Sigma SD15 Camera - Please Does Anyone Have Raw?
Started 10 months ago | Discussions
Peter Slovakia
OP Peter Slovakia Contributing Member • Posts: 716
Re: Sigma SD15 Camera - Please Does Anyone Have Raw?
Ďakujem vám, Abbazz, za vaše vynikajúce poznatky o fotoaparátoch SD14 a SD15. Veľmi dobre rozumiem tomu, čo si napísal. Keby som mal kameru SD14, tiež by som nemenil. Jeho neprekonateľná kvalita obrazu pri ISO50 je všeobecne známa.
Peter
 Peter Slovakia's gear list:Peter Slovakia's gear list
Sigma DP3 Merrill Sigma SD1 Merrill Sigma sd Quattro +3 more
mike earussi Veteran Member • Posts: 9,440
Peter Slovakia wrote:
Thanks, Larry, for your pictures on camera SD15.
Ted he sent me 4 RAWs, which I processed and enlarged in Lightroom. Upsizing and sharpening works very well. It is possible to work with images from the SD15 camera in this way.
As I wrote in the post before, I will not buy another camera now. I'll make do with the SD1 Merrill camera. I'm used to its use and image processing. I don't want to complicate things it's not good for life. Or I'll wait for the new FF Siigma, which will definitely be.
Thank you Larry for your help. I wish you all the best and lots of beautiful photos
Peter
Something to consider is that a FFF will be mirrorless and so will probably not have a removable IR filter so no easy conversion to IR photography by just removing the IR filter.
Admittedly, I don't take a lot of IR photos, but it's still a nice feature to have when I do want to use it. Even if the FFF ever comes out I'm not selling my SD1M for that reason.
SD14 IR panostitch
SD1M panostitch sepia toned
 mike earussi's gear list:mike earussi's gear list
Sigma SD1 Merrill Sigma 105mm F2.8 EX DG Macro Sigma 17-50mm F2.8 EX DC OS HSM Sigma 50mm F1.4 DG HSM | A Sigma 24-35mm F2 DG HSM Art +2 more
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
Unlike the mirrorless sd Quattros ?
what you get is not what you saw ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
Peter Slovakia
I understand, Mike. I will probably never sell my SD1 Merrill camera.  Overall, I have lenses set up by a specialist garage for this camera, which is recognizable by good (mostly) focusing. There will be no reason to sell it.
BTW, nice photos Mike
Peter
Quattros don't have true mirrorless lens to sensor spacing. They're just a dslr without the mirror. I'm not that familiar with the FP but I don't think they have removable IR filters.
Peter
Thanks. On the SD1M I can also calibrate my lenses for IR which of course is a completely different calibration from daylight. This ensures accurate IR AF focus.
xpatUSA
I see, Mike. At what spacing does a mirrorless camera become "not mirrorless"?
It has nothing to do whether it is or is not mirrorless, it has to do with how much room it has to have to have a removable IR filter.
xpatUSA
OK, I get it.
D Cox Forum Pro • Posts: 32,979
They don't -- at least, not removeable by the average user. There are specialists who will do it for you for a fee.
Don
Sigma fp
Gourownway Regular Member • Posts: 111
The SD15 is quite low rez by todays standards but enlarges quite well in Sigma’s propriety software. You can double the resolution.
however the SD15 needs to be well exposed to get a good image. DR is limited and it’s ridiculously easy to blow the highlights. Under exposure will give you horrible noise.
I still use mine and when I get everything right that is when the magic happens. Under or over expose and it will punish you.
xpatUSA
A caveat for those who get that done. I sent my G1 in for conversion not realizing that all they remove is the filter, not the CFA. So when I took my first shots outside, they did not have the ugly magenta cast a la Foveon - almost normal RGB in fact.
Still the IR effect was available with a 720nm on the lens:
Followed by some mapping in the GIMP:
what you get is definitely not what you saw ...
