Re: Why includes graphs and not an actual photograph?
jrsforums wrote:
Dakotan wrote:
You have a camera, right? All these posts are all graphs and numbers, and not a single photo demonstrating what you are talking about. You say it's better than LIVE ND in another post also full of graphs and then adjusted graphs after you sort out median vs mean.
All most of us care about is the end product. Show a comparison image, or ANY image and then we can all judge. Until then, all the graphs you can supply are practically worthless.
There are lots of example articles & videos on the web….Google it….no need for more here. For example: https://fstoppers.com/education/using-long-exposures-without-help-neutral-density-filters-345545
A benefit of doing in post vs. in camera is you can adjust the effects by varying number of images used. Plus, in many cases, can handhold if using for noise reduction (not so much for ND as longer exposures) as post auto alignment is excellent.
When you can't see the wood from the trees it is easy to go and come out with statement like that person
Anyway just to give an example on how going and stacking frames is not a good idea unless required when you want to do a long exposure this is a comparison of the stack of 64 frames against a single frame treated with DxO Deep prime.
The whole idea that a primitive system like mean stacking all of a sudden is better than new noise reduction software is ludicrous
Here you can see that mean stacking of course smudges detail everywhere not just where things move the mountain and the bridge have less details
Another claim is that mean stacking all of a sudden is comparable to HDR and that the shadows are amazing well they are not really as in the example here DxO matches and beats it
So while it may be useful to use stacking if you don't have a strong enough filter with you to achieve the long exposure you want it is not true that you should be systematically stack exposure as it makes the images look amazing, it does not and it softens them
I was curious about those claims so I was looking for something that 'would be more subtle but equally effective than HDR' as suggested here. So I though let's give it a go and also get a bit of a long exposure effect (not desired)
Bracketed shot
Stacked shot
Single shot
I would argue that the single shot looks better than the stacked shot in the end and the HDR shot is in another category but that was a 3 stops gap bracket
