Safari Power Shot S5 IS 8 MP
Started 10 months ago | Discussions
Golfing Bob Regular Member • Posts: 121
I have an old 8MP Powershot S5 IS.  Would this even work for Safari Pictures. I believe most new Power Shot Bridge cameras have the same size Sensor. Any thoughts? I use an M50 for all my other pictures.
Canon EOS M50 (EOS Kiss M) Canon PowerShot S5 IS
Jon_T
Jon_T Veteran Member • Posts: 6,393
Re: Safari Power Shot S5 IS 8 MP
Golfing Bob wrote:
I have an old 8MP Powershot S5 IS. Would this even work for Safari Pictures. ...
Depends if you be happy with the 8MP resolution images,
... I believe most new Power Shot Bridge cameras have the same size Sensor. ...
True. But with more pixels in the same small 1/2.3" sensor; the smaller the pixel surface area, the less lighting gathering ability, and more image noise. Along with long telephoto lenses with small max apertures that basically mean you need good daylight lighting to keep ISO settings low.
Below a screen-shot from the DPR Studio Scene Comparison Tool (HERE ) with comparison of M50 and SX60 HS:
With the small apertures on the long-zoom bridge-type cameras will need high ISO's to have enough to prevent blurring due to animal movement and/ or camera movement.
In lower lighting the small 1/2.3" sensors image noise increases:
... Any thoughts? I use an M50 for all my other pictures. ,...
Take a look at the DPR article:
"Best enthusiast long zoom cameras in 2021" HERE
(be sure to look at the samples images)
Cheers.
Jon
 Jon_T's gear list:Jon_T's gear list
Panasonic Lumix DMC-FZ200 Canon PowerShot G15 Canon PowerShot SX50 HS Canon PowerShot S110 Leica C +16 more
OpticsEngineer Veteran Member • Posts: 7,822
I have an S5 IS.   Well of course it would work.   But I sure wouldn't take mine on safari.    I would much rather take a Canon SX70 or a Nikon P950 because they have much higher resolution EVFs so you can see the wildlife better.
 OpticsEngineer's gear list:OpticsEngineer's gear list
Fujifilm XF1 Olympus XZ-2 iHS Canon PowerShot G7 X Olympus Tough TG-4 Pentax *ist D +27 more
