Macro with TTartisans 40mm F2.8 and Extension tubes- has anyone tried before?
Started 10 months ago | Questions
MacM545 Contributing Member • Posts: 780
I was interested in obtaining a TTartisans 40mm F/2.8 macro. I've heard that it can be quite good, at least at macro magnifications. but is it possible for use with extension tubes at all? It's got a close focus of only about 6.7", while it's 119mm at 1:1. I was thinking that it might work at least to some extent, but am not sure given the specifications of the lens. I've tried various conficurations for macro before. For my needs, I've found that 2:1 is a great magnification. I've not been doing much macro in the past like I was hoping for, but the majority of macro that I've done is of static subjects in a "studio" (indoors with controlled lighting and tripod). I've tried using a Diopter on a telephoto, as well as extension tubes with various lenses of mine- including the 7artisans 60mm 1:1. Such techniques worked fine, except that it didn't get me quite as much magnification as I was hoping for (I tried up to about 25mm or 26mm of total extension). I've also tried reversing a 23mm lens along with extension tubes, which actually worked but I don't particularly like the idea of reversing my wide angle- not simply because of dust and/or moisture getting in, but because the focusing distance was rather short. that being said, yes, I can probably get a UV filter somehow on the the rear (side away from camera) for preventing stuff from getting inside, but the aperture control isn't ideal. at least with the 40mm, I could control aperture. also, I could leave the 23mm alone so that I don't need to take the reverse ring off while wanting to use for landscape photography, then putting back on for extreme macro. A 35mm lens would probably be an interesting option also, in addition to the 40mm. I could use extension tubes on a 35mm lens and/or reversal, which might be enough to be able to get 2X.
Now, I've also got the Sony RX100 MK2, which I'm not sure about can do much for macro.
I've found that a lens with less weight is great, but also a lens that can be short so that there can be more room between the lens and subject. So if there's a better option, let me know what that might be.
 MacM545's gear list:MacM545's gear list
Sony RX100 II Canon EOS 500D Fujifilm X-T2 Canon EF-S 18-55mm f/3.5-5.6 Fujifilm 50-230mm II +1 more
Sony RX100
philzucker
philzucker Forum Pro • Posts: 10,390
Re: Macro with TTartisans 40mm F2.8 and Extension tubes- has anyone tried before?
One thing that might help you in your decision process: Important for the available room between the lens and subject is not the length of the lens, but the working distance (measured between front of the lens and the subject). The TTartisan 40mm at 1:1 has a working distance of 3 cm, which is not so much; adding tubes or close up lenses to achieve 2:1 would shorten this working distance even more, making especially the lighting of the subject more difficult.
As a rule of thumb you get more working distance with longer focal lengths at the same magnification. If you're going for a good working distance at 2:1, maybe have a look at the Laowa 100mm 2.8 macro which provides you with a "built-in" 2:1 magnification, and still has a working distance of about 7 cm at that. Of course it's much more expensive than the TTartisan - but it would be a very comfortable solution. There is also a slightly cheaper, smaller and lighter 60mm 2x macro from Laowa out there that has a working distance of about 5 cm at 2:1.
Hope this helps!
Phil
BBbuilder467 Veteran Member • Posts: 7,057
Using a calculator, adding 26mm tubes to a 40mm macro lens would be 1.65x magnification at 172mm from the sensor to subject. Even using the tubes, you wouldn't reach 2:1.
Eggplantt
Eggplantt Regular Member • Posts: 311
Maybe consider combining the extension tubes with a quality close up lens?
Seeing as how you've reversed some non-macro lenses, I don't think a perfectly flat field is what you need (but my experience with close up lenses can reveal very good performance across 2/3rds of the frame at f5.6 on 50mm lenses).
And a close up lens will allow to work at a higher effective aperture, which is important.
 Eggplantt's gear list:Eggplantt's gear list
Lenovo Vibe Shot
OP MacM545 Contributing Member • Posts: 780
That's a great idea. but in practice, I've not found it practical from what I remember. I've tried extension with a close up lens by Nisi for about $75 on a 320mm lens. It was surprising to me, because any existent loss of image quality wasn't noticeable to me with the close-up lens. also, the extension tubes together didn't seem to cause, for me, a noticeable lack of image quality. It was the Fuji 50-230mm 2nd version.
