Oly question: Is a PRO lens wasted on an EPL9 body?
Started 11 months ago | Questions
(unknown member) Forum Pro • Posts: 47,805
No.
though whether you like the combination of small camera with big lens that's another thing.
Raist3d/Ricardo (Photographer, software dev.)- I photograph black cats in coal mines at night...
“The further a society drifts from truth the more it will hate those who speak it.” - Apparently Selwyn Duke and not George Orwell
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Stabilisation
cc99 wrote:
Guy Parsons wrote:
The 1/8 second quoted would be about a bit over 5 stops stabiisation, the 2 seconds is off the chart and unbelievable.
Two seconds also shocked me (expected 1/2 sec), but I did it several times in a row (albeit seated and braced), so new respect for the E-M1.2.
In my experiments, seated instead of standing adds about one stop. Seated and braced, such as elbows resting on the chair armrests, adds maybe two stops on average compared to standing hand-held, so now your 2 second claim for the E-M1ii now makes some sense to me. Odd though that the E-PL7 does not do as well as I would have expected better than 1/8 sec in that braced seated situation.
agott123
agott123 Senior Member • Posts: 2,579
Get a grip.... :)
nt..
My Street Photography on Instagram @alexgottfriedbonder
 agott123's gear list:agott123's gear list
Panasonic Lumix DMC-GF1 Olympus PEN E-P2 Olympus PEN E-PL1 Panasonic Lumix DMC-GH3 Olympus PEN E-P5 +21 more
MOD Tom Caldwell Forum Pro • Posts: 46,360
Re: Oly question: Is a PRO lens wasted on an EPL9 body?
BruceRH wrote:
I don’t think so particularly if you are eyeing a body upgrade at some point. My opinion is buy the best glass for it lasts a long time, bodies come and go. The small size of the 40-150/4 Pro should match well. Welcome to the forum!
Endorsed - a good lens will always improve any particular cameras performance.
I have been doing that for some time by pairing great lenses with GM5 camera bodies.
On the other hand a better sensor will bump up all the lenses performance with the reservation that the sensor will never make a good lens into the even better lens that you might have chosen to buy.
Tom Caldwell
raenneb wrote:
Thank you! Some of my concern was that I read a review of an EM-5 (cant recall which) where the user said the body was flexing with the weight of the pro lens that they use as their everyday carry. I thought, oh no, does my EPL9 stand a chance?? But you've reassured me, this lens is set to be very light
(Surprised) I have never noticed body flex on any of my camera bodies even with the heaviest lenses.  For example the tiny GM5 can carry the PL 200/2.8 (which has significant weight.
Perhaps it is because the weight to the lens is generally supported by the left hand and arm.  For really heavy lenses - such as large telephoto - it is traditional that the lens more or less supports the weight of the camera body.
Tom Caldwell
Impulses Forum Pro • Posts: 10,039
Not IMO, but I guess it depends on what you're trying to do with it. I use my 75/1.8, PL25 II, 35-100/2.8 and even the 100-300 II on a GX850, outside of shooting action it's not really at a significant disadvantage to my E-M5 III. In fact I'd use those teles a lot less if I didn't have a tiny body to mount it on, sometimes by itself but often carried as a second body to avoid lens swapping as often.
Like others said, bodies come and go, good lenses will easily last ya the better part of a decade or more, and there's not really a super significant IQ difference between most modern M4/3 bodies. Regarding your comment about body flex, the E-M5 III in particular (not earlier ones) had a weaker bottom plate which could turn into an issue with much heavier lenses (>500g probably), but that's a real edge case.
I've carried the ~300g 75/1.8 & 35-100/2.8 on my very plastic GX850 while hanging it off a Peak Capture clip on the side of my bag for years and it's no worse for wear tbh. I doubt an E-PL is built any worse (knock on wood?).
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
On a tripod there's no support for the lens and there's some heavier lenses that could probably benefit from a collar but one isn't provided (and/or available) for them... I doubt it's an issue on most bodies but it's turned into an issue on some, like the rash of E-M5 III with broken bottom plates near it's launch. Most of those instances seemed to involve mounting/carrying the camera on a PD Capture but it's not inconceivable that heavier lenses & certain tripod use cases could lead down the same path.
