Am I crazy to want an Inspire 2?
Started May 17, 2022 | Discussions
Boomanbb
Boomanbb Veteran Member • Posts: 3,211
Loving my Air 2s but what is missing is options. Its great if you want to shoot wide angle but what I want is a field of view half as wide which would allow me be be further away and flatten the perspective on photos. I'm in the US so flying a heavy drone is still an option.
Used Inspire packages are available in the 3-5K range and the batteries are still being produced. No way I would be able to buy afford an Inspire 3, assuming it will even be produced.
The Mavic 3 doesn't interest me at all. I have no need to be more "cinematic", I want more "photographic" instead.
Anyone else out there wanting more camera options?
Ben Boozer
Disagree without being disagreeable
 Boomanbb's gear list:Boomanbb's gear list
Canon EOS 7D Canon EOS 7D Mark II Canon EOS M3 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 70-200mm f/2.8L USM +12 more
Antonio Chagin
Antonio Chagin Regular Member • Posts: 159
Re: Am I crazy to want an Inspire 2?
Wow exactly what I've been thinking, just sold a Mavic 2 Pro and got the M# but it is basically the same and too wide the lens. The zoom is very limited.
I didn't get the Inspire 2 because I've heard the newer firmware had problems and it has been discontinued.
So maybe the Inspire 3 which is coming soon, would be an option.
ken_in_nh Senior Member • Posts: 2,399
Considering that the drone cameras have a smart phone camera heritage, I say be patient.  My newest smart phone, a Pixel 6 pro, has a 4x "telephoto" 12 mpixel camera.  Others have similar.
Can you see trickle down in another year or so?
Sagittarius Veteran Member • Posts: 9,104
Mavic 3 has a 12 MP "telefoto" camera.
Best regards
 Sagittarius's gear list:Sagittarius's gear list
Nikon Z6 II Nikon Z7 II Nikon Z9 Nikon Z 14-30mm F4 Nikon Z 85mm F1.8 +4 more
Boomanbb
OP Boomanbb Veteran Member • Posts: 3,211
Unfortunately, it pales in comparison to the X5s camera commonly found on used Inspire 2s and I can use one of 7-8 other lens with it.
https://www.bhphotovideo.com/c/product/1298596-REG/dji_cp_zm_000496_zenmuse_x5s.html/
Ben Boozer
Boomanbb
That is true, but I also expect the cost to go up with each improvement, just like smartphones. Besides, I'm 60 years old. I want to live my best life... now.
Ben Boozer
jackalopemaui Senior Member • Posts: 1,208
Why not a Mavic 2 Zoom? It has 2x optical zoom and is available for about $1000 used
 jackalopemaui's gear list:jackalopemaui's gear list
Sony a7 III Tamron 35mm F2.8 Di III OSD +1 more
blank_ Regular Member • Posts: 488
yes :)
I have exactly the same problem as I would often need a different field of view and longer lens (90mm equivalent would be perfect).
But those bigger drones just suck The whole package is huge, batteries expensive and while no one really cares when you fly air 2s the inspire is a huge beast.. you need to be really careful and need a different license. It sucks from so many reasons
I really wish there was something like air 2s - or interchangeable module to fit there a longer lens in 50-100mm equivalent range with 1" sensor. If mavic 3 was a 24-70mm zoom with 1" I would buy it immediately.
At least there could be a digital solution in Air 2s offering digital 3x zoom with binding multiple shots to increase resolution. I guess it may be worth to try it manually - 10 or 20 shots combined and cropped may help a little bit.
 blank_'s gear list:blank_'s gear list
Sony a7 Canon TS-E 90mm f/2.8 Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony FE 70-200 F4 +1 more
Re: yes :)
What different license?
Best regards
Re: yes :)
in my country - I believe it will be the same in whole EU, everything is quite easy up to 900g drone + you can do all tests etc online. Then it gets complicated in 900-4Kg range and even more so in 4-25Kg. More limitations about where to fly and not so easy tests (I believe not just online) I believe you may have to pay for the license and insurance too (but I'm not sure here)
Ken Seals
Ken Seals Senior Member • Posts: 2,718
Re: yes :)
Then why speculate?
The OP is in the US, easy to find out by clicking his name at the top of the post. Are you completely familiar with the US regulations?
