ISO on the R5
Started 10 months ago | Discussions
MarshallG
MarshallG Veteran Member • Posts: 8,951
ISO on the R5
Disclaimer: I’m only the messenger.
I’m at a trade show all weekly so I stopped in the Canon booth and spent a long time talking with one of their experts about the R5.
He then me that the R5 sensor slightly boosts voltage as you increase ISO, and it did so in one stop increments. Intermediate ISO changes are made post sensor read, so he said that you can get a cleaner image at a higher ISO setting that falls on a full stop boundary, than on an ISO setting which is between 1/3 to 2/3 stop lower.
Again, I’m just relaying what the man told me. Don’t flame me, I’m just reporting.
 MarshallG's gear list:MarshallG's gear list
Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 16-35mm F2.8L II USM Canon Extender EF 1.4x II +4 more
Canon EOS 1200D (EOS Rebel T5 / EOS Kiss X70) Canon EOS R5 Canon EOS R5 C
Tazz93
Tazz93 Veteran Member • Posts: 3,473
Re: ISO on the R5
Maybe there was a misunderstanding on that. It sounds correct that, at various points the ISO performance can get better as you bump it up (for example 320 to 400 or 500) but I'd be surprised to see that occur at every full stop increment. I don't know the "nuts and bolts" of how dual gain technology works, but it could fall in the bucket you mentioned and that would back up a portion of the claim. But again... not sure its that way at every full stop.
Mike Jackson - Wildlife Photography Enthusiast
https://www.flickr.com/photos/mj_flickr/
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
gossamer88
gossamer88 Contributing Member • Posts: 769
Re: ISO on the R5
FYI
 gossamer88's gear list:gossamer88's gear list
Canon EOS R7 Canon RF 100-400mm F5.6-8 IS USM Canon EOS R5 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 +5 more
BobKnDP Senior Member • Posts: 3,140
Re: ISO on the R5
gossamer88 wrote:
FYI
Is this related to the person who posted some weeks back under the handle "vegetable"?
I presume that this is a trolling post.
Quarkcharmed
Quarkcharmed Senior Member • Posts: 2,713
Re: ISO on the R5
It's very easy to verify following this article
https://www.rawdigger.com/howtouse/iso-is-seldom-just-digital-gain
AFAIK it was true for some very old cameras but now most of the ISO range (except the 'extended' parts) is implemented through the variable analog gain.
 Quarkcharmed's gear list:Quarkcharmed's gear list
Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM Canon EF 50mm F1.8 STM
MarshallG
OP MarshallG Veteran Member • Posts: 8,951
Re: ISO on the R5
I’m only reporting what the man told me, and I have not conducted laboratory testing of his comments. But I did not misreport what he told me.
MarshallG
Re: ISO on the R5
Again, I’m only reporting what the representative from Canon told me (“You’re welcome”) and I have not looked at a bunch of bar charts to confirm his statement. I’m just telling you what he said.
MarshallG
Re: ISO on the R5
  • Hgossamer88 wrote:
FYI
That has absolutely nothing to do with my post.
While I generally like Mr. Northrop, I don’t think this video is very useful because he’s only demonstrating the noise that occurs when you boost brightness in post. It’s Stupid 101, because the real comparison is when you take two images which are exposed with the same lightness, using different ISO settings to obtain the same result. He didn’t even make one of those comparisons, so personally, I think he makes a useless explanation which does not help the photographer gain an understanding of how a higher ISO/lower exposure choice will impact the photograph, which is the ONLY THING THAT MATTERS here. Not “How does it work?” (Answer: I don’t care) but “How will it affect the photograph? (Answer: I need to know this!)
Quarkcharmed
Re: ISO on the R5
Yes, I see it's a Canon rep's claim not yours, I'm just saying it's very easy to verify.
Rawpaul
Rawpaul Senior Member • Posts: 2,567
Re: ISO on the R5
But why post it here without checking the facts ?
light is the source of all life.....
 Rawpaul's gear list:Rawpaul's gear list
Canon EOS M5 Canon RF 24-105mm F4L IS USM Canon EOS R5 Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-300mm f/4-5.6L IS USM +6 more
gossamer88
Re: ISO on the R5
BobKnDP wrote:
gossamer88 wrote:
FYI
Umm..what? Trolling? I thought the video was helpful.
MarshallG
Re: ISO on the R5
Why not report what the camera manufacturer states?
MarshallG
Re: ISO on the R5
gossamer88 wrote:
BobKnDP wrote:
gossamer88 wrote:
FYI
The video isn’t related to the issue.
gossamer88
Re: ISO on the R5
MarshallG wrote:
gossamer88 wrote:
BobKnDP wrote:
gossamer88 wrote:
FYI
That's all you needed to say and not accuse me of trolling.
JustUs7 Senior Member • Posts: 4,327
Re: ISO on the R5
I know the R5 is a much newer sensor.  I have heard this about my RP’s sensor which is older and from the 6DII.  I seem to recall seeing charts from DXO or Photons to Photos or something that supported the claim (full stop ISO adjustments handle noise and preserve dynamic range better) in the RP.
Further, along the lines of the Northrup video posted, the RP does a much better job with higher ISO in camera than it does with lifting shadows in post when it comes to handling noise.
But again, not sure if that applies to the R5. I’m curious if the rep was just giving their usual Canon spiel that they’ve done for years and maybe not considering improvements?   Or maybe it’s still modestly true at pixel peeping levels.
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
John Sheehy Forum Pro • Posts: 26,688
Re: ISO on the R5
5
Reps are not engineers and reps are not scientists. I would not expect any rep for Canon to understand RAW data in any privileged way. It would take a "natural" ability at sussing mathematical details to drive a rep to understand these things on their own. That may even be true for some engineers.
Most people work for corporations to earn income and benefits, not to explore all the technical details related to the corporation's products or services.
Beware of correct answers to wrong questions.
John
http://www.pbase.com/image/55384958.jpg
MarshallG
Re: ISO on the R5
gossamer88 wrote:
MarshallG wrote:
gossamer88 wrote:
BobKnDP wrote:
gossamer88 wrote:
FYI
It was someone else who called you the T word.
Steve Balcombe Forum Pro • Posts: 15,571
Verification...
It depends what you call "very old". I remember learning that the 7D Mark II, and others of that generation, performed best at ISO 160 and 320, and maybe 640, and to avoid the 1/3 stops in between. Above that the noise tended to swamp any other difference. However with the R5 it's different - there's a clear peak in performance at ISO 400, so much so that it's rarely worth using anything less, unless there's enough light (or shutter time) to use base ISO. But the claimed 'full stops' thing is not apparent.
As always, Bill Claff has the data!
https://www.photonstophotos.net/Charts/PDR.htm
Re: ISO on the R5
MarshallG wrote:
gossamer88 wrote:
MarshallG wrote:
gossamer88 wrote:
BobKnDP wrote:
gossamer88 wrote:
FYI
That was me. Actually, I wasn't sure it was trolling. I thought it might have been some sort of joke. The video is so absurd that I doubted it was intended to be taken seriously.
Comparing proper exposures at high ISO to drastic underexposures at lower ISO is a bit, er, misleading.
John Photo Senior Member • Posts: 1,371
Re: ISO on the R5
Thanks for the original post, Marshall. Just remember: "no good deed goes unpunished.";-)