My E-M5 III does have some visible bottom plate flex to it compared to my Mk II, particularly if I mount the 100-300 II to it and don't use the Roesch collar I got for said lens. I've never tried doing the same thing with my GX850 but I've used ~300g lenses on it on a tripod and even hung it off a PD Capture with them without issue. There's a handful of lenses that are as heavy or heavier than the 100-300 but have no collar option unless 3rd parties have filled that gap, eg 12-100, PL50-200, etc.
Bassam Guy Veteran Member • Posts: 4,890
Re: Oly question: Is a PRO lens wasted on an E-PL9 body?
Guy Parsons wrote:
Bassam Guy wrote:
cc99 wrote:
raenneb wrote:
I just bought the 40-150mm f/4 PRO. ... am i doing a disservice to the lens by pairing it with the E-PL9?
On my E-PL7 (same IBIS), I can handhold this lens (at 150mm) for only 1/8 sec. On my E-M1.2, I can handhold at 150mm for 2 seconds.
Edit: I thought this was about the 40-150/2.8.
You must not be holding your camera properly. I handhold a 1Kg 300mm f4.5 OM lens (for film OM cameras) on my E-PL5 indefinitely.
You are supposed to hold the lens with your left hand and the body with your right hand. Body weight doesn't matter. How are you holding it so you can't even hold it for 1 second?
I suspect that he is talking about successful shots at those speeds. The 2 seconds is a bit of a stretch at 150mm unless you use a tripod.
From my little handy spreadsheet... at 150mm likely slowest speeds...
Hand-hold, of course. Explains the seemingly irrelevant beanbag. 😮‍💨
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
cc99 Contributing Member • Posts: 565
Re: Get a grip.... :)
There's the rub: there is no grip available for the E-PL9 (or anything after PL5).  I don't use mine with anything larger than the 12-40/2.8.  Still useful when you need an extra body and have little space in your bag.
 cc99's gear list:cc99's gear list
Olympus E-PL7 Olympus PEN-F Olympus E-M1 II Olympus E-M1 III OM-1 +28 more
Re: Stabilisation
To me, hand-held means no tripod, not free-standing.  In the real world, I try to brace somehow, precisely balance the lens in my left hand, and use the rear-screen, not EVF.  Practice made a huge difference for me.
NT in the title
agott123 wrote:
nt..
BTW: the idea of NT is to save people from clicking to read the post's text, not clicking to read the post's text and be told there's nothing to read.
Cychen Regular Member • Posts: 243
Not at all. All the m43 cameras, 16mp or 20mp, are actually quite similar in terms of image quality (not sure if it should be consider a good thing or bad thing LOL).
So to put it bluntly, you are actually choosing how you wish to handle the camera. That's the only major difference...or perhaps autofocus for tracking (SAF wise, whether PDAF or CDAF only, are all pretty decent. )
For IBIS, the flagships are definitely better but 3 axis is already very good for general use (I'm talking strictly about Olympus cameras though.)
 Cychen's gear list:Cychen's gear list
Olympus XZ-1 Olympus E-1 Olympus PEN E-P2 Panasonic Lumix DMC-G2 Olympus OM-D E-M5 +17 more
kcdogger Veteran Member • Posts: 4,356
Wigelii wrote:
PRO glass is NEVER wasted
+1  I agree, 100%.
John
 kcdogger's gear list:kcdogger's gear list
Olympus Stylus 1 Panasonic ZS100 Sony RX100 VA Panasonic Lumix DC-ZS80 Olympus TG-6 +37 more
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
raenneb wrote:
I just bought the 40-150mm f/4 PRO. I currently have the EPL9 which has served me well. I've been eyeing the EM1 mark ii (or in an ideal world, iii) but was planning on becoming familiar with the lens first + waiting a bit to recoup funds to spend on a new body. I'm not in the "get the gear" camp (after all, we live in a world where a feature length movie can be shot entirely on an iphone) but I'd like to know: am i doing a disservice to the lens by pairing it with the EPL9?
You are not doing wrong with the body technical wise, the epl9 can use the good glass,
What you might have a problem is with the practicality of holding a heavy lens on the epl9, it barely does the 40-150 R ok, so it will struggle holding with a larger lens.
