Questions about R5 and moire
Started May 13, 2022 | Discussions
David Franklin Senior Member • Posts: 1,776
I am a very long time pro photographer and user of many different high end digital cameras but, I have used Canon DSLR's and mirrorless models for quite some time now. My main camera is now an R5. I am extremely happy with it in almost every way possible.
One thing that I have always noted about Canon digital cameras in the past is that their output was tempered by a very practical consideration for making sure that there was always - except for the 5Dsr - a very effective anti-moire filter in front of the sensor. It may have sometimes limited the appearance of sharpness of output in some cases, but it was more than made up for in being able to have confidence that moire would not ruin some important pictures. The filters didn't eliminate moire, but they sure did make it exceedingly rare.
Now to the meat of the matter. Last week, I shot a family portrait job. It was certainly not an easy one to do, because of the limitations of time, location and lighting conditions, but I overcame those issues in general with good flash lighting techniques in a difficult outdoor environment. I would prefer not to show the pictures, because my client has not even got their pictures yet, much less given me permission to show them here.
In this shoot, I got the most and worst moire I ever got in any shoot I've ever done, due to my clients' clothing. They did wear the exact patterns that I specifically warned them not to wear when I arranged the shoot - small regular, repeating patterns in the material, but this has happened before, using other cameras, with no where near the amount and frequency of the instances of moire in this set of pictures, appearing as both large monochromatic false swirling patterns and as those same false swirls with multicolor bands as well - all the typical false patterns of moire one could expect. It was a processing disaster, as I've had to use incredibly time consuming work-arounds to partially or wholly correct those afflicted pictures.
So, here's my question to the rest of you Canon R5 owners out there: have you noticed more moire in your results than with previous Canon cameras? Does anyone know if the anti-moire filter in the R5 is weaker than in previous Canon cameras? Any information specifically about this would be welcome. And, finally, is this is a problem specific to R5, or is it just a run of bad luck, where all the elements of the shoot came together to produce this woeful outcome, and will not likely occur again, or at least not any more than would happen with any another camera?
Finally, besides using the Lightroom anti-moire tool and bringing the sliders down on the Clarity and Sharpness controls, is there anything else which is even better at fighting moire, with less image softening, in post?
Well, now it's back to the horrible task of completing my post work on that same family portrait job.
Keep learning; share knowledge; think seriously about outcomes; seek wisdom.
 David Franklin's gear list:David Franklin's gear list
Canon EOS R Canon EOS R5 Canon TS-E 17mm f/4L Canon TS-E 90mm f/2.8 Sigma 8mm F3.5 EX DG Circular Fisheye +7 more
Canon EOS 5DS R Canon EOS R5
OP David Franklin Senior Member • Posts: 1,776
Re: Questions about R5 and moire
Anyone?
Croomrider Contributing Member • Posts: 827
I have not noticed this on my R5 on anything I've shot to date, but I can't say I regularly shoot anything that would cause this. It sounds like you know what to watch for and tried to avoid a situation that would cause it, but your clients didn't help.
 Croomrider's gear list:Croomrider's gear list
Canon EOS 7D Canon EOS 550D Canon EOS 5D Mark III Canon EOS RP Canon EOS R5 +27 more
Anyone else at all.
I would like to get some feedback, because I am now a little worried about this moire nightmare happening more often.
Please reply if you've experienced anything similar, or not, with your own R5.
bodeswell Senior Member • Posts: 1,939
Sounds like you just hit a perfect storm.
 bodeswell's gear list:bodeswell's gear list
Canon EOS R5 Canon EOS R7 Canon EOS R6 Mark II Canon EF 135mm F2L USM Canon EF 200mm f/2.8L II USM +4 more
Mike Engles Senior Member • Posts: 2,761
I would suggest that you used an exceptionally sharp lens to be so unlucky.The R5 is not particularly sharp in it self.
