drj3
Re: GH6 vs OM1 for Stills Only - Also, Synergy of Panasonic with Own Lenses
glassoholic wrote:
drj3 wrote:
victorav wrote:
tammons wrote:
abe4652 wrote:
Two questions:
1) If you are virtually only a stills shooter, does the GH6 make sense over an OM1?
2) Is there a synergy between Panasonic cameras (such as GH6) and older Panasonic lenses, like the 100-400?
Thanks.
Doesnt the Om1 have cleaner high iso files?
Not really. In camera noise reduction is good for jpegs, raw performance is about the same as previous 20mp sensors.
There has been some debate on high iso of the GH6 but GH6 seems pretty good to me.
Why would you get the GH6 instead of the GH5.2, if you are not interested in its advanced video capability?
DPR's initial evaluation for stills on the GH6 compared to the OM1 (the full review is not completed so there may be changes)
Our Exposure Latitude test delves into the deep shadows of base ISO images to test the degree to which you can underexpose to protect highlights, then exploit the camera's full dynamic range. The GH6 is showing significantly more noise when given the same exposure as the OM-1. In principle this represents deeper shadows because of the difference in their respective base ISOs, but the difference is pronounced enough that you can comfortably conclude that the GH6 has less usable dynamic range than the OM-1.
The ISO invariance tells a similar story: above ISO 800, where the GH6's Dual Output Gain system kicks in, the two camera look very similar, but push the lower ISOs and the Panasonic shows increasing noise levels in the very deep shadows.
What if the next update to DXO PL5 Elite to make it compatible for the GH6, cleans up the low ISO shadow noise very well, and retails sharpness? Would the GH6 then be a good photographers camera, including for landscapes?
I don't think it is bad now, but possibly not quite as good for stills as the OM1 when noise is an issue. If the noise was primarily a high ISO problem, then I think it would be less of a problem for stills (but maybe a greater one for video). While we will have to wait and see what the full reviews indicate, it appears to have a lower dynamic range at ISOs below 800 than other mFTs cameras.
I did not intend for my post to imply that this would be a very serious issue. My post was actually only to clarify the statement " raw performance is about the same as previous 20mp sensors" which appears to be incorrect.
From what I have read from Interceptors posts, I would think the GH5.2 would be a much better choice for stills than the GH6 for one who wanted to maximize performance with Panasonic lenses.
If the OP had asked GH5.2 vs OM1, then I probably would have posted, pick the one which has the features you need for your photography.