Ken - LR ACE
FAA Remote Pilot Certificate, ATP ASMEL
Mizzou PJ '66
www.kenseals.com
 Ken Seals's gear list:Ken Seals's gear list
Nikon D700 Nikon D850 Nikon Z9 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF +11 more
Boomanbb
Re: yes :)
Ken Seals wrote:
Then why speculate?
Only special license I would be after is my part 107. I’m really hoping an Inspire 3 gets released, should put more inspire 2 models on the used market.
Ben Boozer
The Mavic 3 Pro zoom camera now shoots raw so that along makes a huge difference, maybe you can edit your photos and get good results
Re: yes :)
Boomanbb wrote:
Ken Seals wrote:
Then why speculate?
I still hope, we will get something from DJI or Autel with longer lens and decent sensor under 900g. As long as you stick with iso 100 (which I do all the time with stills) I dont see much difference between 1" and X5S, and with 1" a 3x zoom lens or even better  interchangeable camera modules should be something, that can be done.
I expect Autel to copy the Mavic 3 with its next drone, so lets hope they use something bigger than 1/2" 12 mpix sensor for the long lens.
If you really want the inspire 2  though, I'd just get it. At this moment it is the only choice (unless you go for some custom build drone to carry a small mirrorless) and X5S with some Olympus primes is not  so expensive. DJI uses the TB50 batteries for another products, so lets hope they will not be discontinued with the inspire 2 (as did inspire 1 batteries). Just tell yourself you are saving that money from inflation :))
mmarian
mmarian Senior Member • Posts: 2,145
Re: yes :)
The Inspire 2 is still relevant 6 years after it has been released. To this day it has not real competition. M43 sensor size X5S camera with exchangeable lenses is pretty good or x7 if you want to go all the way. But the x7 is not that great and not much better than x5s for stills. X7 has always been made with mostly video in mind and hence it has got quite strong AA filter which is not that desirable when shooting stills. Anyway if you have your mind set on I2, get it. You won't be disappointed IMHO.
MikeReid
MikeReid Regular Member • Posts: 176
Re: yes :)
I had an Inspire 2, X5S and several lenses.  Took it all over the US and to Iceland.  I've hiked with it strapped to a backpack.  Its an impressive drone with great IQ.  Its not subtle and its not something you can fold up and toss in a bag.  The big deal is not only sensor but the ability to mount 50mm and 90mm lenses for a unique view.  I found that I could get 80% of the IQ using my Autel Evo 2, but I do miss the lenses.  The Mavic 3 is ok, but word is, the quality of the lens involved degrades the Micro 4/3rds advantage.  The XDynamics Evolve 2 looks promising.
Some favorite X5S stills:
Iceland Highlands, DJI 15mm kit lens
Skagit Valley Olympus 45mm lens (90mm)
Mount Baker Dusk Olympus 25mm lens (50mm)
GFX100s and Lenses
 MikeReid's gear list:MikeReid's gear list
Fujifilm GFX 100S Canon EF 200mm f/2L IS USM Canon EF 70-200mm F2.8L IS II USM Carl Zeiss Apo Sonnar T* 2/135 Canon EF 100-400mm F4.5-5.6L IS II +5 more
mmarian
Re: yes :)
Beautiful photos BTW!!
I have to say that I got pretty excited about the Mavic 3. I though to myself if I can get the IQ of I2 sans the lenses in much smaller form factor I might get one. Then I downloaded some DNG files available online and cooled off. The tiny lens in front of M43 sensor kind of kills the advantage of having the camera with large (ish) sensor. The old saying there no such thing as a free lunch is very much true in here. For video I read is great but the stills are not that impressive, IMHO. So, my good old I2 is not going on ebay as yet 🙂
Re: yes :)
great shots. Also thanks for the tip on Evolve 2, despite I wish they used the 20mpix sensor or the new 25mpix Panasonic one, but I understand the video is their main focus.
Lensmate
Lensmate Veteran Member • Posts: 8,310
Re: yes :)
What happened to it?
-M
mmarian
Re: yes :)
I apologize for mucking up my post by placing my photo (taken also with I2 and Oly 12mm lens) on top of the three beautiful Mike Reid's photos, perhaps confusing the unsuspected reader into thinking that it is also his. Just wanted to clarify..
