RF-S Lenses - What We Know and What is Rumored
Started 10 months ago | Discussions
2ndact scene1 Contributing Member • Posts: 802
Re: RF-S Lenses - What We Know and What is Rumored
musicmaster wrote:
MikeJ9116 wrote:
Not to mention that the lenses referenced like the RF 100-400mm, the 600mm/800mm and others are not all that bright. If one says the 17-55mm f/2.8 wasn't fast enough for them then how can 600mm/800mm lenses at f/11,and the RF 100-400mm, be something they can recommend? Especially on a crop camera where the use cases for a f/11 lens is so narrow it makes them almost unusable. Even the RF 100-400mm is limited on a crop camera.
Why does the aperture being F/11 make a difference on a crop vs a full frame? It will focus the same, just using the inner 1.6x of the lens.
I assume most buying the 600 and 800 are wildlife / bird photographers where you are outdoors anyways.
On DSLR’s, the issues with slow lenses were the inability to focus if the max aperture was narrower  than f/8 (generally but with exceptions) and poor sensor performance at high ISO that produced noice and banding.   Mirrorless has solved the first problem and a combination of better sensors (in some cases) and better software has ameliorated the second.  Personally, I think I was programmed to avoid high ISO settings above 3200 based on what I read. When I got an RP, I was amazed how well ISO 10,000 or 12,000 could look with a little effort.  I did rent the 600mm once and used it at a bird park - both outside and in a birdhouse. It was a bit challenging inside - you needed a non moving subject because fast shutter speeds were just not possible. And even when a bird is stationary, it is still moving some part of its body.
 2ndact scene1's gear list:2ndact scene1's gear list
Canon EOS 5D Canon EOS 7D Canon EOS 6D Panasonic Lumix DC-GX9 Canon EF 85mm F1.8 USM +8 more
MikeJ9116 Veteran Member • Posts: 6,955
musicmaster wrote:
If you are trying to defend using an f/11 constant aperture long zoom on a crop camera then god bless you for trying.
It's a cheap $700 lens that is equal to around 900m FF which is fantastic for wildlife. Show me another 600mm lens for the same price.
But I guess something like these clearly must be fake and terrible photos.
Grey Butcher Bird | Lekha Suraweera | Flickr
Great Egret | 17th January 2023, Causeway Bay Typhoon Shelte… | Flickr
Parrot in Rome | Roberto Villani | Flickr
Small Grass Yellow- | Taken hand held four and a half metres… | Flickr
If an f/11 lens suits a user that can live with its limitations then they should buy it.  I was pointing out the irony of a person saying an f/2.8 crop lens as not being bright enough and then recommending f/11 lenses to be used on a crop camera.
KEG
KEG Veteran Member • Posts: 4,909
f/6.3 is about the slowest lens I would dream of using on crop.
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
Sittatunga Veteran Member • Posts: 5,406
We're getting very far from the subject of likely RF-S lenses here.
You can make anything sound stupid by removing the context.
f/2.8 was talked about in the context of standard zooms.  Apart from the 18-50mm Sigma, which by sacrificing stabilisation is almost small enough to fit the EF-M template, the fast crop standard zooms are much the size of the f/4 full-frame zooms that are effectively faster. The Sigma 18-35mm f/1.8 fits the R7 and would be much better than these were it not so huge. I, for one wouldn't miss the 35-50mm range on APS-C half as much as I'd miss the 15-18mm range.
The f/11 primes allow mere mortals to achieve things on crop format that would otherwise  demand real sacrifices. Nobody's going to carry a 600mm f/2.8 around.
I've used an EOS M  on a 500mm f/8 mirror.  It was the first time I ever wished for IBIS so that I could see what I was focussing on.  But lenses slower than f/6.3 are specialist lenses anyway.
m100
m100 Senior Member • Posts: 2,048
By 2030 lots of Canon lenses will be f/11 ?
It is a sensor of the future thing ?
A f/11 lens would not be as useful on a 10D ?
Dr. says listen to this every morning.
https://www.youtube.com/watch?v=bEeaS6fuUoA
 m100's gear list:m100's gear list
Canon EOS M6 II
koenkooi Contributing Member • Posts: 919
The RF100-500L works great on the R7 at f/7.1 and gets only more versatile if you're willing to use fancy noise reduction in post, like DxO and Topaz offer. But even without NR, it's a great combination to use.
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
My slowest is f/5.6 with the only exception being the EF-M 15-45mm and I put up with it because of its focal range, size and lightweight.
Yet here were are and you are doing the same with this post.
Anyone can use any lenses they wish to and can afford.   The fact is that an f/11 lens on a crop camera makes it a highly niche optic.  If one thinks f/2.8 is too slow on a crop camera then there are better options than an f/11 constant aperture 600/800mm lens.
MAC Forum Pro • Posts: 18,487
again, these f8 and f11 lenses are specialty lenses for birding and field sports outdoors in good light
and again, they provide a great value for those involved in these specialty activities -- which apparently you are not involved
for example, the best birding reviewer on the planet says the $2000 R7 + RF 100 -400 is the best value proposition for those just getting into birding vs all the older stuff for similar dollars
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
