I can't change the language on my Canon EOS KISS
Started 11 months ago | Questions
GoDP Junior Member • Posts: 38
Hi,
After changing my camera's date/time battery, the language changed to Japanese (I suppose). I've tried to change to English but it doesn't change. Battery indicator flashes, reset occurs, but remains in Japanese language. I already reset the camera settings but problem still there.
Has anyone gone through this problem?
Thanks.
Dunlin Senior Member • Posts: 2,611
The menu
It's in the menu, last icon, 3rd down.
https://support.usa.canon.com/kb/index?page=content&id=ART101201
 Dunlin's gear list:Dunlin's gear list
Canon PowerShot SX410 IS Olympus OM-D E-M10 II Canon EF 35-80mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Gimp +6 more
OP GoDP Junior Member • Posts: 38
Re: I can't change the language on my Canon EOS KISS
Let me be more direct:
The camera does not obey my command to change the language, after I changed the date/time battery.
Answers like "Because your camera is a Rebel one" will not be tolerated.
Kameratrollet Senior Member • Posts: 1,106
What if you remove the date/time battery?
I already tried this...
Hmm........
Strange.... Is your camera up to date firmware wise?
I'd tell you what the most recent version is.... only I don't actually know which model you have! I don't operate on "KISS(s)", I operate on xxxD.
Re: Hmm........
300D. Made in Japan.
Firmware Ver. 1.1.1
I haven't tested all the menu. At least "image quality" and "format" are working.
When I change the language to English (I also tried Spanish), the CF card recording light comes on. But the change is not saved.
Re: Hmm........
Firmware Ver. 1.1.1
Sounds like you have the hacked firmware from 10D. If you have ISO 3200/ISO H, then it is the hacked firmware. One known issue with that firmware was about changing language.
"The camera freezes on attempt to switch the user interface language. To change the user interface language use the original firmware."
If that is the case you will need to install the real 300D firmware and then change language. You may after that install the modified firmware from 10D again if you would like that.
http://www.bobatkins.com/photography/digital/digital_rebel_firmware_hack.html
Sounds like Kameratrollet is correct.
I've never owned a 300d, and, while I've heard of the "10d hack", I don't know how one "does" or "undoes" the trick.
Re: Hmm........
Yes, iso H here.
I just found the original 1.1.1 firmware but installation does not start.
https://www.dpreview.com/articles/8379228950/eos300dfirmware
http://www.opendrivers.com/download/driver-11836.html
I think I need the first firmware. Anyone?
Re: Hmm........
GoDP wrote:
Yes, iso H here.
I sent you the firmware and installation manual, if you just check your PM.
Verify with sha256 checksum https://kameratrollet.se/use-sha256-checksum-to-verify-canon-firmware-updates/
368a34a4a660dbefe76f75dc994bfde136659d9571024b194a103b6ef9a52ece E3kr_111-e.exe
Re: Hmm........
OH!!!
It's "E3kr111.fir"
Inside "E3kr_111-e.exe"  file
I was trying with the ".exe" file. That's why was not working.
THANK YOU VERY MUCH!!!
Re: Hmm........
I presume that's your language problem fixed.
If so that's good.
Re: Hmm........
If so that's good.
Yes, fixed. I will keep the original 1.1.1 firmware version.
I believe the first camera owner updated to the hack version. I don't need that.
Thanks!
