Canon Cine primes and R5/c
Started 10 months ago | Discussions
Chris1X4 New Member • Posts: 19
I recently inquired via B&H and a local Canon rep about using Canon Cine primes on my R5c. Apparently they are not compatible with the Canon EF to R adapter. (I don't really trust either source...)
Is there a way to use Cine primes with an R mount camera (specifically the R5c)?
And I wonder what "incompatible" means. Clearly they'll mount via the adapter, so is it an issue with the electronics?
Canon EOS R5 C
cortex95x Contributing Member • Posts: 862
Re: Canon Cine primes and R5/c
The PL mount primes are obviously not compatible, and the EF mount Canon Cine lenses will not have any electronic contacts, but I would guess that they should work in full manual.  I have a set of Meike EF mount primes for my Canon C300 Mk III that I will try on my R5c via adapter.  But I'll be honest, unless you're working from a tripod, or have access to a focus puller, a fully manual lens for video is a PIA to use. But that's just my opinion.
