What size filters would you get for an RF kit?
Started 10 months ago | Polls
Texchappy Contributing Member • Posts: 598
If you were buying filters (ND, circular polarizer, etc) for your RF lenses, what  size filter thread would you get? Especially considering future lens purchases?
 Texchappy's gear list:Texchappy's gear list
Fujifilm X100F Fujifilm X-Pro1 Canon EOS Rebel T4i Canon EOS R6 Fujifilm XF 18mm F2 R +10 more
POLL
77mm (for 24-105L, both 70-200s, 14-35, 100-500, 50/1.2)
77.8% 7  votes
82mm (for 15-35, 24-70, 85/1.2, 600/11)
22.2% 2  votes
95mm (for 800/11, 28-70)
0.0% 0  votes
  Show results
JustUs7 Senior Member • Posts: 4,327
Re: What size filters would you get for an RF kit?
100mm square with a set of adapters.
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
BBR5 Regular Member • Posts: 212
Would seem to depend on your lens plans.  Most L series lenses except for the super teles are 77mm or 82mm.  Filter sizes for the non-L lenses are all over the place.
SteveinLouisville
SteveinLouisville Senior Member • Posts: 1,586
If you get one large size, usually you can find a reducer that will work with smaller size lenses.
 SteveinLouisville's gear list:SteveinLouisville's gear list
Canon EOS RP Canon EOS R7 Canon EF 17-40mm f/4.0L USM Canon EF 40mm f/2.8 STM Canon EF-S 24mm F2.8 STM +9 more
Karl_Guttag Senior Member • Posts: 1,883
This question is highly dependent on the way you use your equipment and budget. If you are really going to buy the high-end L lenses the budget should not be that big an issue.
You might get better advice if you laid out what you are likely to buy and use and how much use the various filters.
Polarizing filters are a bit of a special case. How much do you use a circular polarizer? Generally, I would not use a circular polarizer or variable neutral density filter (top-notch ones have less of an X problem) with a very wide-angle lens (aka 14/15 to 35mm).
You could certainly go with the 82mm and then get a step-down ring for filters you might use but then they don't work with lens hoods (you can get an extra lens cap that would fit). I would only go with the step-down ring approach for filters you would rarely use but might want to use occasionally.
Personally, I mostly use ND filters for the purpose of using a slow shutter speed and I use fixed ones to avoid problems with polarization effects. I thought I could use a step-down ring but then decided the inability to use the hoods with them was too big a drawback.
 Karl_Guttag's gear list:Karl_Guttag's gear list
Canon EOS R5 Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 24-240mm F4-6.3 +14 more
PhotoKhan Forum Pro • Posts: 11,930
Irrelevant.
Buy this, with adapters for all 3 sizes.
https://en.nisioptics.com/
You will not regret it.
PK
“Loose praise may feed my ego but constructive criticism advances my skills”
https://www.instagram.com/lisboa_ao_voo_do_passaro/
http://www.humbertoborgesfotografia.com/
http://www.pbase.com/photokhan
(PBase Supporter)
Franz Kerschbaum
Franz Kerschbaum Senior Member • Posts: 1,242
I started with 82mm ones but then I also bought the 77mm version since it makes life so
much easier not having to use a step ring and have problems with the sunshade. With my L Lenses filter cost is not a deciding factor.
 Franz Kerschbaum's gear list:Franz Kerschbaum's gear list
Canon EOS 5D Mark II Canon EOS 7D Mark II Canon EOS M6 Canon EOS Ra Canon EOS R5 +30 more
Mark B.
Mark B. Forum Pro • Posts: 29,742
I would get whatever filter or filters I want to fit the lens or lenses I'm using.  I don't use step-up filter adapters, and I'm not a fan of the square filter holder systems as that negates use of the lens hood.
robgendreau Forum Pro • Posts: 10,917
I wouldn't bother with lens filters, except maybe for the CPL.
I'd get clip filters. Since behind the lens means they fit on everything. And none of the normal issues with lens filters, from getting stuck to flares to messing with step up rings.
