Shouldn't I be able to get closer?
Started 10 months ago | Questions
grsnovi Veteran Member • Posts: 3,030
The field of view here is about an inch. It was shot from a distance of about 10" using manual focus. The small black piece is about 1mm wide in the horizontal width.
Pieces of the balance from a 110 year-old Elgin pocket watch
 grsnovi's gear list:grsnovi's gear list
Panasonic Lumix DMC-GX85 Sony SLT-A65 Sony a7R III Panasonic Lumix DC-GX9 OM-1 +11 more
BBbuilder467 Veteran Member • Posts: 7,057
Re: Shouldn't I be able to get closer?
1" is 25.4mm. The apsc at 1:1 would be 22.6mm, so you're close to 1:1. If you manually adjust to minimum focus and physically move closer to focus, you should reach true 1:1 if you aren't already.
OP grsnovi Veteran Member • Posts: 3,030
Thanks BB!
Next question: What do I need to do to get more?
I just ordered a set of extension tubes, we'll see what they do...
grsnovi wrote:
Thanks BB!
Extension tubes seem like the most practical way to get an increase in image size.
If you used a macro lens with your micro 4/3, it would get 17.3mm in frame at 1:1.
Josh Photo Bug
Josh Photo Bug Forum Member • Posts: 72
Coincidentally, I have a capture of a similar watch part. Not a pocket watch, but similar nonetheless.
7mm watch part; About 2x magnification
 Josh Photo Bug's gear list:Josh Photo Bug's gear list
Nikon D750 Olympus E-M5 II
Yep, yours sure is cleaner...
