Olympus TG-6 maintenance
Started 10 months ago | Discussions
Jslark0323 New Member • Posts: 1
Got my new tg-6 for a snorkeling trip coming up. I’m just curious about maintenance I know on the housing you have to lubricate the rubber o-rings but I do not have a housing, and this Made me think about the seals on the battery and hdmi doors should I lubricate these seals?
kelpdiver Veteran Member • Posts: 5,564
Re: Olympus TG-6 maintenance
what does the manual suggest?   If you're not touching the HDMI doors often, that's less a concern.  But my general routine with larger housings is I clean and lubricate the main o-ring and the port  or battery door (strobe) o-rings at the start of the trip, and then likely not again for the trip.
Lubricant is a sticky attractant and people who overdo it every time they open the housing seem to be the ones that are getting floods.
The fresh water post dive soak is the important one for your TG.  Salt crystals can form when it dries out, and these tend to be at the buttons where corrosion can occur.  The quick rinse post dive, the longer soak at night.   You want to push all of the buttons midway thru.
Think about the housing, maybe.   The tiny battery door is much more vulnerable, hard to care for, than the big housing o-ring.
Camrarat Regular Member • Posts: 349
Should the tg6 be used with the add on underwater housing for snorkeling? Or is it designed to be used naked for that?
The housing would protect the camera from direct salt exposure.   You get two sets of o-rings to protect the insides.  So long as one is good, it won't flood.   It would add bulk, though it might reduce how negatively buoyant it is in the water.
But strictly speaking, unless you're an excellent free diver, the TG-6 is rated for the depths the snorkelers inhabit.
