The diameters of EFM and RF mounts
Started 10 months ago | Polls
lumenite Senior Member • Posts: 1,207
In my opinion, Canon's first decision as to the diameter of EFM mount was a mistake. They must have thought that the mount was good enough against M43 kingdoms or Sony E mount. Moreover they must have not been serious with mirrorless system at the moment since APS-C market has not been their main target. It seems certain that they just wanted to defend the market with the minimum effort. Finally they had to develop another mount, which is RF with 54mm diameter, while the diameter of EFM is 47mm.
Sony E mount is 47mm wide; Leica L, 51mm; Nikon Z 55mm. All of them support both full frame and APS-C sensors. Now RF appears to want to support both as well. At this moment, I think Canon had made another mistake when they released RF. The mount looks too big to be shared with APS C bodies since they have to give up small form factor. Considering Sony's latest lenses, I doubt Canon and Nikon's argument for a bigger mount. Canon must have thought that they would use RF only for fullframe and they needed a totally new, better mount for their future.
Would Canon really have chosen 54mm if they had not had EFM?
Although RF is not good for compact APSC bodies and Canon maybe has to give up EOS M, I think, however, Canon would not be able to avoid using RF for APSC bodies in the end. It is a better mount in terms of technology, and their focus has been always on fullframe market, apart from the inefficiency of keeping two mounts.
What do you think? Which of the following would be the best solution?
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
POLL
separate mounts for APSC and Fullframe like Canon as of today: dedicated mounts!
22.2% 6  votes
one big mount like Nikon Z: just focus on FF since FF is the answer.
37.0% 10  votes
one small mount like Sony E: good enough even for FF and wonderful for APSC.
22.2% 6  votes
one medium sized?
18.5% 5  votes
  Show results
jtstanco Regular Member • Posts: 353
Re: The diameters of EFM and RF mounts
7
The RF mount is the same 54 diameter as the diameter as the EF/EF-S mount which has been used for years on both full frame and APS-C cameras.  Canon did not increase the diameter of their mount when coming up with the RF mount.
Nikon increased mount diameter to 55 mm for the Z mount from the F mount's 44 mm.  This mount has a slightly larger diameter that the Canon RF mount.  As you pointed out, Nikon already uses the Z mount for both full frame and APS-C.
 jtstanco's gear list:jtstanco's gear list
Canon EOS 70D
OP lumenite Senior Member • Posts: 1,207
So true. I missed the point. Thank you for your reminder. On the other hand, the mirrorless systems can reduce the body size thanks to the short flange distance, while there was no big difference between DSLR FF and Cropped bodies in terms of their sizes. The compactness was one of the main features of M4/3 mirrorless system and what Sony is still pursuing, I believe.
MyM6II Senior Member • Posts: 2,424
medium format sized ????? Omg
How large is that mount ?
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
Oh, my bad. sorry for the confusion. I believe you know what I really mean.
BirdShooter7 Veteran Member • Posts: 9,127
This is where I think you went off the rails
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
Icagel Forum Member • Posts: 70
The best solution is to make somehow 2mm M to R adapter. Or possibility to change m mounts  bayonete to R... 😃
 Icagel's gear list:Icagel's gear list
Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon 70-300 F4-5.6 IS II +3 more
The EF-M mount would have worked just fine. (IMHO)
R2D2 Forum Pro • Posts: 26,528
Mistake? You mis-read Asian corporate culture methinks. A smaller M-Mount was part of their plan all along. They think in the Loooong term.
Myself, I can certainly see Canon's logic. Why sell just one lens line when you can sell two! Or threee! It's brilliant!
Absolutely.
This is exactly right. Plus it's been super-popular to boot!
The RF mount much better accommodates Full Frame Mirrorless. It was a natural progression.
Except Canon and Nikon now aren't locked into an inferior mount. They have that big wide throat to work with.
So? It costs them next to nothing to develop a couple of cheapo RF-S lenses. As some have mentioned, they could even basically re-run a couple of EF-M designs with a new mount!
Not me. I've been shooting with Canon RF for almost 2 years now, and it's magnificent.
Thus EOS-M! It was viable back with EF, and it's still viable with RF on the scene. I'm living proof! Vive le 'M!! Vive le 'M!!
Again, it can be used for both FF and crop. Just like EF was. For minimal expenditure.
Certainly.  It allows for improved lens designs!
Canon might (might!) give up on EOS-M, but we don't have to.
Right. Why develop another APS-C mount when it's not needed.
EOS-M is operating all in The Black for Canon. Even an M6 Mark III "firmware upgrade" would cost them next to nothing.
The best solution depends on what you're shooting, and how.  IMHO it's great to have a number of excellent choices...  Rather than the other way around.
R2
nnowak Veteran Member • Posts: 9,074
Yes, Japanese companies tend to take a very long term outlook, but there are clear mistakes in the design of the EF-M mount that suggest that Canon did not anticipate a future with professional level full frame mirrorless.  Making the mount just a couple millimeters larger would have allowed EF-M to fit a full frame sensor.  If EF-M and RF flange distances were changed by only a couple millimeter, adapting RF lenses to M bodies would have been possible.
