Talk me into or out of the RF 50/1.8
Started 10 months ago | Discussions
Texchappy Contributing Member • Posts: 598
For a while, I planned to get the the RF 50/1.8 stm. lately however, I’m leaning away from it. Against it is some sub par reviews, mushiness away from center, and it not being a zoom*. For it are cost and aperture **.  So talk me into or out of it…
*Been shooting primarily primes on Fuji for the last decade. Being in a wheel chair while shooting, I’ve found zooms much more convenient. I currently have the RF 24-105L & RF 100-400.
**It’s hard to beat $200 but if I never use it then it’s still a waste. However, having nothing less than f4 is new to me.
 Texchappy's gear list:Texchappy's gear list
Fujifilm X100F Fujifilm X-Pro1 Canon EOS Rebel T4i Canon EOS R6 Fujifilm XF 18mm F2 R +10 more
Karl_Guttag Senior Member • Posts: 1,883
Re: Talk me into or out of the RF 50/1.8
It is certainly the worst of the RF lenses I have tried (both "consumer" and "L"). It is sharp in the center and mushy in the outside areas. Unlike even the RF24-240, keeps better contrast in the corners. The RF85f2 is very good compared to it.
Here is a link to some comparisons I ran using the Canon RP (similar in resolution to the R6) comparing the RF50f1.8 to the RF24-240 and RF80f2. https://www.dpreview.com/forums/post/64790334 These tests are rather harsh and you may not notice the issues as much in real-world photos.
On the other hand, it is only $200 and you don't have any fast lenses. If you want to shoot in existing light and the subject is somewhat centered, it will probably do OK.
 Karl_Guttag's gear list:Karl_Guttag's gear list
Canon EOS R5 Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 24-240mm F4-6.3 +14 more
bodeswell Senior Member • Posts: 1,378
What sort of shooting do you do? Do you think you would not use it because it is soft in the corners, or do you think you would not use it because you rarely shoot at 50mm? If the latter don’t buy it. If the former, do you really need corner sharpness at wide apertures? If so, don’t buy it. Otherwise it’s a good lens at a good price. The RF 85mm f/2 IS is significantly better at $599.
 bodeswell's gear list:bodeswell's gear list
Canon EOS R Canon EOS R5 Canon EOS R7 Canon EF 135mm F2L USM Canon EF 200mm f/2.8L II USM +4 more
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
It's very good for the money. It's certainly the best of the three Canon 50 F1.8 that I have had (the EF 50 F1.8 II, EF 50 F1.8 STM, RF 50 F1.8 STM). It's sharp wide open in the center, and out to a bit beyond the rule of thirds points. It's only really soft wide open in the extreme corners (unlike the previous two iterations of the lens). If you use DXO Photolab (or even just the Deep Prime NR with lens corrections), even the corners are reasonably sharp (the DXO lens corrections are by far the best I've used). But the main thing is that it is small, light, and cheap. If you use it mostly for people shots, like I do, it's unlikely that the soft extreme corners wide open are going to matter.
“When I die, I want to go peacefully in my sleep like my grandfather. Not screaming in terror, like the passengers in his car.” Jack Handey
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
ojenfish Forum Member • Posts: 57
Go to the Canon refurb store and get one. $139 plus tax.
If you don't like it, you can sell it and justify it as an "as long you want" rental.
Imo, the lens is just fine. I had the RF 50 1.2, have the EF 50 1.2 and will be keeping the RF  50 1.8.
 ojenfish's gear list:ojenfish's gear list
Canon EOS R6 Canon EF 50mm f/1.2L USM Canon EF 85mm F1.2L II USM Canon EF 100mm f/2.0 USM Canon EF 135mm F2L USM +2 more
Kokopelli_Rocks
Kokopelli_Rocks Veteran Member • Posts: 3,661
Only if you shoot 50mm. I bought one last year when I bought my R5. I think I used it once and sold it a few weeks ago. I just don't use primes anymore.  Even if I did personally I don't have a lot of use for a 50mm. Used 50mm on my AE1 for years, I also used the EF 50mm 1.8 but infrequently.  For me the lens was a bad purchase.  I have finally built my RF kit to meet my needs. Used the proceeds from 4 lenses to get my final RF zoom the 15-35, great deal on a like new used copy.
 Kokopelli_Rocks's gear list:Kokopelli_Rocks's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Sigma 14mm F1.8 Art Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM +15 more
rmexpress22 Senior Member • Posts: 2,304
8
You're going to get almost every response possible regarding this lens. I think the comments are the same for all 50mm 1.8 lenses.  The lens is bad but also good for the money at the same time.
It's a wonderful bad lens.
Very sharp and weird rendering.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
Interpol Regular Member • Posts: 480
If you never plan to use it because of the IQ issues, then it really is a waste of money regardless of the price tag.  Save up for the 50/1.2L instead, or just stick with your 24-105.