I have only had moire once to my knowledge and that was with a 5D2 using a very modest Canon 28-135, which does turn out to be very good. It was at a wedding and the culprit was the groom's suit.
bigshledge Contributing Member • Posts: 609
I've done product shots with previous Canon cameras, a lot of it fabric related. Got pretty bad moire, especially on high detail or reflectant fabrics. Happens regardless as AA filters on sensors can only do so much.
One trick I used was to slightly defocus the shot - still sharp enough, but just enough to ensure moire doesn't rear its head. As for how this can be done with mirrorless cameras in a portrait setting, could likely zoom in while taking the shot and adjust focus that way.
 bigshledge's gear list:bigshledge's gear list
Canon EOS R6 Canon EOS R10 Canon EF 135mm F2L USM Canon EF 100mm f/2.8 Macro USM Sigma 8mm F3.5 EX DG Circular Fisheye +6 more
Karl_Guttag Senior Member • Posts: 1,951
Try DxO with DeepPrime or Adobe "Enhanced" RAW conversion
Hopefully, you shot RAW or C-RAW. There is a very good chance that you can fix the problem with better RAW conversion.
I ran moire experiments about a year ago and found a significant difference in the moire effects with different RAW converters. See the pictures in my post: https://www.dpreview.com/forums/post/64949671
I follow up with further experiments comparing DxO DeepPrime and Adobe Camera RAW "enhanced" and "superresolution."
https://www.dpreview.com/forums/post/64937922
The result of this short experiment was that Adobe Camera RAW's Enhanced Processing seemed to work the best on dealing with moire followed by DxO with DeepPrime.
Modern software is better able to detect when moire problems are happening if you use the more advanced algorithms that require more processing.
Please let the forum know if this helps in your case.
 Karl_Guttag's gear list:Karl_Guttag's gear list
Canon EOS R5 Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 24-240mm F4-6.3 +14 more
Re: Try DxO with DeepPrime or Adobe "Enhanced" RAW conversion
Hi Karl,
This looks awful promising, in that the "Adobe Enhance Raw" conversion obviously handled the moire in your case way better than other conversion methods you tried.
Now, forgive my ignorance, but what the heck is this Adobe Enhance Raw method and where exactly in Adobe software is it hiding? Is it in Lightroom in some setting I have overlooked. Is it only somewhere in the Adobe Raw processor that is attached to Photoshop. I have no idea what this is. I know about super resolution and have tried it a couple of times with some success, but this function sounds like it is something else. Please let me know.
Thanks very much!
Used booth the RF 24-70 f/2.8 and the RF 70-200 f/2.8. Yes, they are both very sharp, but I don't know if that mattered a whole lot in this particular instance.
I'm not sure that I have the nerve to shoot out-of-focus shots on a paid job, but it sounds like you have perfected this method somewhat. What happens when you apply strong sharpening to the image to correct the mis-focus? Does that take you right back to the same problem of moire, or does it somehow still work?
It still looks sharp, the trick is to very slightly misfocus so that the moire disappears, rather than actually reduce resolution.
The thing about moire is that it's caused by out resolving the sensor. The goal of what I do is to make sure it doesn't do that.
Toothwalker Junior Member • Posts: 39
Strong sharpening will not introduce aliasing, but it does result in other artifacts. An image free of artifacts is necessarily a bit soft at the pixel level.
One of the reasons I am loyal to Canon is that they, unlike many other manufacturers and the majority of customers, understand the importance of an anti-aliasing filter. However, with my R6 I also notice more aliasing than with my previous (20 megapixel) Canon DSLRs. It can be annoying.
Moiré can be "brushed off" in post-processing, but there will be collateral damage as automated algorithms have no way of telling aliasing artifacts apart from valid detail. Educated guessing is the best they can do. Approaches differ between software suites, but color desaturation of areas affected by moiré patterns is often included.
Instead of deliberately shooting out-of-focus, you can also consider to use diffraction blur to avoid moiré. Just use a smaller aperture, if an increase in depth of field can be tolerated.
Simply because if the lens were less good, it would automatically blur enough to
do the already suggested defocus.A precaution for the future, sadly no help now.
A way to do a defocus in the field, would be to move forward or back a few inches to do a defocus, having focussed.