Why sell three lens lines when you can sell a single lens line three times.  Having multiple lens lines is a lot more challenging when your sales volume gets cut in half over just three years.
Absolutely.
It is still outsold by the EF mount.
It definitely makes it easier, but Sony seems to be coping just fine.
Let me know when you can mount a RF lens on a M system body.
It is also the same diameter as the old EF mount.
The same could also be said for the entire EF-S lineup of bodies and lenses.
Great for the consumer, but not so great for manufacturing efficiency and Canon's bottom line.
It has been working wonderfully even for me.
It will turn out to be a mistake if Canon really ditches the mount any time soon, although it will have lasted longer than Nikon 1.
That's one of the things that I do not understand regarding Canon's strategy about APS-C system. Why do they not put more money to APS-C when they are still the number one in Camera industry? Just a little more lenses and bodies for APSC would have been great.
Absolutely.
Yes. I won't give up until my things die since I do not know how to sell all of them and restart all things from the scratch.
R2
Thank you for your interactive reaction!
casus Regular Member • Posts: 148
I certainly agree with that. Buying M6II I wasn't intending to upgrade to FF at all. I upgraded from 300D to 5D M III in the past and I don't see "one mount fits all" as a real value.
Here in Europe I don't see Canon as a market leader. I see more Sony/Nikon on display. Visiting some electronic store like Mediamarkt I always wonder why according to some reports Canon is the leader of photo equipment, it doesn't look so.
Urs, Casus.
 casus's gear list:casus's gear list
Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Sigma 16mm F1.4 DC DN (E/EF-M mounts) Canon EF-M 32mm F1.4 +1 more
thunder storm Forum Pro • Posts: 10,139
Even beside the size of the eos-M mount there's more evidence this is the real mistake of Canon.  Canon should have launched the R6 and R5 before at the same time as the launch A7III.  Even the R was significantly later launched as the A7III, and as the first model of the RF line this is clearly a product of a company not thinking forward enough.
Right now Canon is on par as it comes to sensor tech.  The big question is if Canon can follow Sony if it's doing a next round sensor upgrades.  Is the Canon tax we pay enough to finance new sensor fabs? Or will Canon lay back again leaving the owners of RF L glass without sensor upgrades?  Beware of doing "investments".  "Investments" might give ROI for the next 5 or even 3 years only if you love the best sensor tech.
Comparing the FE 50mm f/1.2 G-master to the RF 50mm f/1.2 L the bigger RF mount doesn't give an advantage for optical designs of lenses. I'm not sure if a bit better IBIS is enough to justify the size of the RF mount.  So I would argue the M mount probably isn't too small, I would rather argue the R mount was both too late to the show AND too big. With the RF mount you can't make a camera more compact than the A7C. With the FE mount you can. It's not only the weakness of the M mount (being too small for full frame)  forcing Canon to create the RF mount, it's also the weakness of the RF mount (being too big) to make truly compact cameras forcing Canon to sustain the M mount.
There's a lot of speculation of discontinuation of the M mount. At the end of the day the M50II and the M200 are at least available. Go try to by an A6100 or A6400.  It's nice when a mount is shared with full frame so we all should assume aps-c would last forever in the Sony world, however, if you can't buy it these kind of eternities won't bring you much.....
45 is more than enough, but 500.000 isn't
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
The M occupies a niche that cannot, will not, (not in anyone's wildest dreams!) be filled by a crop RF body.  ...and to your point it is the diameter of the EF-M mount that actually guarantees this!
Canon first and foremost protects their own higher level camera lines.  It's built into their corporate identity!
Absolutely.
Me too!  Me too!
R2
Nothing like a little competition to spark discussion!
R2
You're describing what would sound good to us, and not what would work best for Canon's bottom line.
That's complete babble.  I've used my (same) EF 85mm f/1.8 on every body line so far.  I did not buy it threee times.
Sales volume is determined by the products you make available.  Just ask Coke or Pepsi, or Tide for that matter.
Absolutely.
And the EF mount is dead.
Sony was the first to "cook" their corners.  It's become ingrained in their design now.  Canon and Nikon now do the same, but to better effect (IMHO).
Don't have any desire to.  I love my EF-M lenses.  All of them.
And I love my RF lenses on my R bodies.  (actually proves my point)
EF is dead.
They're all dead too.  And sooner than EF-M.
Actually my argument is that it's good for both!  Horizontal market saturation!  Squeeze everybody else off the shelf!  Works.
R2
Absolutely.
Me too! Me too!
R2
R2
I have some serious doubts about this. Time will tell.
I just don't see Canon replicating my beloved M6 Mark II form factor with the R10.  No way, no how.
The R10 will be bigger, have a built-in EVF, be bigger, have an articulating LCD instead of a tilting one, be bigger, won't be specced nearly as well as the M6ii, and be bigger.
End of story!
Vive Le M!
R2
And why would they?
Those are all features on cameras that consistently outsell the M6 II.
End of story!
Vive Le M!
R2
Your love of the M6 II does not change market realities.
