15-45mm + 55-200m Or 18-150mm for m50 mark ii
Started 10 months ago | Questions
yonatan5522 New Member • Posts: 5
Hi, I have 2 options:
1. 15-45mm + 55-200m
2. 18-150mm
I want to photograph landscapes, people, cars, and planes.
what should I get?
or maybe should I buy a different camera (250D/850D)
nnowak Veteran Member • Posts: 9,074
Re: 15-45mm + 55-200m Or 18-150mm for m50 mark ii
13
2. 18-150mm
what should I get?
Definitely the 18-150mm kit.  If you need a wider view for things like landscapes, the EF-M 11-22mm is a much better lens than the 15-45mm.  For telephoto reach, the adapted EF-S 55-250mm STM is optically better than the EF-M 55-200mm while also providing more reach.
Maxmolly7
Maxmolly7 Senior Member • Posts: 1,481
2. 18-150mm
what should I get?
Due to sample variation of the 15-45 lens, the 18-150 will likely produce better IQ.
The 55-200mm is said to be medocre, the EF-S 55-250MM STM IS needs the m-adapter but is light and sharp at all settings, even wide open.
For planes you may need focal length > 300mm.
May THE LIGHT be with you!
 Maxmolly7's gear list:Maxmolly7's gear list
Sony RX10 IV Sony RX100 VII Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +16 more
MyM6II Senior Member • Posts: 2,424
2. 18-150mm
what should I get?
15-45mm + 55-200m no doubt ! (for your use cases)
15-45mm is much better in the 15-18mm range and 55-200 is much better in the 150-200mm range.
Seriously; 15mm is important for landscapes. And 200mm is important for planes.
The 18-150 is also a very good lens, but is a bit large and heavy (IMO) for a walkaround lens and it starts a bit narrow. The 15-45 is very small and light and very good stopped down a little. They both have copy variations, so check the lens when you receive it.
EF-M 15-45 @ 15mm
EF-M 15-45 @ 15mm
EF-M 15-45 @ 45mm
The 55-200mm is a very good lens. It slightly beats the larger EFs 55-250 STM in image quality. It is obviously missing the 200-250 range, but is much more compact and much lighter and does not need an adapter.
EF-M 55-200mm @200mm (Cropped a little )
There is a good review of the 55-200mm by Dustin Abbott here. He also compares it to the Efs 55-250 STM.
Here is what he says about the pros for each lens when he compares them:
EF-M 55-200mm STM
  • Significant size advantage
  • Construction and handling are superior
  • Better overall image quality
  • Better balance on EOS M/M2/M3
  • Greater portability (retains the compact nature of the mirrorless system)
EF-S 55-250 STM
  • Price advantage (if you own the EF adapter)
  • Longer focal range
  • About 1/3rd stop aperture advantage at all focal lengths
  • Can be used on EF-S mount cameras as well.
  • Better minimum focus distance and maximum magnification
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
Attila75 New Member • Posts: 23
Did you check Tamron 18-200mm iii eos m?
 Attila75's gear list:Attila75's gear list
Canon EOS M50 II Canon EF 85mm F1.8 USM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 18-150mm F3.5-6.3 IS STM +1 more
I think he is trying to decide what m50 II kit to buy. An that’s why he has got only two options.
Maxmolly7
I had the Tamron and compared it side by side to Canon 18-150mm. The latter has better IQ at all focal lengths and is smaller and lighter. IS and AF seems more efficient, too that's why I sold the Tamron after 4 happy years of usage.
Fjzk Regular Member • Posts: 220
If you don’t mind a bulkier combo the 70-300 USM II will give you 480mm reach in the M50 and (an important consideration right now) can also be used in any future R cameras you may buy (crop or FF). I have it and use in both my M50 and the RP with great results.
In that option you could buy the kit with the 15-45 only and add a longer reach telephoto separately.
 Fjzk's gear list:Fjzk's gear list
Canon EOS M50 Canon EOS RP Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +8 more
Larry Rexley Senior Member • Posts: 1,238
2. 18-150mm
what should I get?
You've already gotten lots of good advice in previous responses. Everyone has their own shooting style and way of using lenses. Either set can work for you, both have different advantages.
I have to agree with those who say getting a good copy of the kit 15-45mm lens is a crap shoot. There are a few good copies out there, but most seem to be sharp in the center and noticeably blurry or slightly 'smeared' in the corners even at f5.6 or f8 which would be noticeable in landscape shots. I've had 3 middle-of-the-road copies of the lens that were like that, and my most recent fourth copy had a soft left edge, I sent it back for replacement under warranty service and should get the new one this coming week.
if you manage to get a very good copy, the 55-200 is apparently quite a good lens and does not seem to suffer copy variation. Consensus seems to be the optical quality is not very different from the EF-S 55-250mm, with each lens having some advantage (small size and weight for the EF-M vs. longer reach and slightly wider aperture for the EF-S).
For me, given the choice of 15-45 + 55-200 vs 18-150, I'd choose the 18-150 in a heartbeat. It's a great walkaround lens, is quite sharp for landscapes all around at 18mm by f5, and having such a large range you don't end up swapping lenses often. When I'd shoot with the 15-45mm and EF-S 55-250mm with one body, I ended up changing lenses very frequently to shoot various subjects, and it became quite annoying with a lot of lost shots.
