Is Canon RF 15-35mm F2.8 unavoidable for interior/architecture photography?
Started 10 months ago | Discussions
atolk Regular Member • Posts: 120
I get calls from an architecture design studio to shoot interiors and exteriors of their buildings. So far, I have been getting by with the EF 24-105mm F4 on a Canon 6D and now R6. I get good results, but was thinking about making my job easier and results more impressive.
For "architecture photography" everyone recommends tilt-shift lenses, which are expensive and prime. For "interior photography", the top recommendation is the RF 15-35mm F2.8 at $2,399. The zoom range is not that great, but I feel the 15mm wide end of the zoom is necessary as I am struggling to get tight spaces like bathrooms and meeting rooms in at 24mm.
F2.8 for interiors? Probably an overkill, lets more light in, but we are not looking for any artistic shallow DoF effects. Of course at 15mm, the scene should be mostly in focus at any aperture.
Is there a lens with a better zoom range, or cheaper, or in any way a better interior/architecture lens than the subject?
Would I go for a manual focus lens? Maybe. The scene is not going anywhere. But the touch AF on R6 is a godsend when the camera is tripod mounted.
Thanks!
 atolk's gear list:atolk's gear list
Canon EOS 6D Sony a6500 Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Canon EF 24-105mm f/4L IS USM +4 more
Canon EOS R6 Canon RF 15-35mm F2.8L IS USM
BobKnDP Senior Member • Posts: 3,140
Re: Is Canon RF 15-35mm F2.8 unavoidable for interior/architecture photography?
Probably a stupid response, but...
Have you considered the RF 14-35mm f/4 L?
It's still expensive ($1.7k US), but less so than the 15-35 f/2.8 ($2.4k).
OP atolk Regular Member • Posts: 120
BobKnDP
Just as soon as I wrote this post and went to pick out a lens to link in tags. The RF 14-35 F4 popped right up and I became aware of it. Like I said, f/2.8 seems extra for the interior shoots off a tripod. So, yes.
I'd almost say that f/2.8 is extraneous for interior work using a tripod, but I don't do such work professionally.
I would say the same
ProDude Senior Member • Posts: 4,851
Real Estate is one of 3 things I perform professionally. Ironically, I don't even use a tripod. Never needed them as the image stabilization in either the body or lens I've used was more than sufficient to keep things steady. There are some more rare times I've needed to resort to a flash but it's actually surprisingly rare. I do daytime shoots almost exclusively anyway.
The average f stop, I'm using for ideal depth of field is at least f5.6 or even f8 at times. I do however use a lens that after trying out the Canon as well as a couple others, settled on the Sigma 14-24 f2.8 Art lens. Not only was it sharp edge to edge (the Canon wasn't) but had virtually NO correction needed due to the distortion so prevalent in wide angle lenses. I've had no compelling need for a tilt shift lens so far. There was also NO need to correct for CA or any other bad habits. The color rendition is superb on my R5 as well. I don't care it's used with an adapter. The focus is like native in speed and accuracy thanks to Sigma updating it's firmware. Not to mention a price less then half the Canon with wider performance and better all around. I never thought I'd go for 3rd party but in this case it simply was unavoidable. Better is better. Nuff said.
Name the gear and I've probably owned it and used it.
John Crowe
John Crowe Veteran Member • Posts: 3,476
RF lenses are at a premium.  Actually the TS-E lenses are actually cheaper than the 15-35.  The Laowa's are much less expensive.
You could consider the EF 16-35/2.8 or f4 L.  Buying used would save a lot of money.
Also the Sigma 12-24 ART for EF.
Generally to line up architectural photos effectively one uses a tripod so IS is not necessary, or may even be detrimental.  f2.8 is not necessary unless the overall IQ is superior, which sometimes it is.
I use the 17 TS-E and the Laowa 12/2.8 Zero-D for the odd architectural interior.
So the 15-35 may be very nice, but avoidable.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
fredlord
fredlord Veteran Member • Posts: 3,303
The prevailing real estate method in my area is to use HDR exclusively. The aperture recommended is f/8. A tripod is also generally easier although, if you are really steady, you could do it handheld. The camera should always be leveled up completely so it's easier with a tripod.
I have used the EF 17 TS-E, EF 16-35, and EF 11-24. The wider the better for some of the really tiny powder rooms. That said, the company I worked for wanted either 16mm or 17mm on a full-frame camera or 10mm on a crop-sensor camera.
The problem with HDR is the number of frames involved in each property. A simple shoot might be 3–400 frames. We often had eight properties to shoot in a day. That came to 3–5,000 frames per day. Many of the shooters picked up a less expensive camera along with a spare since they might shoot over 100K frames in a month. The cameras wore out fast and a spare body was always a good idea.
