850D (T8I) OR M50 Mark ii
Started 10 months ago | Questions
yonatan5522 New Member • Posts: 5
I was told the M series is going out of production.
I am undecided and want to buy a camera and on the one hand the M50 is smaller and it has no mirror and on the other hand the 850D has a lot of lenses and there is also a LIVE mode that gives a comparison to the advantage of the mirrorless. The prices of the cameras are the same in my country. What should I take?
Canon EOS M50 (EOS Kiss M) Canon EOS M50 II Canon EOS Rebel T8i (EOS 850D)
nnowak Veteran Member • Posts: 9,074
Re: 850D (T8I) OR M50 Mark ii
Canon DSLRs are also going out of production.  The unknown is when specifically either will become unavailable.  You might have 2 years with either of these systems, or you may only have 2 months.
Do you have any other camera gear, or are you starting from scratch?
OP yonatan5522 New Member • Posts: 5
No I don't have anything,  I had a compact camera and now want to upgrade only for photography and not video's.
Digirame Forum Pro • Posts: 41,839
I thought about that, about different camera models going out of production. But even if that happened those cameras (and corresponding lenses) would be sold in the used market for years and years, possibly for more than five years from now.
I already replied to him on the other forum that I would pick the Canon T8i (850D) camera for stills and the Canon M50 MKII for video. If a person looks at on-line comparisons, there are pluses and minuses for both of them. It would come down to personal preferences. Each person would have their different viewpoint on this. It would be interesting to see what other people say. They are so similar in a lot of ways (in terms of specs), apart from the size & weight and mirror or lack of one etc.
MyM6II Senior Member • Posts: 2,424
By whom? That is only malicious rumors. There will still be M series for a long time to come.
It is more likely that the DSLRs are going out of production.
The 850D can not use the excellent M lenses, while the M50 Mark II can use all EF-M, EFs and EF lenses.
Does size and weight (of body and lenses) mean anything to you ?
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
Andy01 Veteran Member • Posts: 5,188
Who said that the M series WILL be around for a long time to come ?
I think there is probably a 50:50 chance of it going either way. I really doubt that anyone on this forum can say either way with any authority/certainty.
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
tamaraw35 Contributing Member • Posts: 784
There have been no official announcements Canon, from just a bunch of wild speculation. People have been claiming that it will be discontinued "soon" for almost 10 years now since the inception of the line.
We may have more information when Canon makes it's next product announcements on May 24th. Rumor has it that they will announce APS-C bodies using the RF mount which could indicate the start of a transition away from EF-M but we don't know anything for certain yet.
On the other hand, Canon did officially announce at the end of last year that the EOS 1D X iii from 2020 will be their last flagship DSLR. They are moving away from SLRs towards mirrorless although it may take some time before they stop selling SLR products entirely.
The M50 with the official Canon adapter can use every single EF and EF-S lens that the 850D can. The M50 additionally has access to the selection of smaller/light EF-M lenses and you can adapt pretty much any vintage lens that you want.
The M50 itself is a bit smaller, lighter, and you can preview all settings (exposure, white balance, etc.) through the electronic viewfinder. What you see through the viewfinder is the image that you will capture.
The 850D is a bit larger, heavier, and has an optical viewfinder. What you see through the viewfinder is real life (and the results you get may be different). If you want to preview settings, you would need to use the screen on the back. The 850D does have a larger grip and may be more comfortable for some people, especially larger hands. It is also probably more comfortable to use with very large or long lenses. Another advantage is that when you are just using the optical viewfinder with the screen off, battery life can be much longer.
Try to go to a store and see if you can hold them both (or even similar models) to see which is more comfortable for you.
They both have different strengths and weaknesses but will return the same image quality, it's really up to you what works best. For example, if you think you will do a bunch of wildlife photography with long lenses, then the larger gripped 850D with better battery standby may be more practical. But if you think that you will want to do a bunch of landscape photography and carry it around a lot, then the smaller/lighter M50 and EF-M lenses may be more practical.
It may or may not - people have been speculating in these forums for years about that. It seems likely to be around (as in currently sold models) at least as long as Rebel DSLRs, but I may be wrong.
It depends a lot on what you want to do with the cameras (other than the obvious - take photos).
