Sigma 24-70mm F2.8 EX DG HSM Lens hood
Started May 13, 2022 | Discussions
glacerda
glacerda Contributing Member • Posts: 582
Has any one ever bought one of these?
Sigma 24-70mm F2.8 EX DG HSM Lens hood Sun visor (subtel.co.uk)
G. Lacerda
It is not the equipment, is my lack of skill that matters!
 glacerda's gear list:glacerda's gear list
Sigma DP1 Merrill Sigma SD10 Sigma SD14 Sigma SD15 Sigma 20mm F1.8 EX DG Aspherical RF +8 more
larryj Forum Pro • Posts: 13,197
Re: Sigma 24-70mm F2.8 EX DG HSM Lens hood
Hello glacerda:  I lost mine a few years ago and got a replacement from Sigma USA.  Have you tried Sigma UK?
larryj
If you can see the light, you can photograph it
Quote from Myron Woods
 larryj's gear list:larryj's gear list
Sigma SD1 Merrill Sigma 24-70mm F2.8 EX DG HSM Sigma 150-500mm F5-6.3 DG OS HSM Sigma 105mm F2.8 EX DG OS HSM Sigma 18-35mm F1.8 DC HSM Art +1 more
glacerda
OP glacerda Contributing Member • Posts: 582
Yes, I have. Sigma has a policy of only dealing with items from the ART generation.
I wanted to send it for maintenance and to buy the missing part. No luck.
Also dropped a SD14 and 17-70m non-OS and they declined to fix them; these items are too old, apparently.  I am very disappointed.
G. Lacerda
mike earussi Veteran Member • Posts: 9,529
That's the one main problem with buying anything from Sigma, if it's a few years old forget about it being repairable. In that sense they are definitely not a professional camera company.
 mike earussi's gear list:mike earussi's gear list
Sigma SD1 Merrill Sigma 105mm F2.8 EX DG Macro Sigma 50mm F1.4 DG HSM | A Sigma 24-35mm F2 DG HSM Art Sigma 70mm F2.8 DG Macro Art +1 more
Ceistinne
Ceistinne Veteran Member • Posts: 3,494
glacerda,
I dropped my old SD14 one time causing the focus screen to pop out of it on to the mirror. That is easy enough to put back in place. It's still working perfectly used now for IR photos only.
The 18-50mm f2.8 broke in two & at that time was fixed at the local Sigma agent here. It's still going well on my SD15 which use occasionally when large files are not needed.  Unfortunately they are gone now & Sigma Benelux is the Sigma supplier since January this year. So no more local support that I can walk into.:-(
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
Roger Veteran Member • Posts: 3,434
glacerda wrote:
Greetings glacerda
Yes, if you can't get the original it will work, not the best, but it works.
Even the Big "Pro Companies" can/won't repair a lot of their discontinued products. Sigma is a small company, but they'll repair or replace what they can. It's the new business model, don't repair or replace sell a new product. Sony is terrible about this.
Did you try Sigma Japan, or Sigma USA ?
Good Luck
Roger J.
glacerda
Good Luck
Roger J.
Theoretically I can try, my wife travels to Japan almost every year, except 2020 for obvious reasons, to visit her parents. A lot of my equipment was bought in Japan at a really nice small shop in Osaka.  I have not been to the shop for over a decade. I do have all the lens I need.
I will not bother with USA as they have refused to sell items to Europe; see another thread about buying sensor filter.
I will buy this item and try an original in Japan later.
G. Lacerda
