Lumix G7 - exclamation !
Started 11 months ago | Questions
redhatcode29 Junior Member • Posts: 48
Hi guys, obtained a G7 as a back up. I changed the frame rates to 30fps and 60fps. When this hack is done, is it common for the wording Lumix to not appear when the camera is turned off ? Instead the exclamation mark appears at every shut down. Is this normal ?
 redhatcode29's gear list:redhatcode29's gear list
Canon EOS 1000D Panasonic Lumix DMC-GF1 Olympus PEN E-P3 Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-G7 +14 more
Jappie52 Regular Member • Posts: 450
Re: Lumix G7 - exclamation !
Usually the exclamation mark means the camera is still in service mode. Did it also appear before the hack? If not, then it's caused by the hack somehow. Check if the camera is operating normally. If it does, then no worries.
pannumon Veteran Member • Posts: 4,130
Yes, this is normal.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
OP redhatcode29 Junior Member • Posts: 48
Ahhh… thats good to hear ! Thanks
Certainly not before. Its a common hack, but i was not sure of the ‘!’   Looks like its normal.
FotogGuy Regular Member • Posts: 221
Exclamation mark is normal for such "hacks". It's a reminder that your camera is still set to service mode.
It will go away if you disable the hack.
I have the same on my G7 which has been hacked for unlimited 4k record. here's a link if yo u haven't done so yet.
https://benonistudio.com/unlimited-4k-mp4-record-time-with-the-panasonic-lumix-g7/
 FotogGuy's gear list:FotogGuy's gear list
Canon PowerShot G5 X Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Canon EOS RP Canon EF 70-200mm f/2.8L USM +30 more
Thanks for the confirmation. Appreciate the link for the unlimited. Will skip it for now as i i dont record long videos - at the moment-  it sure is a cool hack.
I remember the days where i missed so much footage due to the much shorter recording time in the Olympus Ep3. Wasnt a video machine in anyway !
