Maxxum 800si Aperture issue
Started 10 months ago | Questions
with777 Forum Member • Posts: 79
I have an 800si where the aperture tab/ring inside the camera seems to sit lower than it should, causing the lens to stop down. I can manually adjust it, it's good for a few shots, then it drops again. There is tension in either direction when using my finger so it's not loose.
Is this a common issue among Minolta AF cameras? Can it be fixed? I have no issue opening up the camera but I'll save myself the trouble if it's a lost cause.
Thanks!
MikeInOr
MikeInOr Senior Member • Posts: 1,630
Re: Maxxum 800si Aperture issue
I have a dozen Maxxum cameras, even a couple 800SI's.  I have never heard of this issue before.
 MikeInOr's gear list:MikeInOr's gear list
Sony SLT-A55 Sony a7R IV Sony 20mm F2.8 Sony 100mm F2.8 Macro Sony FE 12-24mm F4 +11 more
OP with777 Forum Member • Posts: 79
Unfortunately, after a lot of searching online, I found out it was a pretty common issue on Minolta cameras with this aperture mechanism. I currently have three that all exhibit the same thing.
I guess consider yourself lucky.
neilt3
neilt3 Veteran Member • Posts: 3,008
With the exception of some of the budget models , I have all the Minolta AF SLR's , both digital ( RD-175 , Dynax 5 & 7 ) and 35mm SLR's , in the case of some , I have several copies . i.e , the Dynax 7 (x3) D9 , D5 , D700si & 600si ( x2 each ) , and for a while every used lens you bought came attached with a 7000AF or 7000i attached , so I've no idea how many of them I have lurking around !
I've been shooting AF Minolta SLR's since the early 90's and have never heard of this as a common problem , all of mine are also fine , so luck has nothing to do with it .
Unless you consider yourself particularly unlucky !
Some models are prone to certain issues , the Dynax 7 film advance and/or ( rarely ) aperture mechanism , certainly sticky rubber of the grip ( cleaned off easily with IPA ) . The Dynax 9 occasionally can have an aperture issue and the solenoid of the 9000AF aperture mechanism is frequently dead .
The hand grip on the 7000i , 8000i and 700si sometimes crumbles away , possibly a reaction to an outside agent ( insect repellent on the owners skin perhaps ? )
But certainly not a general "common issue on Minolta cameras" .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
spacemishka New Member • Posts: 1
I have the same issue.  Were you able to fix IT?
