She felt her pictures were a bit "hazy". I threw the protective filter in the bin... it was covered in fine scratches from poor cleaning. The rear element, really deep down inside, looked like a frosted light bulb it was so dusty... hardly any of which blew off with a blower. Wet cleaning was needed and the overall optics came up 9.7/ 10 and her pictures looked good after that.
Addicted To Glass