The extension tubes definitely worked on the 23mm Viltrox, but by the time the focus was about 1mm away from the lens, the magnification despite the close focus was only 0.4X. For the close-up lens to work to achieve 2X, it would require a focal length of ~400mm or more. The close-up is in a way the opposite of extension tubes. An extension tube works more effectively for a wider angle lens, but a close-up lens is more effective for a longer focal length.
That being said, it might work differently with an SLR.
gardenersassistant Veteran Member • Posts: 9,656
With a Raynox 250 on a 55-250 lens at 250mm on a Canon 70D I get a tiny fraction less that 2:1 (11.5mm scene width with a 22.5mm sensor width), with a working distance of around 115mm.
True.
I don't think it is different with a dSLR.
True.
I've been wanting a Raynox 250, but was trying to figure how I'd mount the thing to a 52mm and 49mm lens. Not saying that it's not possible, but probably simply haven't found the exact accessory that I might need. seems pretty good for a 250mm lens! The reverse lens technique can work differently to some extent for an SLR. It could be that extension tubes and close up lens might be working the same as for mirrorless. If I can somehow find how to do with a Raynox, I might finally make it work. BTW, is the 250 the strongest close up lens?
True.
The Raynox 250, like the Raynox 150, comes with a spring-loaded adapter. This can be clipped on to any 52mm to 67mm filter thread. For 49mm, you can use a 49mm to 52mm step up ring (or a 49 to anything up to 67) and use the adapter.
Alternatively you can use the Raynox 250 (like the Raynox 150) without using the adapter. They have a 43mm thread so you can use step ring(s) to get from 49 to 43 and/or 52 to 43.
That is 250mm used on a Canon 1.6X crop factor camera. With a different crop factor the scene size covered will be different.
No, there are stronger ones. The strength is measured in diopters, the higher the diopter value the strong the close-up lens.
The focal length of a close-up lens is 1000 / diopters mm. So for example the Raynox 250 is 8 diopters, so its focal length is 1000 / 8 mm = 125mm. That is the working distance, between the lens and the subject when the camera lens is focused at infinity. If the working distance is more than this you cannot gain focus. The working distance can be less than this - how much less depends on the camera lens on which the Raynox is mounted.
The Raynox 150 is 4.8 diopters. The Raynox 250 is 8 diopters. The Raynox 202 is 25 diopters. The Raynox 505 is 32 diopters. These last two are the strongest close-up lenses I know of. They have very short working distances.
To get a sharp image you need to have the working distance between the maximum and minimum working distance. How wide that is depends on how close the camera lens can focus.
As the power of the close-up lenses goes up, the difference between the maximum and minimum working distance gets smaller. For the Raynox 202 and even more so for the Raynox 505, the difference approaches zero, so you have to be at exactly the right working distance. If you are using manual focus that is not a problem, because whatever kit one is using one typically fine tunes the focus by moving the camera back and forth a little. However, if you want to use autofocus the Raynox 202 and even more so the Raynox 505 can be quite tricky to use out in the field, because autofocus will only engage when you are within the acceptable range of working distance. (I found autofocus worked quite well most of the time with the Raynox 150 and 250, which were the close-up lenses I used most, although how well autofocus works, and indeed whether it works at all, depends on the camera+lens setup. In my case it was better on my Panasonic fixed lens small sensor bridge cameras and micro four thirds cameras than with my Canon APS-C setup. With the first 55-250 lens I got with the Canon autofocus didn't work very well with the Raynox 150 and hardly at all with the Raynox 250. When I swapped that 55-250 for a later model autofocus worked ok with both of them, although not quite as fast or accurate as with the Panasonic setups.)
Rather than using a Raynox 202 or 505, you can get greater magnification than with the Raynox 250 by adding a Raynox 150 (to give a total of 8 + 4.8 = 12.8 diopters, or a second Raynox 250 to give a total of 8 + 8 = 16 diopters. These combinations are a bit easier to use than the more powerful 202 and 505.
You must have done something wrong. A 10mm tube with a 23mm lens should be 0.43x at "infinity". Then add the lens magnification at minimum focus.
To reach 2x at infinity, tubes need to be about twice the focal length of the lens, so you know from the start what's feasible.
