Power Shot Gix Mark III won't take photos
Started 10 months ago | Questions
GB10 New Member • Posts: 4
Hi -- I have a new Canon Power Shot G1X Mark III. I pulled it out of the box today and charged the battery. The batter is fully charged and there is a memory card inserted in the camera. When I press the on/off switch the green light comes on and the lens automatically pulls out of the body of the camera. In other words, the battery appears to be working. But ... nothing else works. There is nothing in the view finder and nothing on the touch screen. Pressing the shutter button does nothing. Pressing the menu button does nothing. The only button that makes anything happen is the on/off button. Any thoughts on what's going on and how to make this work?
Mina J
MOD Mina J Veteran Member • Posts: 5,996
Re: Power Shot Gix Mark III won't take photos
If you haven't already done so, I would remove the battery and memory card and start again. You indicated there was a memory card inserted. Did it come with the camera or did you insert a new memory card? You can also check the manual online. I googled your problem but didn't find anything other than for the camera not coming on at all. If it still doesn't work you should call the dealer you brought it from immediately for a new camera or refund.
Mina
"A photograph is a mirror that remembers"
By Blind Tom 1849-1908
 Mina J's gear list:Mina J's gear list
Sony RX100 III Sony RX10 IV Sony RX100 VII Nikon D300 Nikon D750
YehudaKatz Senior Member • Posts: 2,512
Did you remove the lens cap?
No text.
 YehudaKatz's gear list:YehudaKatz's gear list
Canon EOS 6D Canon EOS M50 Canon EF 24-105mm f/4L IS USM Canon EF-M 22mm f/2 STM
Swerky Contributing Member • Posts: 793
Since pressing the menu button does nothing and pressing the shutter button does nothing, not even a sound, it’s probably a faulty unit. As suggested turn it off and remove the battery and on again and see what happens. Also make sure the SD card is pressed all the way in correctly and stays in place. But no menu probably a bad camera.
No perfect gear out there. Just be happy with what you have and go shoot.
 Swerky's gear list:Swerky's gear list
Canon G1 X III Canon EOS 6D Fujifilm X-A10 Voigtlander 20mm F3.5 Color Skopar SL II Voigtlander 90mm F3.5 APO-Lanthar SL II +1 more
Chris 222 Senior Member • Posts: 1,981
Is this a new cam? If used how old is it?
OP GB10 New Member • Posts: 4
It's brand new. Right out of the box.
Re: Did you remove the lens cap?
Yes. I've tried it with the lens cap off and the lens cap on. Still nothing.
I've tried a different battery and I've reinserted the memory card. Nothing.
As I said, the lens will pop out when I hit the on button, and it will retract back in when I hit the off button, but nothing else is available. I cannot see anything in the viewfinder or on the screen, and none of the buttons work (other than hitting the playback button, which retracts the lens, but does nothing else.)
Okay, since it's new and you have tried a different batt, try a different mem card, just to be sure (I had a similar issue not with my G1X3, but with a Pana cam, many years ago.)
If you still get the same result, I would suggest that you return the cam for a refund or exchange.
Thanks for all of the suggestions. After many attempts to make it work, the camera was obviously flawed, so I sent it back.
Mina J
Thank you for the update.  It is much appreciated.  Sorry it didn't work but glad you're sending it back within the return date.
Mina
Very odd to see this happen with a new G1X3.
Will you let us know what they found once it's repaired?
