Bag suggestion for my little R6 kit
Started 10 months ago | Discussions
Texchappy Contributing Member • Posts: 598
Was hoping my 6L Peak Design everyday sling would work but it doesn’t seem to fit well. I have the R6, RF 24-105L, RF 100-400, & RF 16/2.8.
*Have the sling because that design works well shooting from my wheelchair.
 Texchappy's gear list:Texchappy's gear list
Fujifilm X100F Fujifilm X-Pro1 Canon EOS Rebel T4i Canon EOS R6 Fujifilm XF 18mm F2 R +10 more
Canon EOS R6 Canon RF 100-400mm F5.6-8 IS USM Canon RF 16mm F2.8 STM Canon RF 24-105mm F4.0-7.1 IS STM
Steven Blackwood Senior Member • Posts: 2,210
Re: Bag suggestion for my little R6 kit
How about the 10L bag. Given your setup, and looking at the website photos, this my be nearly ideal.
Steve
stevenblackwood1950@gmail.com
Milwaukee WI
 Steven Blackwood's gear list:Steven Blackwood's gear list
Canon EOS R Canon EOS R6 Sigma 100-400mm F5-6.3 Canon EF 70-200 F4 II Canon RF 35mm F1.8 IS STM Macro +2 more
BobKnDP Senior Member • Posts: 3,140
I'll second that.
I have an R5, with an RF 24-105L, an RF 100-400 STM, and an RF 14-35 L. With the 24-105 attached to the R5, they fit well in the 10L version.
cocoanud
cocoanud Contributing Member • Posts: 699
Hi,
If a shoulder bag works then I can recommend ThinkTank Mirrorless Mover 30i. I got it recently and I am able to fit
- R6 + RF 24-105L (laid on its side, grip side up ready to go)
- EF 70-200 f/4 L + hood inverse fitted (RF 100-400 will also fit with the hood inverted, I tried my friend's RF 100-400 and fit much better in that bag)
- Also, I actually place the little EL-100 flash and EF-RF adapter at the bottom, attach one of the separators which came with the bag on top of that and then place the R6 + RF 24-105 on top of that.
- And after all that there is space for RF 50 1.8 (or 16 2.8), and and a couple of extra batteries.
The only slight issue is that the additional RF 50 or RF 16 will have to go on top of the camera body and will get in the way while taking the camera out and putting it back in and could be an annoyance if you plan on doing that frequently.
You could in theory try placing the RF 50 at the bottom and then use a separator on top of it and place the camera on top but not sure if that is a good idea with the STM Lenses ?
I am planning on getting a JJC lens pouch for the RF 50 and attaching it outside the bag if I do end up carrying the RF 50 just in case.
HTH
C
 cocoanud's gear list:cocoanud's gear list
Canon EOS R6 Canon EF 100-400mm F4.5-5.6L IS II Canon EF 70-200 F4 II Canon RF 24-105mm F4L IS USM Samyang AF 85mm F1.4 RF +3 more
Morvegil
Morvegil Senior Member • Posts: 1,024
Wandrd 11l Sling
Only pros shoot with Canon.
 Morvegil's gear list:Morvegil's gear list
Canon EF 70-300mm f/4-5.6L IS USM Sigma 50mm F1.4 DG HSM | A Sigma 24mm F1.4 DG HSM Art Canon EOS R5 Canon RF 24-70mm F2.8L IS USM +2 more