I would get a small tripod to help hold the camera, till you get a bigger, stabler body.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
Getting a thumb-grip
Actually, there is one: I have used the Fotodiox Type-B thumb-grip [B&H ], with my E-PL7, and it greatly helps with larger lenses, but also slightly hinders the AEL button.  It probably fits the E-PL9 too.
Guy Parsons
About grip gripes
As I bought the 12-40/2.8 while I was using the E-PL5 I took the opportunity to try it with...
  • The default grip.
  • The bigger grip (I think was an optional one for the E-P3?).
  • No grip at all.
And for me I report no difference at all in handling, even if putting the 75-300mm on the E-PL5. I also kept my Sony RX100M6 "plain" and did not add the optional grip to its front.
Oh, and no viewfinder, always screen (with all cameras) and held mostly around mid chest and sometimes down to waist level.
The trick for me is to make fitted wrist straps from 1/2 inch cotton tape so the right side of the camera is held with the strap and my grip of the right side only needs to be a rather light finger wrap.
The left hand holds the lens and body at an appropriate balance point by adjusting hand shape.
No problems at all.
Guy Parsons
Re: Stabilisation
In my case I base all my experiments and tests on standing hand-held as that is by far the most likely situation - usually no tree or post is handy. Naturally if some support is close by and the need arises then they may be used as stabilisation boosters.
The E-P5 IBIS is so good that I never carry a tripod any more on trips, maybe just that little bean bag gets used on rare occasions. One evening in Japan in 2014 I tried my "stability" and at 40mm I could get perfect results shot after shot at 1/2 second, that's a bit over 5 stops compared to my usual ability with no IBIS to match the old rule. Lately though increasing age has taken my 40mm ability to 1/4 sec to be reliable. I now do need that tree to lean against.
Re: Stabilisation
I don't mean to suggest this is in any way representative, but it shows what the IBIS can do if you really push it.   If there really are no supports, I can always sit on the ground (which I already do for macro).
I don't set out to deliberately go crazy to prove a point that the GM5 with its usable evf is perfectly at home with lens supported by left hand and eye to evf.  But it is not really any different balance-wise to any regular dslr with a significant lens on board.  If the mount might flex I have not noticed it. Holding the GM5 thus equipped by each end of the camera body and trying to use this combo by using the lcd to frame and focus is plain nuts.
I do agree that mounting such a combination via the tripod socket on the camera body itself is unwise.  But I hardly use tripods any more.  I do have occasion to use the EF 400/2.8 (5.5Kg) which really needs a tripod but this lens and most other truly heavy types have a tripod socket in a lens collar as you obviously know and appreciate. But with larger lenses I usually use larger camera bodies as I am not truly stupid with it
I still find the PL 200/2.8 quite happy as a hand held lens even with the 2.0x TC in use.  The lens IS is certainly good enough to make even a GM5 combination quite stable. Again, if I am not trying to work as compact as possible I will have something like a G9 attached to this combination.
The Olympus 12-100/4.0 is one of my favourite GP lenses and almost always lives on a GM5 camera body without any reservations as to its size.  The Lens-IS again makes it an excellent stabilised platform on the GM5 camera body.
Tom Caldwell
Guy Parsons
Re: Stabilisation
As I said, sitting or sitting braced adds one or two stops to IBIS, it also adds one or two stops to non-IBIS situations.
In my years of testing it always works out that with no stabilisation the old rule works for me and bracing helps of course. The thing with no stabilisation is that the scatter of good and bad results is rather messy and sometimes even stupidly slow shutter works and sometimes way faster does not work. More randomness but a curve soon develops that sees the old rule surface.
Turn on IBIS and it all tightens up and the results are less scattered, the stability is good down until at the slower speed where the IBIS "lets go" and then it all falls apart reliably. It's much clearer to plot the good/bad curve.
In testing I do 10 separate shots at each shutter speed, not bursts, just 10 careful separate single shots. Even with the greatest care I occasionally find failed shots (shake, not shutter shock) at good higher shutter speeds, no matter if IBIS is on or not. It doesn't happen often in the tests but it does happen.
All that means is that with a scene that is important, just don't take one single shot like I usually do on holidays, take a few shots and one may be found to be better than the others.
