Beeeees... and some of them in flight :-)
Started 11 months ago | Discussions
Yannis1976
Yannis1976 Veteran Member • Posts: 6,309
28
I have been experimenting with the 100-400 to understand its pros and cons with my EM1.3. Subject distance and sun light plays a huge role on the final result, but for some subjects the lens works very good...
The lens is of course softer than my 12-100 but works good for insects due to the longer distance from subject.
Hit ratio is very low with the flying bees, but eventually out of the tens of photos some of them are in focus and can look great!
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Olympus 100-400mm F5.0-6.3 IS Olympus E-M1
Garry Schaefer Veteran Member • Posts: 3,349
Re: Beeeees... and some of them in flight :-)
Good set! I have the Oly 100-400 and an E-M1 mk2 so this should be indicative. I haven't yet had much decent weather to truly try it out during our cool, damp spring. Hoping to catch some birds and BEES in coming months. Thanks for posting these.
Garry
 Garry Schaefer's gear list:Garry Schaefer's gear list
Panasonic Lumix DMC-G3 Olympus OM-D E-M10 Olympus E-M1 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 +8 more
Yannis1976
OP Yannis1976 Veteran Member • Posts: 6,309
For close subjects works pretty good, but the further you get from your subjects, the worse the lens gets. I will post another message with birds from today.
Brian Wadie
Brian Wadie Forum Pro • Posts: 11,017
nice work, one of my favourite subjects which I have been studying and recording for 15+ years
Beware, it can become addictive
The 100-400 makes a nice long range way of shooting these and Pro cap Low is a great tool for recording those bits my reflexes are too slow to get
So much to learn, so little time left to do it!
 Brian Wadie's gear list:Brian Wadie's gear list
Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-45mm F4 Pro +1 more
Yannis1976
Hahaha, I already find it addictive!! And yes Pro cap Low works very good.
However, although I am not using it so much anymore, I still find the Fuji XT3+70-300 a more capable kit for that specific work (insects, bees, butterflies etc). Sensor, CAF and sharpness at 300mm are better...
Brian Wadie
I've not used the Fuji system but have no problems whatever shooting bees, bugs and butterflies behavioural and flight images with the Olympus kit with good enough results to win competitions and have had requests to use my images in various museums and the occasional journal.
Its largely spending a lot of time sitting and watching their behaviour and only when I understand it, picking up the camera
That plus loads of practise (and if I'm honest, loads of luck  )
Lots of examples in my flikr albums
Gary from Seattle Veteran Member • Posts: 7,852
Nice set. I shoot bees pretty often myself. Really good shots are few and far between in a wild setting. But, I find shooting them with a long lens like the 300 F4 to be difficult because of the necessity of maneuvering about. Consequently, I mostly get better shots of them with the 60mm macro. But, only certain bees and even M or F sexes allow close approach. Then too, the bees move rapidly in typically unpredictable directions and they rotate as well when on a flower. So, only on occasion, with their speed and unpredictable motion, does the focus fall where one would like it. But the really good shots are terrific.
Do you think that when farther away you get worse results, or do you think that when distant there is not enough pixel definition?
I don't crop my shots, but just value those with the subject in focus and the distance/composition just right of higher quality.
 Gary from Seattle's gear list:Gary from Seattle's gear list
Olympus E-M1 Olympus E-M1 II Olympus OM-D E-M1X Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 +7 more
nprnncbl Junior Member • Posts: 48
Nice! In flight is particularly challenging.
Are you using MF or AF on those? I find that when I use AF with the Oly 60mm macro (on an EM5), that the focus is unpredictable, and just slow enough that I miss a lot; I typically have better results from MF.
John (nprnncbl)
Yannis1976
CAF with longer lenses than the 60mm macro. Its a fantastic lens, but so far no bee has let me come that close.
Yannis1976
For me the 60mm macro hasn't worked well for moving insects such as bees. No living bee has let come that close to take advantage of the 60mm macro. I prefer the 12-100 (great detail if I reach enough) and then the 100-400 which lacks a bit of detail though at 400mm.
The best kit for this kind of shots though is the Fuji XT3 with the XF70-300. I may not use it too much anymore, but for bees it is great, due to larger sensor, resolution, a bit better CAF and very sharp at 300mm (450mm).
DrHook59
DrHook59 Contributing Member • Posts: 856
Insects in flight, including bees, are one of my favourite subjects. I don't have a long lens that gives good enough definition, so I am stuck with the Oly 60 and the Panny 30. After a year of having both lenses in my bag, I much prefer the Panasonic lens for its much faster AF (I only use S-AF), but the focal length is so short I haveto crop to get any results that please me. I imagine that OM1 users will find their cameras exceptionally successful for flying insects, particularly with a long lens like the 100-400 or 150-400 and the much better tracking implementation. I'm looking forward to being jealous of their future photos
I'm keen on hawk moths and bee-flies where I am; there are some bees but not enough to make them a real target.
_____________________________________
Some of the coolest things in life are really, really small.
https://www.flickr.com/photos/roddyhays/
 DrHook59's gear list:DrHook59's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS Olympus M.Zuiko Digital ED 60mm F2.8 Macro Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +2 more
Yannis1976
Re: I would highly suggest the 12-100 vs the 60 or 30mm
Today I tried both the 12-100 and my Fuji XT3+70-300 kit. Vs the OM 100-400, the level of detail I get from the 12-100 is noticeably better even with highly cropped images. I need to get closer though which is some cases scares the bees, but still I get better images from the 12-100:
Yannis1976
Re: VS the Fuji kit
I believe its a matter of lens, since the results I am getting with the 12-100 match in sharpness the ones I get from the XT3+70-300 (check my other message with the 12-100). Also CAF hit rate with the Fuji is bit better..
Henry Richardson Forum Pro • Posts: 21,959
MIF photographers are a huge market
Cool photos! And not easy to get, I bet.
It reminds me of a few years ago when I called for better MIF (Mosquitos in Flight) support.
MIF photographers ignored again?
https://www.dpreview.com/forums/post/64108105
But what are all the MIF (Mosquitos in Flight) photographers supposed to do? Suck their thumbs?Once again no one cares about them.
Will MIF (Mosquito in Flight) photographers ever get the attention they deserve from these camera companies? Olympus (or JIP) will be missing a golden opportunity if there is no MIF support in the new firmware.
Where's the 600mm f2 for MIF photos?
https://www.dpreview.com/forums/post/56045576
Did Olympus ever make a 4/3 600mm f2 to compete with the Canon 1200mm f5.6? If not then this is definitely an opening for a new m4/3 lens! Oh, Mama!!!!MIF (Mosquitos in Flight) photos are awaiting!
Henry Richardson
http://www.bakubo.com
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,435
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
Brian Wadie
Re: VS the Fuji kit
"I believe its a matter of lens, since the results I am getting with the 12-100 match in sharpness the ones I get from the XT3+70-300 (check my other message with the 12-100). Also CAF hit rate with the Fuji is bit better.."
I agree absolutely about the importance of a good lens to get the best results but as I say, I can make no useful comment re the comparison between systems
One thing I have noticed on going back to using the EM-1 mk3 whilst my OM-1 is out of action, using the EM-1 is a lot harder than using the OM-1 for this subject and my success rate lower (with the same lenses)
I'm already out of practise
Yannis1976
Re: VS the Fuji kit
Yes, I guess the OM1 is game changer in terms of hit ratio.
