Fuji x100f skin tones
Started 11 months ago | Discussions
Shutter_slapps Junior Member • Posts: 26
Hey guys….
A few people have spoken about it… but I’m shocked at how bad the skin tones and film sims are on the Fuji x100f.
I was expecting a lot as everyone raves about the film sims. They are so overrated.
Any tips on how to get skin tones that don’t look like a mad woman’s custard?
Fujifilm FinePix X100 Fujifilm X10 Fujifilm X100F Leica X1
Erik Baumgartner Senior Member • Posts: 6,894
Re: Fuji x100f skin tones
Shutter_slapps wrote:
Hey guys….
Is this a SOOC Jpeg or processed RAW? What film sims are you using? This looks to be indoors under fluorescent lights? Maybe that has something to do with it?  Posting a full size image with the EXIF intact is preferable if you are having issues sorting image quality.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
DarnGoodPhotos Forum Pro • Posts: 11,882
Hey guys….
LOL
Set your NR (noise reduction) to a negative number. Experiment until you find a value you like, mine is usually on -2 or -3.
Film sims and noise reduction are unrelated.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
Makingtrax Senior Member • Posts: 1,082
Hey guys….
You need to alter your settings. Skin tones can look plasticy with jpg and certain film sims.
Steve
 Makingtrax's gear list:Makingtrax's gear list
Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R Fujifilm XF 16mm F1.4 R WR Fujifilm XF 100-400mm F4.5-5.6 OIS WR
allineedislight Senior Member • Posts: 1,311
For natural skin tones try to stick to the following film Sims: Pro Neg Hi, Pro Neg Low, Astia, or Provia. The first two may need a small boost in colour saturation.
Staying at low ISO also helps as well as accurate exposure and natural light. If you activate face detection the camera will expose for the face which helps to avoid underexposure. Also experiment with white balance, the AWB may be off sometimes so better to try a preset (you can do all this by reprocessing the raw file in camera).
When I used a X100F I never found skin tones to be a problem (what bugged me more was the 23mm lens 😂 )
 allineedislight's gear list:allineedislight's gear list
Sigma DP2s Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +1 more
Also, something to bear in mind is that Provia on the X100F generation cameras is a little on the cool/bluish side; I always went with Astia instead,
OP Shutter_slapps Junior Member • Posts: 26
Ok I’ll give that a try 👍 I do shoot Astia mostly as I find it works the best, besides STD.
Yeah I’m with you in regards to the focal length 🙈 35mm is not my favourite by a long shot… wish it was either 28 or 50…. Even 40 would be better 😅
Thanks for the advice, I’ll give it a go 👍
Hey guys….
This is SOOC Jpeg . I believe this is Pro neg high. I’ll find the file and see what the EXIF has on it. Thanks for the response
deednets Forum Pro • Posts: 13,887
An example?
Hey guys….
Fuji X100F default
Deed
 deednets's gear list:deednets's gear list
Leica Q2 Fujifilm X-Pro3 Sony a7 IV Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Re: An example?
Hey guys….
Fuji X100F default
Deed
Ahh So your also getting the same issue. I really had high hopes for this camera. Shame it lacks in the colour department.
rsn Contributing Member • Posts: 788
Fluorescent lighting .... bad
This image was shot under fluorescents as others have observed. The cure is quite simple, turn on your in camera flash, dial down the flash with flash compensation, start out with -2/3 and dial down more if the flash look dominates.  Fill flash is usually around -1 1/3 - 2/3rd's so that might work for you. The problem you are having has nothing to do with film sims.
 rsn's gear list:rsn's gear list
Fujifilm X100F Fujifilm X-T1 Canon EOS 5D Mark IV Canon EF 35mm F2.0 Canon EF 85mm F1.8 USM +11 more
Paul JN
Paul JN Contributing Member • Posts: 734
Re: An example?
Hey guys….
Fuji X100F default
Deed
I don't see it.
The first image by the OP looks like NR is too high. Try -4.
The second image looks fine to me???
 Paul JN's gear list:Paul JN's gear list
Ricoh GR IIIx Sony a7R III Sony a7R V Zeiss Loxia 35 Sony FE 85mm F1.8 +7 more
