T6 Will Not AF in Manual Mode
Started 11 months ago | Discussions
LuckyPaco New Member • Posts: 5
when I place the camera in Manual mode it will not auto-focus, when I turn the dial to sport mode, micro mode, etc, the AF works fine. I'm using the standard 18-55mm kit lens, the A/F switch on the lens is set to A/F, contacts on camera and lens are clean. Camera and lens are less than 1 year old has only been used a few times, but never in the M S A P modes until today.
Any help is greatly appreciated.
Canon EOS Rebel T6 (EOS 1300D)
stevet1 Senior Member • Posts: 1,300
Re: T6 Will Not AF in Manual Mode
Paco,
Just out of curiosity, does the AF work in Av mode or Tv modes?
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
OP LuckyPaco New Member • Posts: 5
Paco,
Steve Thomas
HI Steve,
Negative, M, AV, Tv and P do not AF all other modes AF works fine
LuckyPaco wrote:
stevet1 wrote
Paco,
Steve Thomas
HI Steve,
Paco,
It sounds like you may have a faulty selection switch.
Have you tried a different lens to see if the problem extends to all lenses, or if it is confined to just that one lens?
Steve Thomas
stevet1 wrote:
LuckyPaco wrote:
stevet1 wrote
Paco,
Steve Thomas
HI Steve,
Paco,
Steve Thomas
Good Morning Steve,
Thanks for your help, I only have the single lens kit 18-55mm , but I will try to get my hands on a 2nd lens and try it out, thank you so much for your advice.