It is no comfort, but you did ask the subject not to wear certain clothing, having anticipated the problem. It is not your fault that that they ignored your advice.
Hi Karl,
Thanks very much!
It is a little tricky to find the feature and tricky to get it to work (lousy user interface IMO).
From Lightroom (which I don't use), you can follow Adobe's instructions; https://helpx.adobe.com/camera-raw/using/enhance.html
Using Photoshop (the way I used it) you first open the picture in Adobe Camera Raw as you would normally open a RAW image.
  • Then look for the "more options" with 3 little dots and right-click on it. Alternatively, you can right-click on the thumbnail and then click on "ENHANCED" in the menu that pops up. OR you can use the shortcut SHIFT-CONTROL-D.
  • Once you open the Enhance you will see the check box options for "Raw Details" and for "Super-Resolution."  You want the box for RAW Details checked.
  • Then click "ENHANCED" - NOTE this creates a DNG file and does NOT immediately make it the active file you are opening. You THEN have to click on the DNG thumbnail that will be created to have the ADC open the DNG file and not the original file (easy to screw this up).  Make sure the file name at the top says "enhanced DNG."
I have included some pictures below to help guide you. I have not used the enhance option much and found it to be confusing and easy to not get what you want.  I have included the pictures below to show you how I got it to work.
Finding the more-options submenu (see arrow and ellipse on the right side). You can also right-click on the lower right thumbnail and then click "Enhance."
Showing the "more-options"
Setting up the checkmarks. Note clicking enhance will create a NEW and different DNG file and NOT immediately open it for use (at least that is what happens for me).
Select Raw Details (only) and click Enhanced
After a little processing time, a DNG thumbnail will be created. You need to click on this DNG thumbnail to make sure you open the "enhanced file." Make it stays "enhance DNG" in the file name at the top of your screen (very easy to miss this step and not used the enhance file).
gimp_dad Senior Member • Posts: 2,873
My seat-of-the-pants assessment is that of bodies in fairly recent history the ones with the most moire given use of a very sharp lens that isn't stopped down too far is
  • Nikon Z7
  • Canon 5DSR
  • Canon R5
I've seen moire in all three of the above and in the listed order (most to least moire).
The LR moire healing brush has come a long way. I'd start there if it were me.
Here's an example from my Z7:
https://www.dpreview.com/forums/thread/4455768
drsnoopy Senior Member • Posts: 1,955
The Adobe enhanced raw processing workflow described by Karl looks like a good bet. However if it doesn’t work out, I would try with a layer based technique, creating a layer with a very slight Gaussian blur (0.3 or 0.5 pixels), which should hopefully remove or minimise the moiré, then using a layer mask to paint that over the affected areas. This would of course be a pain for lots of images, and probably wouldn’t work at all for heavy moiré.
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS R5 Canon EOS R7 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM +8 more
George Zip Senior Member • Posts: 1,633
I had the R6 and when shooting weddings I was having moire problems consistently on suits . Which I never figured out and seems weird . I have a suspicion it related to back lit scenes mainly .
Easy enough to clean up but annoying nonetheless. Like you I had never had that issue with the 5d2, 5d3 and 5d4.
I ended up changing to the R5 for different reasons and never had a moire problem since .
My studio specialises in headshots , branding and Boudoir . I never get moire now , and I’m primarily shooting business people in suits and fine fabrics. Imam using mainly the EF 70-200m2.8 II , EF 24-70m2.8 II , ef 50 1.2 (plenty of CA but that’s another story and recently the RF 24-105 F4 which is actually awesome.
It sounds like you just had a weird set or circumstances…. I would not stress unless it happens regularly.
sorry I can’t be of more help.
Wanted to add , I have since just stuck with the mechanical  shutter exclusively … only because it’s one less thing to worry about . Better minds than me will know if that has any bearing at all , but mention it as it is something that changed from the R6 .
Hi Karl,
Thanks very much!
Thanks very much Karl. I will definitely try it as soon as I get a chance. If it works, I may never have to live the recent nightmare of correcting 70 shots on one job with some nasty moire.
