Irix 15mm f/2.4 with EF-RF adaptor
Started 10 months ago | Questions
vtzerpos New Member • Posts: 13
I recently bought a Canon RP camera with the original Canon EF-RF adaptor. Checking how my EF lenses work with the adaptor (and they do work fine), I noticed that with my Irix 15mm f/2.4 Firefly there is no focus confirmation, as it was the case when I used this lens with my previous DSLR camera (Canon 6D mark II). I am still using this lens with the camera in the AV (Aperture Value/Priority) mode and I can still change through it the aperture, which means that there is indeed communication between the camera and the lens through the adaptor, but still I don't get the focus confirmation as in my DSLR. Is this a limitation of the EF-RF adaptor or do I have to change something in the settings of the camera?
Thanks in advance for your help.
VT
 vtzerpos's gear list:vtzerpos's gear list
Canon EOS RP Canon EF 50mm F1.8 STM Canon 70-300 F4-5.6 IS II Irix 15mm F2.4 Canon RF 35mm F1.8 IS STM Macro +1 more
Sittatunga Veteran Member • Posts: 5,406
Re: Irix 15mm f/2.4 with EF-RF adaptor
VT
I think it's a limitation of the RP, in that the R (and presumably the other RF mount cameras) brings up the match-triangles focus aid (if you've enabled it) when a lens is detected that hasn't got AF switched on. I don't have an RP to check this. In the absence of that focus aid, I find that scale focussing is the quickest method, and precise enough beyond arm's reach with a lens that short. If the subject's closer than that I can use a tape measure. The depth of field scale on the lens will give you an idea of how precisely you need to estimate the distance for each aperture. Choosing a focus spot and then magnifying it 10× in the viewfinder is the most accurate method. Using focus peaking can be precise enough if I stop down a couple of stops, but I find it slower than scale focussing.
Andy01 Veteran Member • Posts: 5,188
VT
I don't know about the adapter and how it may affect the indicator, but on my Samyang 14mm f2.4 XP (I didn't buy the Irix because the first 3 lenses I tried were defective - 2x Firefly and 1x Blackstone) on my 6D ii the focus indicator is sort of superfluous.
The reason being I think is that the DoF with these UWA lenses, even wide open is so big that it is fairly hard not to be in focus (good enough for daytime purposes) simply setting the focus using the distance scale (which I think from memory steps from 3m to infinity, so pretty much everything outdoors is infinity). I can rotate my focus ring quite some distance before the focus indicator will change state.
And, of course for stars (my main subject for my 14mm) the focusing has to be done MUCH more accurately than could be achieved using the focus indicator.
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
OP vtzerpos New Member • Posts: 13
I sent my question to Irix and they replied, saying this: “For mirrorless cameras, you need to enable "focus peaking" in the settings. This should solve your problem.”
Do you want this focusing aid for normal daytime work, or for astro/stars ?
IMO for daytime or indoor use with a UWA lens like this the focus distance scale is perfectly adequate to achieve very good (if not perfect) focus.
For astro/stars, no focus indicator or focus peaking is going to be accurate enough to achieve sharp stars. The only way to achieve decent focus is either with a physical aid like a Batinov filter or doing what most of us do, which is to use Live View and maximum magnification to find a bright star and adjust focus on it.
Colin