As others have mentioned, the EF-M 11-22mm is a fantastic quality wide-angle zoom for the price and is the best Canon EF-M landscape lens. It's very sharp at all focal lengths and apertures. If you're on a tight budget and want a great wide-angle landscape lens, and don't mind manual focus, the Rokinon 12mm f2 is even sharper than the Canon EF-M 11-22mm with great color rendition, and is sharp even at f2. being such a fast lens it also makes a great indoor, night photography, and astro lens. It has become one of my favorite EF-M lenses. Focusing isn't much of an issue, I've found for most outdoor shots I can just set it at a parfocal distance on the lens and just forget about focusing. You can find it used under $200.
I agree with others that even 250mm is going to be short for airplanes. I've modified an EF-S 55-250mm IS STM lens to work on EF (instead of only EF-S) teleconverters, and use it with good 1.5x and 2x teleconverters to give it the kind of reach you need for shooting planes and birds in flight.
To go out and shoot the subjects you mention for the 'cheapest' set of lenses from my collection, I'd bring the Rokinon 12mm f2, Canon EF-M 18-150mm, and EF-S 55-250mm with 1.5 TC (making it an (88-375mm f5.6-f8 lens).
 Larry Rexley's gear list:Larry Rexley's gear list
Canon EOS M6 II Canon EOS M200 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +21 more
KoolKool Regular Member • Posts: 263
11-22 and 55-200, i personally recommend this pair.
and don't worry, changing lenses is actually just wasted of your lifetime 3-4 seconds if you are skilled enough.
18-150 is okay, but sometime i wish the wide end and be...wider, 15 or 16 is better.
palombian Contributing Member • Posts: 637
2. 18-150mm
what should I get?
My 55-200 was really good.
Unfortunately I lost it in the field (these things are so small).
But switching lenses is not for these kind of cameras, so if (and if ?) I would continue with M I would choose the 18-150 (BTW the 11-22 is very good).
 palombian's gear list:palombian's gear list
Canon EOS 7D Canon EOS M6 Canon EOS M100 Canon EOS M6 II Canon EOS R5 +25 more
YehudaKatz Senior Member • Posts: 2,512
Without any question I would take the 18-150.
No text.
 YehudaKatz's gear list:YehudaKatz's gear list
Canon EOS 6D Canon EOS M50 Canon EF 24-105mm f/4L IS USM Canon EF-M 22mm f/2 STM
Alexis
Alexis Senior Member • Posts: 1,998
My experience with both these 2 lenses has been very positive and I have loads of examples to share if you need to see the capabilities of these lenses using both the M50 and M50 Mkii
Having said that, some people are reporting variation in quality between copies of these lenses so maybe I was just lucky - the 18-150 is not wide enough or long enough for me and the EF-S 55-250 is too heavy and bulky and you need an adaptor to use it. What is the point in investing in the lighter, smaller EF-M format is you're going to be using EF-S glass. Just my €2 worth!
 Alexis's gear list:Alexis's gear list
Canon EOS 50D Canon EOS M50 II GoPro Hero9 Black Sigma 17-50mm F2.8 EX DC OS HSM Canon EF-M 11-22mm f/4-5.6 IS STM +12 more
dan the man p Senior Member • Posts: 1,201
I would do the 18-150 option simply because it is highly regarded, and most copies of the 15-45 are not worth buying intentionally.
 dan the man p's gear list:dan the man p's gear list
Sony DSC-RX0 Nikon Z6 Nikon Z 24-70mm F4 Nikon Z 40mm F2
Agree. I just got my 5th copy of the kit EF-M 15-45mm IS STM. Finally on the 5th copy I have one that is about as sharp as the EF-M 18-150 IS STM I have. It's a crap shoot.
Here is a post with some samples:
https://www.dpreview.com/forums/thread/4644778#forum-post-66173221
Lost99999 Regular Member • Posts: 336
Before the end of May Canon will announce new cameras
You might want to wait for that !
Rumors also mention new lenses in exactly your area of consideration.
( personally i find 15-45 on APSC a no go : it not wide enough for landscapes or many indoor pictures, and 45 is a very poor zoom for sport, catching a detail, etc )
 Lost99999's gear list:Lost99999's gear list
Canon EOS RP Canon EF 200mm f/2.8L II USM Canon RF 24-105mm F4L IS USM Canon RF 50mm F1.8 STM Canon RF 16mm F2.8 STM
2. 18-150mm
what should I get?
Since writing my original answer (above) I've been fortunate enough to get a decent copy of the kit EF-M 15-45mm lens (fifth time's a charm) and also I have for the first time gotten the EF-M 55-200 IS STM lens.
My latest copy of the EF-M 15-45 lens is just as sharp as the copy of the EF-M 18-150 lens in the relevant range. Here's a post with some sample images:
https://www.dpreview.com/forums/post/66199406
My testing of the EF-M 55-200 lens shows that it is quite a bit better optically than the EF-M 18-150 lens in the telephoto range, in fact it appears to be optically even slightly superior to the EF-S 55-250mm IS STM lens (although not by much). Here's my post on that with some sample images:
https://www.dpreview.com/forums/post/66243584
So if I were to answer the OP's original question again now, I'd say that it's a tough choice. The 18-150mm is a great walkaround lens and can cover most subjects... but
If you don't mind changing lenses, can get a good copy of the EF-M 15-45 kit lens, and shoot with it and the EF-M 55-200 - you're going to have a greater range both at the wide end and tele end, and are going to get better images at the telephoto end, and probably at least as good images at the wide end. If you don't get 'wider' lens like the EF-M 11-22 IS STM, that 'extra' wide angle of the 15mm lens is very useful.
