image stabilization
stevet1 Contributing Member • Posts: 919
image stabilization
It's interesting.
My T8i has in body movie image stabilization, but not still photo image stabilization.
I wonder why.
i got to thinking. I've got a 50mm 1.8 that doesn't have IS. I'm going to have to be real steady, or start using a tripod more.
Steve Thomas
Digirame Forum Pro • Posts: 41,094
Re: image stabilization
As you probably know, some of the lenses have stabilization. All of them that I use have that. On the Canon lenses they will be identified as IS. I never use a tripod, but I do have to remember to avoid shaking the camera/lens even at higher shutter speeds.
Jethro B-UK
Jethro B-UK Senior Member • Posts: 1,654
That sort of IS isn't true IS. It's digital.
If it worked for photos it would crop them.
 Jethro B-UK's gear list:Jethro B-UK's gear list
Canon PowerShot SX410 IS Canon EOS 7D Canon EF 35-80mm f/4.0-5.6 III Canon EF 100-300mm f/4.5-5.6 USM Canon EF-S 18-55mm f/3.5-5.6 IS STM +5 more
tdbmd Senior Member • Posts: 1,365
Just keep your shutter speed fast enough and you will be fine.
 tdbmd's gear list:tdbmd's gear list
Canon EOS 7D Mark II Canon EOS Rebel T8i (EOS 850D) Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF-S 17-55mm f/2.8 IS USM +11 more
You can also use the camera at slow shutter speeds like 1/6th of a second handheld.  If you play around with it, slower shutter speeds than that (without a tripod) are possible if you brace the camera on something like a tree.
Here's an example.
Try it and see.
OP stevet1 Contributing Member • Posts: 919
Dig,
You get an awful lot of nice pictures with that camera and lens combination.
Steve Thomas
