RF-S 18-150
Karen Casebeer
Karen Casebeer Contributing Member • Posts: 872
RF-S 18-150
The new review of the Canon RF-S 18-150 states:  "The RF-S18-150mm lens is a longer-range standard zoom, equivalent to 29-240mm lens coverage on a full frame. While ideal for the new EOS R10 and EOS R7 APS-C sized sensor bodies, these lenses can be used for any R-series camera."
So, if I'm understanding this correctly, I could use this lens on my RP full frame body.  Right?  Are there any ramifications of using this lens on a full frame body?
 Karen Casebeer's gear list:Karen Casebeer's gear list
Canon EOS M50 II Canon EOS R10 Sigma 30mm F1.4 (E/EF-M mounts) Canon EF-M 18-150mm F3.5-6.3 IS STM Canon RF 100-400mm F5.6-8 IS USM
Canon EOS R10 Canon EOS R7
Canon_Guy Regular Member • Posts: 492
Re: RF-S 18-150
Is Your RP an R-series camera? If yes, then you could. If not, then you could not .
FF body will go automatically to its crop mode. Nothing else will happen.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Canon EF 50mm F1.8 STM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art +6 more
Karen Casebeer
OP Karen Casebeer Contributing Member • Posts: 872
Re: RF-S 18-150
Yes, the RP is definitely an R series body.  The smallest one of the group.
PicPocket Veteran Member • Posts: 5,618
Re: RF-S 18-150
The RP will switch to crop mode only using the center 10MP from the sensor. You will see a field of view similar to 28-240mm lens on FF. So if you have the RF 24-240mm you can get similar FOV with full 24MP
 PicPocket's gear list:PicPocket's gear list
Canon EOS R5 Canon EF 24-70mm F2.8L II USM Sigma 135mm F1.8 Art Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +13 more
MAC Forum Pro • Posts: 17,627
Re: RF-S 18-150
the RP is 26 mp
 MAC's gear list:MAC's gear list
Canon EOS 6D Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EF 70-200mm f/2.8L USM +9 more
quiquae Senior Member • Posts: 2,239
Re: RF-S 18-150
the RP is 26 mp
Both of you are correct. 26mp cropped to APS-C size is 26mp / 1.6^2 ~= 10mp. By the same token, an EOS R will let you shoot at 12mp, R6 at 8mp and R5 at 18mp.
 quiquae's gear list:quiquae's gear list
Canon EOS R Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +5 more
Klaus dk
Klaus dk Veteran Member • Posts: 9,155
Re: RF-S 18-150
As others have written, the RP will enter crop mode and give you 10Mp pictures.
A crop EF-S lens would not fit a full frame EF body, so there's a small advantage to mirrorless there.
 Klaus dk's gear list:Klaus dk's gear list
Sony RX100 II Canon EOS R Canon EOS R5 Canon EF 70-300mm f/4-5.6 IS USM Canon EF 16-35mm F4L IS USM +5 more
SteveinLouisville
SteveinLouisville Senior Member • Posts: 1,500
Re: RF-S 18-150
It will be just like using an EF-S lens on an RP, only the RF version won't need an adapter.  The RF version will also use the RF communications protocol with the RP so there may be some incremental improvements in performance.
 SteveinLouisville's gear list:SteveinLouisville's gear list
Canon EOS RP Canon EF 17-40mm f/4.0L USM Canon EF 40mm f/2.8 STM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM +6 more
tkbslc Forum Pro • Posts: 17,358
10MP APS-C
Sounds like it.
Since it is made for a crop sensor camera, the lens cannot cover a Full Frame sensor. So the camera will go into 1.6x crop mode, which only leaves it with 10MP on an RP.   (or 8MP on a R6 or 18MP on an R5)
So the ramification is that you will be shooting with a 1.6x 10MP sensor when you use an RF-S lens.
But, you will get a much smaller and lighter lens than the Full Frame RF 24-240. And for vacation snaps or family outing photos, 10MP might be more than enough.
gimp_dad Senior Member • Posts: 2,611
RF24-105/STM would be better with your RP
Karen Casebeer
Re: 10MP APS-C
Thank you!