I use a couple different ones behind my RF lenses and love it.
I use Kolari ones. Their ND are particularly free of color cast, and it's especially important to me because I shoot IR. Not everyone is as picky. Great filters.
But STC makes some, and I think Kase does now as well.
I've still got tons of lens filters, but I sure wish I'd started out with clips instead so I didn't have so many.
https://kolarivision.com/product-category/lens-filters/rear-filters-lens-filters/
https://usa.stcoptics.com/collections/clip-filters
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
OP Texchappy Contributing Member • Posts: 598
Interesting. I have never seen anything like that.
davidwien Contributing Member • Posts: 572
I buy filters to fit each lens that I have, Of my five RF lenses, only two take the same size anyway: 50mm and 16mm. I keep a UV filter on at all times to protect the lens. I consider this cheap insurance. I also use the circular polarizers, so find it economic to buy one of these kits.
David
 davidwien's gear list:davidwien's gear list
Sony RX100 VA Canon EOS RP Canon EOS R6 Canon EF 17-40mm f/4.0L USM Canon EF 70-300mm f/4-5.6 IS USM +6 more
redli0nswift Forum Member • Posts: 91
I am not a professional but I decided on two sets.
58mm UV, 3 stop, and 6 stop fits the nifty 50mm f.8 and 35mm f1.8 with step up rings.
82mm UV, 3 stop and 6 stop for my 15-35mm f2.8 and later the 50mm f1.2 when funds allow
I am not doing video, so I opted not to buy a circular polarizer.
 redli0nswift's gear list:redli0nswift's gear list
Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 15-35mm F2.8L IS USM Canon RF 50mm F1.8 STM
drsnoopy Senior Member • Posts: 1,216
Surely it depends on the lenses you have, or intend to buy.  Many of the L lenses are 77mm, so that’s a good choice, and you can use a step down ring to adapt to 67mm for example.  If you are looking for slide-in 100mm filters (eg Lee or NISI neutral density), you buy one holder and the necessary adapter rings.
For protection filters, if you use them, you would buy one for each lens, in the correct size.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Mark B.
Your last comment is interesting.  CP is very useful for a lot of still photography.
Distinctly Average Senior Member • Posts: 2,527
Re: Irrelevant.
PK
I have the V5. I got it mainly due to the massive vignette I was getting on my EF-S10-22 years back when using a polariser on the Lee system. That mounted with a 105mm CPL on a front ring. I moved to Nisi mount and CPL and it was superb. The CPL works perfectly with nice clean corners on the 10-22 and also with FF at 16mm. Bit fiddly at times but all things I have seen are Improved With the V6 and now V7. I have a mixture of brands of filter including a couple of Lee grads, a 10 stop and a 6 stop from nisi and a starglow filter from someone who I forget right now. All work well on the V5. So I agree, great system to have in your bag. I would upgrade to V7 but there is zero wear on the V5 so will wait until it becomes loose or I loose it.
Re: Irrelevant.
PK
I have the V6. Love it.
Even my biggest fear, that my clumsiness would go broken glass in an expensive way, has not materialized, so...
PK
(PBase Supporter)
Re: Irrelevant.
PK
PK
And tomorrow’s PhotoKhan thread “How much does it cost to have bits of filter removed from my front element”
enemy14123 Junior Member • Posts: 26
Re: Irrelevant.
I Use the also the Nisi V7 Kit with 8 Filters for my 14-35 and my 24-70
AND I LOVE IT!
KariP
KariP Veteran Member • Posts: 6,450
77mm because
I use protective filters on all my lenses - 14-35 + RF24-105L + 70-200Lf4. If something happens there is always a spare part in the bag (filter) and same pol filter is usable on all of them.
To me the 77mm size matters
Kari
I started SLR film photography in 1968. Now two systems: Fujifilm X-H1 + X-E3 and Canon FF gear 5dMkIV + R6
 KariP's gear list:KariP's gear list
Canon EOS 5D Mark IV Fujifilm X-E3 Fujifilm X-H1 Canon EOS R6 Canon EF 50mm F1.4 USM +13 more
