ISO on the R5
Started 10 months ago | Discussions
thunder storm Forum Pro • Posts: 10,139
Re: Verification...
Quarkcharmed wrote:
thunder storm wrote:
I want just a single button to toggle between 100, 400 and auto. That's all I use. Saves me a dial for ISO adjustments.
There's a setting to change ISO increment to 1 stop. So you will have Auto, 100, 200, 400 etc. 200. You may not be happy with 200 but that's the best you can get.
I'm not happy without thirds stops increments for my Auto ISO.
In landscape photography, I use ISO 100 and 400 99% of time, and higher ISO values for astoscapes.
I use Auto ISO a lot.
I have special settings on C1 for landscape photography with 1-stop ISO increments and such, and 1/3-stop ISO increments on Av and M. Mostly for portraiture.
I will rethink my C modes.
45 is more than enough, but 500.000 isn't
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
Quarkcharmed
Quarkcharmed Senior Member • Posts: 2,713
Re: I see!
John Sheehy wrote:
Quarkcharmed wrote:
With all due respect to Bill's analysis, there must be gaps in the raw histogram which I don't see, so potentially it's more complicated than just digital multiplication.
Say if you multiply ISO 400 values to get ISO 500, you have to multiply each value by 2^(1/3) = 1.256, basically 5/4.
With integer digital numbers there will be gaps each 5th value - it won't be contributing to the raw histogram and we'll see the regular gaps.
A camera could do "corrections" differently for different lines of pixels, and fill a histogram that way, too; not just by using analog gain only. That's why you need to look at highlight headroom, too, to determine what is being done.
I suspect such corrections may easily introduce moire in the shadows. It can also be done by adding some dithering, but that will be adding the noise. Such additional corrections would just add to processing time with very little benefit - or am i missing something?
Beware of correct answers to wrong questions.
John
http://www.pbase.com/image/55384958.jpg
 Quarkcharmed's gear list:Quarkcharmed's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM Canon EF 50mm F1.8 STM
John Sheehy Forum Pro • Posts: 26,688
Re: I see!
I am talking about rescaling the RAW values; not adding or removing noise.
John
bclaff Forum Pro • Posts: 13,922
Re: ISO on the R5
Quarkcharmed wrote:
bclaff wrote:
Quarkcharmed wrote:
bclaff wrote:
MarshallG wrote:
Disclaimer: I’m only the messenger.
I’m at a trade show all weekly so I stopped in the Canon booth and spent a long time talking with one of their experts about the R5.
He then me that the R5 sensor slightly boosts voltage as you increase ISO,
Not slight but in proportion to the ISO setting.
and it did so in one stop increments.
True of many Canon bodies including the R5
Intermediate ISO changes are made post sensor read,
How do we establish that? I don't see it in rawdigger. With the interim ISO values (e.g. 125, 160, 320, 500 etc.) there are no regular gaps in the histogram.
4ex:
There are strange regular 'dips' though but they present at any ISO setting including 100, 200, 400
Anyway digital amplification should have produced much more frequent regular gaps with bins at zero.
It not so obvious as with older Canon bodies but you can see the pattern in the Read Noise
I added the red lines to show how every whole ISO setting is the bottom of a group of three that have a straight line. The pattern is most obvious at low ISO settings.
Right, that's very interesting. It's prominent before ISO 1600 although a bit debatable after 1600. But maybe it's just the small scale that hides it.
However the question is, why doesn't it show in the raw histogram? Say if ISO 500 is ISO 400 digitally multiplied by 5/4, we should see clear gaps every 5th bar.
I suspect some mild filtering or dithering which hides the gaps you might expect to see.
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
Re: ISO on the R5
Quarkcharmed wrote:
It could be that, but then it's not 'digital', and the Canon's representative from the OP said it was digital multiplication between the 1-stop ISOs.
I would not expect a public-facing rep to know the difference between 1/3-stop gain granularity in the first amp, "digital" (integer math) pushes, and 1/3 and 2/3 stop gain from a secondary amp. I would have to talk to that rep enough to know if he understands all these possibilities before I would assume that he knew what he was talking about.
Of course, it may be the case that with a combination of HTP, lighting with one weak color channel, and e-shutter, that ISO 160 may have more visible read noise than ISO 200 in shadows.
John
Re: I see!
MarshallG wrote:
Well… my eyes tend to defocus and glaze over on the math, but mostly because a 50,000 foot view of the data shows a basically flat line, nothing spiky.
It's nice to see the data, and a nearly-straight-line based on standard deviations may prove a limited difference, but standard deviations have nothing directly to do with visible noise. It is a hollow currency which depends on the noise character being the same always (usually assumed to be 1/f), only varying in intensity.
Imagine that you are laying under a glass table, looking up. Somebody comes along with bottles of black, white and grey sand. They poor the sand into little piles, one at a time so that there are clusters of black or gray or white, with dozens of each clumped together. You clearly see the "noise" of these B&W grains. Then, they take their fingers and keep mixing all the sand together, until it all looks grey to you. What happened to the standard deviation of the sand? Nothing. What happened to the histogram of the sand? Nothing. Yet, as far as you can see the noise is mostly gone after it is all randomly mixed. This is a removal of spatial correlation.
Standard deviations do not describe noise in a spectrum, which is where we SEE noise.
John
MarshallG
OP MarshallG Veteran Member • Posts: 8,951
Re: I see!
  1. John Sheehy wrote:
MarshallG wrote:
So he is absolutely correct, except that it absolutely does not matter in any meaningful way. No point in changing our practices as a result of this.
Standard deviations don't tell the whole story. You could have a situation where you don't see any triplets in charts but would see them in actual deep shadows in images, because spatially-correlated noise often has little impact on standard deviations.
There is no large-scale spatial correlation in the R5, though; its post-gain read noise is fairly random, with a fine horizontal banding noise, but it does not correlate vertically to create large bands.
So you’re saying I could be wrong, but thanks to a combination of pluckiness, native curiosity and a healthy dose of good old dumb luck… I’m right?  Happy day!
 MarshallG's gear list:MarshallG's gear list
Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 16-35mm F2.8L II USM Canon Extender EF 1.4x II +4 more