If size & weight is important to you, then the M body is probably the way to go.
If you are planning to use it with larger / longer zoom lenses, then the 850D is probably a better option.
If you are serious about getting RIGHT into photography and value having more buttons & dials to change settings, then the DSLR may be better. Same goes for wanting functions like Bulb, multi-shot AEB (bracketing) etc - 850D might be better.
850D has more features & custom functions etc.
AF is likely to be better in general on M50 ii, especially things like eye tracking, but low light focus overall might be better on 850D. I think it is vertical lines that mirrorless cameras struggle with (I can never remember if it is vertical or horizontal).
The 850D has a significantly stronger flash - only relevant if you plan to use the built-in flash.
While the M50 ii can use all EF and EF-S lenses, an adapter is required, whereas the 850D can use a LOT more lenses natively.
Bear in mind that the 850D (being a Rebel) does NOT have AFMA, so if you get a lens that does not play well with the body (ie. it front or back focuses) it can be annoying/problematic, whereas the mirrorless cameras generally don't have this issue.
The 850D will have significantly better battery life (probably 3-4 times better), so a single spare battery would be OK for 850D, but 2-3 spare batteries would be required for M50 ii.
If you just want a camera with basic zoom for family snaps, holidays etc, then the little M50 ii + EF-M 18-150mm zoom is probably a good place to start, but if you want to get into wildlife/bird/sports photography, then the 850D might be better.
This might be useful;
https://www.the-digital-picture.com/Reviews/Camera-Specifications.aspx?Camera=1484&CameraComp=1523
Colin
R2D2 Forum Pro • Posts: 26,528
If you can do it, skip both of those and go straight to the flagship M6 Mark II.
Here's a good thread detailing its capabilities. (Follow the links I provide in my first post there for more samples)
https://www.dpreview.com/forums/thread/4501836
R2
thunder storm Forum Pro • Posts: 10,139
Between these two I would definitely get the M50.  The M50 can take al the EF and EF-s lenses with the adapter.
You might also want to skip both, and get the RP.
It's hard to give a good advice without any information about what you need it for.
45 is more than enough, but 500.000 isn't
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
KEG
KEG Veteran Member • Posts: 4,909
  1. Marketshare in Japan
  2. Common Sense
Colin
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
trungtran Senior Member • Posts: 1,747
Is it on sale? Get the M50ii, or else just wait until next week's announcement and see what the new R10 is all about.
 trungtran's gear list:trungtran's gear list
Olympus OM-D E-M10 Sony a7 II Canon EOS M6
RLBur
MOD RLBur Veteran Member • Posts: 5,551
The thread is being hijacked by debates/arguments none of which are helpful to the OP.
 RLBur's gear list:RLBur's gear list
Canon PowerShot A640 Canon PowerShot G1 X Canon PowerShot S120 Canon PowerShot G7 X Olympus PEN E-PL1 +10 more
MAC Forum Pro • Posts: 18,487
Hi, the combined lenses and body and accessories can be expensive for both.  What do you like to shoot and what is your budget?  Without other gear, then you can be open to other systems as well.
Provide some more background, and we can better help.
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
Lost99999 Regular Member • Posts: 336
Both are good cameras .. or wait for the new R10
Hi Yonatan, both are good ( first ) cameras and A massive improvement over iphone or similar.
Guess it also depends on which lenses you get with the deal.
I think that if I would prefer a small camera and would not be bothered to develop this into a bigger photo hobby i would go for the M.
the 850 gives the option to add very nice lenses (Canon eos EF ) .. which in 3-6 years from now you could migrate to a new RF body. (That has been my canon history .. adding / upgrading lenses .. upgrading bodies .. but not always at the same time )
You could also wait for the new R10, which will be announced before end May. ( not sure when it will actually sell )
where i live the RP with a kit zoom lens is ~ 250 or 25% higher priced than the 2 options you considered. I guess if you have the cash, would recommend that one ( it will keep also more it’s value, so not that much more ‘expensive’ over the life time .
good luck ! Photography is a nice hobby. Nice pictures of interssting events will be even better memories with nice visuals !