 Interpol's gear list:Interpol's gear list
Sony RX100 VII Canon EOS R6 Canon EOS R3 Canon EOS R7 DJI Pocket 2 +32 more
MaStErPsX
MaStErPsX Regular Member • Posts: 203
Re: Parlez-moi dans ou hors de la RF 50/1.8
I don't find it's a bad lens at all, and certainly better than EF version, good in the center at F1.8 (except with very close subject) but very soft in the corners, at F4 it's very good everywere.
For sure if you want sharp border to border lens at F1.8 it's not the good lens but it's probably the best RF lens for price/performance
 MaStErPsX's gear list:MaStErPsX's gear list
Canon EOS R6 Mark II Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4.0-7.1 IS STM Canon RF 85mm F2 Macro IS STM +6 more
OP Texchappy Contributing Member • Posts: 598
That’s the way I’m thinking, at the moment at least. If I don’t get it, it’s slightly sooner to get a 70-200.
greyalienabductions Junior Member • Posts: 39
It's small, light, cheap, and pretty good. Even though the colors are good, as everyone states the corner sharpness is poor until about f/2.8, then it's just a little soft when viewed at 100%.
Franz Kerschbaum
Franz Kerschbaum Senior Member • Posts: 1,242
The weak corner performance was the reason I send it back. The images below are 100% cornerpics of a xmas chain at different apertures. The RF50/1.2 row is for reference.
 Franz Kerschbaum's gear list:Franz Kerschbaum's gear list
Canon EOS 5D Mark II Canon EOS 7D Mark II Canon EOS M6 Canon EOS Ra Canon EOS R5 +30 more
Canon_Guy
Canon_Guy Senior Member • Posts: 1,486
Well, you must know the best how you would value this lens...
Personally I quite like it (I have the EF STM version which is optically virtually the same). Nifty fifty was always in my camera bag. It costs nothing, measures nothing, weights nothing but if you learn how to use it, it makes very nice pictures. R6 with its lower resolution flatters this lens. I would not choose it for R5.
Since I own it for ages, I did learn to accept its pros and cons and can easily live with them.
But if you know the lower IQ up to f/2.8 would distract you, then look for something else.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
And-roid
And-roid Senior Member • Posts: 3,200
This is what so exciites me about R7, the 35 1.8 macro STM is a very good lens and on the R7 we have a 56mm 1.8 macro with dual is. The 50 STM wasn't massively impressive on the R5 imo. Plus the 16 2.8 cuts out the pretty average corners too for what makes a very cool 25.5mm wide prime or 29mm prime in 4:3 ratio. After years shooting m43 I always wanted to replicate the Panasonic 14 and 15 focal lengths now I can in one lens! Seriously, the 16 2.8/35 1.8 and 85.2 make real sense on the R7, sensible resolution, sensible size and excellent ibis I'm sure. I'll probably go for tge ef-s 50 1.4 for 80-85mm as its fast usm and again its corners are no longer soft lol👍
EOSSpeedLite Contributing Member • Posts: 640
RF 50mm f1.8 is OK if...With Examples...
The RF 50 f1.8 is very good if you need your model close, and accept the fact that the focus plane is not flat across the frame (soft corners). Expect the wide-open shots to be a bit hazy too, lacking a bit of contrast.
Decent post-processing can hide these problems to a certain extent.
On balance, its a very good lens, and if you know what you are doing, you can do pro work with it in some circumstances.
Notice the eye lashes:
The RF 35mm f1.8 is a lot better, and the RF 85 f2 even better.
BE CAREFUL WITH COPY TO COPY VARIATIONS!!
The best photographers talk about pictures & techniques. Posers & Fanboys talk about brands.
 EOSSpeedLite's gear list:EOSSpeedLite's gear list
Canon EOS R5 Canon EF 135mm F2L USM Canon EF 8-15mm f/4L Fisheye USM Canon Extender EF 2x III Canon EF 100-400mm F4.5-5.6L IS II +12 more
thunder storm Forum Pro • Posts: 10,139
As a landscapes lens it's good. So the question is rather simple:  do you need a 50mm for landscapes?  If yes, buy it.
Of course you can buy it because it's affordable, but if you don't need it spilled money is spilled money, even if it's not a whole lot.
If you want a portrait lens being capable to render your backgrounds beautifully it's not worth it imo.
45 is more than enough, but 500.000 isn't
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
RF 50 f1.8 Renders BEAUTIFUL Bokeh..
Your blanket statement is false. The RF 50 f1.8 can render awesome backgrounds...it depends on the background, the distance from the model, and the skill of the photographer. You also said the same thing about the RF 35mm f1.8 some weeks ago, but that was false too.
Awesome backgrounds from the lowly cheap RF 50mm f1.8:
Suave Senior Member • Posts: 2,289
8
If you need convincing that you need it - you don't need it.
Wait... is this a list?
 Suave's gear list:Suave's gear list
Nikon D7000 Canon EOS 5D Mark III Canon EOS RP Canon EF 85mm F1.8 USM Canon EF 24-70mm f/2.8L USM +7 more
Re: RF 50 f1.8 Renders BEAUTIFUL Bokeh..
I'm not going to talk down your pictures, and I'm glad you're happy with it, but I like better bokeh.
This lens also works quite well for video.