To simplify, all you need is something in 16mm for a FF camera. Wide apertures are not necessary as f/8 is the best aperture in most cases. The lens does not need to be top of the line, as one poster stated, so checking 3rd-party brands can really pay off as far as cost goes. Most lenses are just fine at f/8.
 fredlord's gear list:fredlord's gear list
Canon EOS R5 Canon EOS R7 Canon TS-E 17mm f/4L Canon EF 100mm F2.8L Macro IS USM Sigma 15mm F2.8 EX DG Diagonal Fisheye +13 more
Texchappy Contributing Member • Posts: 598
Would the little RF16/2.8 stm work in these instances?
 Texchappy's gear list:Texchappy's gear list
Fujifilm X100F Fujifilm X-Pro1 Canon EOS Rebel T4i Canon EOS R6 Fujifilm XF 18mm F2 R +10 more
Do you ever need to correct perspective distortion?
What does the ART designation signify/contribute?
Is this almost/about the same? Glowing reviews when people are not comparing about getting a grey market copy.
https://www.amazon.com/Sigma-14-24mm-Black-212954-Canon/dp/B079QCBYTZ
And this seems to be the exact lens you recommend for $100 more
https://www.samys.com/p/Wide-Angle-Lenses/212954/Sigma-14-24mm-f/2.8-DG-HSM-Art-Lens-for-Canon-EF/200921.html
Thanks, good info! I get a sense from most of the replies that the pricey RF 15-35mm F2.8 is highly avoidable. Looking into options.
Thanks, very good info.
I am looking closely at Sigma 14-24 ART f/2.8 for $1,299
TS lenses seem limiting for the type of jobs I get. Some kind of zoom is better than no zoom, and AF helps in a quick hit-and-run.
fredlord
Absolutely! Yes. It's light, small, relatively inexpensive and, reading the review, not that bad for IQ. Real estate photography doesn't require any more especially since it's generally shot at f/8 and manually focused. The barrel distortion mentioned would not present any impediment to a home sale.
https://www.the-digital-picture.com/Reviews/Canon-RF-16mm-F2.8-STM-Lens.aspx
PicPocket Veteran Member • Posts: 5,897
Re: same lens
They are same lenses if the picture on amazon listing is correct. The Amazon listing just doesn't mention the full name. The little metallic A badge on the left of the body is the ART logo. The $100 you are looking at is street vs MSRP
Specifically, sigma ART can be thought as their Canon L type lineup. More specifically, this is how C, A, S lenses are split in sigma global vision lens lineups - https://www.sigma-global.com/en/lenses/lines/
 PicPocket's gear list:PicPocket's gear list
Canon EOS R5 Canon EF 24-70mm F2.8L II USM Sigma 135mm F1.8 Art Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +16 more
Very rarely surprisingly which was one of my favorite things about the Sigma. If I ever did need to one click in DXO Viewpoint 3 does the trick perfectly.
The Sigma model you correctly linked to is Rectilinear in design which incorporates lens elements aligned in a manner to correct for the distortion associated with ultra wide angle lenses. The Canon doesn't do nearly as well in this regard. The corner to corner sharpness of the Sigma Art is also exemplary as well. You certainly can't fault the build quality as it's built like a sculpted Rolls Royce and very solid in the hand.
jwilliams Veteran Member • Posts: 6,385
Unless ...
Unless you're going to be making huge prints from shots taken with the lens wide open I see no advantage of the 15-35 2.8 over the 14-35 4.  The one stop of ISO difference will not be noticeable for most uses, but the extra 1mm could come in handy.  Saving money never hurts either.
Jonathan
Steve W Veteran Member • Posts: 6,998
I think you need to first decide how wide you need to go to
-16mm, 15mm, 14mm, or 12mm ( would you need 11mm)
At all of these there are typically f/4 an f/2.8 version but I think we have already agreed that f/4 is enough for your type of work.
i personally own the RF 15-35mm but I don’t use it for real estate an the 14-35/4 was not out yet. Also have 14mm on other systems I shoot.
Also there are two excellent EF 16-35 L lenses, the f/4L which is ~ $600 used and the 16-35/2.8L III if you wanted a faster lense.
Two things are infinite: the universe and human stupidity; and I’m not sure about the universe! - Words to live by. Albert Einstein
 Steve W's gear list:Steve W's gear list
Fujifilm X-E3 Canon EOS R5 Sony a1 Sony a7 IV Sony a7R V +49 more
Betonist Junior Member • Posts: 25
Sigma rectilinears
I understand that the SIgma 12-24 f/4 and 14-24 f/2.8 are both rectilinear. Dustin Abbott ( https://dustinabbott.net/2018/04/sigma-14-24mm-f-2-8-art-review/ ) suggested that the 12-24 might be better for interiors, while the 14-24 might be better for landscapes based on distortion at intermediate distances vs infinity. Is this an issue worth worrying about when choosing a lens for interiors and architecture in confined spaces? Also: does anyone have experience which might support or contradict Dustin Abbott's claim?
