Why isn’t AF picking up these birds?
Started 10 months ago | Questions
Texchappy Contributing Member • Posts: 598
Got my R6 today and tried to get it set up. First with the 24-105l and this one with the RF100-400, the AF just isn’t finding these birds. What am I doing wrong?
It kept locking on the fence. Earlier when I was using the shorter lens, it kept locking on a lawn chair in the corner.
 Texchappy's gear list:Texchappy's gear list
Fujifilm X100F Fujifilm X-Pro1 Canon EOS Rebel T4i Canon EOS R6 Fujifilm XF 18mm F2 R +10 more
Canon EOS R6 Canon RF 100-400mm F5.6-8 IS USM Canon RF 24-105mm F4L IS USM
JustUs7 Senior Member • Posts: 4,327
Re: Why isn’t AF picking up these birds?
5
I’d suggest that the bird is too small. Even the spot AF area would be bigger than the whole bird. The line where the fence meets the house offers strong contrast. You have to get closer, or get the RF800 f/11, or manually adjust focus.
Heck, they might even be in focus but by the time one blows them up big enough to see on a 1080 monitor, they’re all pixelated and appear to not be sharp.
You’re also at 1/60th. I know IBIS and IS on the lens are supposed to be good, but that’s a tall order at 400mm shooting that small of a subject hand held.
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
R2D2 Forum Pro • Posts: 26,531
14
You're too far away, the birds are too small, the fence has too many knots, your settings might not be optimal. you weren't using crop mode (might be all of the above).
R2
OP Texchappy Contributing Member • Posts: 598
I wondered if that might be the case
I’ll try the closer birds tomorrow and move the chair out of frame because it was catching too much of frame I believe.
And they were pretty small on this lens as well.
Re: I wondered if that might be the case
The chair is not in focus.  The pole holding the bird feeder is.  As is the bird bath.   I’d sit right where you were and use the 100-400 on the feeders, not the fence.  Set up your animal eye af and make those birds as big as you can in frame.  That lens has a very short minimum focus distance allowing you to use 400mm from three feet away.
If full AF isn’t working for you, try spot or single point and use touch and drag to put the square right on your subject.
That’s what was on tap for tomorrow - longer lens and closer targets.
tsinvest
tsinvest Senior Member • Posts: 1,600
I would say way too far away for that little bird.  Even if the camera did focus on it, at that distance with a 20mp sensor you wouldn't get much detail anyway.  Even with the R5 45mp sensor your bird details would be muted.  You need to somehow get closer and/or find bigger birds to photograph.
Thanks, Tom
my Instagram gallery...
https://www.instagram.com/tom.sicora
 tsinvest's gear list:tsinvest's gear list
Canon G7 X III Canon EOS R5 Canon EOS R7 Canon EOS R10 Canon RF 35mm F1.8 IS STM Macro +6 more
birdbrain
birdbrain Veteran Member • Posts: 4,258
8
Which pixel is the bird?
 birdbrain's gear list:birdbrain's gear list
Sony RX10 II Canon EOS R5 Canon EOS R6 Canon EF 16-35mm F2.8L II USM Canon EF 24-70mm F2.8L II USM +7 more
The one with feathers obviously;)
Rawpaul
Rawpaul Senior Member • Posts: 2,567
Lol , funny
light is the source of all life.....
 Rawpaul's gear list:Rawpaul's gear list
Canon EOS M5 Canon RF 24-105mm F4L IS USM Canon EOS R5 Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-300mm f/4-5.6L IS USM +6 more
Bobby V
Bobby V Senior Member • Posts: 1,592
From the Canon Global site: "The Animals AF subject setting and Eye AF are very effective when the subject is relatively close, there are no obstructions around it, and you can distinguish the bird's eye. However, there are times when a bird will hide in the grass or in the branches of a tree to protect itself from predators. When the subject is perched or not moving around much, it would be best to focus the shot within the frame using a single AF point or surrounding points."
John Photo Senior Member • Posts: 1,371
Good points by others. To emphasize, if your focus is jumping to the chair in the second photo, your af point group is likely too large; use point or point with' small surrounding group.
Much better today
Using the 100-400 on the closer birds. Was my plan yesterday but the dog scared them to the fence.
From just now…
Re: Much better today
5
Why f/16 and why 1/60th? IS is great for static subjects but that feeder moves in the breeze. The bird makes small movements.
I’d be at f/8 with a minimum shutter speed of 1/500 or 1/1,000 and auto iso. Your R6 can handle the ISO’s
Auto mode
Wasn’t laying much attention, had it in auto and was concentrating on the autofocus points.
Andy01 Veteran Member • Posts: 5,188
Re: Auto mode
It seems unlikely that Auto would have selected such a slow shutter speed or small aperture at 400mm.
I think all of the images you have shown here, including the first one were at 1/60th - perhaps check that you are not in Manual or Tv modes ?
As mentioned above, even with good IS, at 400mm you want to be at a minimum of 1/400th, preferably faster to get good sharpness. Also, for many (most ?) lenses diffraction is becoming evident at f16. With my EF 100-400L ii I generally only stop down to around f6.3 or f7.1 and often use f5.6 at 400mm to maximise shutter speed, so I would expect f8 or f9 to yield decent results with your lens.
Your latest photo, while better, is still incorrectly focused - IMO the light below the feeder appears to be much sharper than either the bird (the bird is very OOF) or the feeder - perhaps both were moving across the slow 1/60th, or something has gone wrong quite badly with the focusing.
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
Re: Auto mode
Colin
Checked the AF point and it shows basically the top of the bird’s head. Thought I was on the A+ auto mode but it’s possible I was on something different. I’ve started using the flexible priority mode as I’m paying more attention to other aspects of the camera as I’m getting comfortable with it.
Re: Auto mode
If it was windy and the feeder (and bird) were moving around, then you probably needed at least 1/1000th to freeze the bird (assuming it was correctly focused on the bird's head).
You could achieve the same exposure by using f8, 1/1000th and ISO 800.
Colin
Re: Auto mode
Colin
Going to try to go sit out this evening and give it a try. They didn’t cooperate this morning. There isn’t a lot of times in west Texas that there isn’t wind. One of the set that morning had the birds tail oof so that should have given me a clue. Was focused (no pun intended) on the AF settings/operation that I wasn’t looking at the other aspects of the shot. Now that I’m figuring out more settings and functions I’m looking more at those things.  Having shot Fuji for the last decade, I’ve had to pay much more attention to those things on the dials.
Today. Maybe a little better
Slowly getting things in place…