 Lost99999's gear list:Lost99999's gear list
Canon EOS RP Canon EF 200mm f/2.8L II USM Canon RF 24-105mm F4L IS USM Canon RF 50mm F1.8 STM Canon RF 16mm F2.8 STM
PVDL Regular Member • Posts: 122
Re: Both are good cameras .. or wait for the new R10
In your case, a fresh new start, I would not go with the 850D. 850D is a very very good camera, but mirrorless is the future so my advice is to buy the M50ii over the 850D. But in your case, I would choose the new R10, announcement next week. With a RF16, a RF50STM and a RF24-105STM you have everything you need to start with photography.  Don't buy to much or to expensive. If the R10 does not have an electronic viewfinder, I would chose the RP and the same lenses, as the better choice. Price of RP is very good nowadays. If this RP is your first camera, then you can study a few years with this equipment, RP is small but very good, and after a few years you can make new and better choices based on you own experience. You can sell R10 or RP second hand. (Selling 850D will be more difficult in the future, I think.)
 PVDL's gear list:PVDL's gear list
Canon G5 X II Canon EOS 6D Canon EOS RP Canon EOS M50 II
Biertje Regular Member • Posts: 121
I think the first questions that need to be asked are:
What is your budget?
What type of photography are you interested in?
What are your other requirements like small and compact? More ergonomic? Battery life etc
Too many people in these types of threads say you must get this camera and this lens without knowing what the OP's requirements are.
I do agree with the wait until the R10 is announced (potentially in the next few days) to see what that's like.
Just because these systems may be discontinued doesn't mean the second hand market is suddenly going to dry up.
 Biertje's gear list:Biertje's gear list
Canon EOS 90D Canon EOS R7 Canon EF-S 15-85mm f/3.5-5.6 IS USM Tamron SP 70-300mm F4-5.6 Di VC USD Sigma 150-600mm F5-6.3 | C +2 more
UrbanHobbit
UrbanHobbit Contributing Member • Posts: 996
I was in a similar position years ago, thinking about upgrading from compact cameras and smartphones to a “real” camera. I ended up getting a small Canon DSLR with a crop sensor (one of the 100D/Rebel/KISS series, the SL1). As an absolute novice, I was frustrated with how what I saw in the optical viewfinder did always not match what appeared later on the screen. Coming from simpler cameras, and computers, I was accustomed to WYSIWG – What You See Is What You Get. I am embarrassed to say that I stopped shooting.
In 2019 I resolved to really figure this stuff out. I did some research, discovered the exposure triangle, and started hearing about mirrorless systems, and how the electronic viewfinder is always a preview of the eventual photo. I looked around for the Canon mirrorless camera with the most controls, so that I could most easily change aperture, shutter speed, and ISO to see the effects in the EVF. At the time that was the EOS M5, purchased used. My learning curve became much easier. With the 22mm f/2 EF-M, I had a relatively cheap and compact photo-centric package that was convenient enough to take nearly everywhere. That rig could fit into any bag I owned, and the pocket of almost any jacket. With this little photo machine almost always with me, I just had a lot more time to practice. I also purchased an EF-to-EF-M lens mount adapter, which opened up a world of inexpensive used EF and EF-S lenses from Canon’s mature DSLR line. That allowed me to experiment with focal lengths, and I discovered that I am mostly into longer ones. The EF-S 50-250mm is really a gem, and so much value for money. (Those DSLR lenses would have been even easier to mount onto the SL1 years ago, but… no WYSIWYG. So I never even got there.)
Since all that ancient history, Canon has leaned into mirrorless a lot more, so I’m not sure I would recommend the M5 as a first choice. The M50 series has fewer controls, but is more capable for things like 4K video, if you think you might head down that route in the future. But I do think mirrorless cameras are easier to learn than their DSLR equivalents. It’s not a huge gap, but if you want to just get into shooting right away, it’s a gap you wouldn’t have to make up.
And yes, like others have suggested, given the impending announcements from Canon, I would definitely wait a couple of days more before buying anything!
 UrbanHobbit's gear list:UrbanHobbit's gear list
Olympus Stylus 1 Panasonic Lumix DMC-GM5 OM-1 Canon EF 100mm f/2.0 USM Panasonic Lumix G 20mm F1.7 ASPH +15 more
