Re: Always going to be an issue
Promeneur wrote:
Nice commentary and write up. The dust issue is a big yawn for me, especially from those who don't own the cameras and don't intend to buy a GR. Just come here to complain and then move on, not to be heard from again. Having said that, I understand the frustration if this occurs to someone with a relatively new camera.
I've never put a pocketable camera with a retractable lens in a pocket without something around it to protect it from dust, etc.
Even if eventually you do get dust on the sensor why is a camera different than any other product we own that eventually needs servicing. I collect manual typewriters and used to remove the platens and feed rollers and send them off to have new rubber put on them until the last company that did this work closed down.
I'd also like to buy a small body like you mentioned for my M43 lenses and hope Panasonic comes out with something new this year. So far, can't get my hands on the Oly PEN E-P7, although it might be possible directly from Japan. Not motivated to try at the moment.
This dust on sensor issue is not new with the Ricoh GR - it has been a minor issue with the GDR/GR for years - usually dismissed as being due to sharing a pocket with the lint inside. Something that is often denied with some vehemence. I don't really know but what is expected of a pocketable camera other than placing it in a pocket from time to time?
I assiduously avoided pocketing my GRD bodies and this continued with my GR until I did pocket it once or twice - and surely I found a dust bunny.
Lots of noise about better seals - but a hermitically sealed collapsing lens could not function because of the compression of air when retracting and suction when expanding. For that reason I prefer even my lenses to be of the internal focus and zoom variety. Might be a little larger than their extending cousins but quite a lot less likely to be a dust pump.
Those that are into buying legacy MF lenses will well know the reservation by all vendors: "has some dust inside the barrel, but will not affect images". Dust inside lenses happens and the sensor is right behind the lens. This leaves all collapsing lenses just a trifle vulnerable.
Therefore I remain gratified by my Ricoh years and I still have all my Ricoh gear in working order. It is just a pity that a brand which has several mount systems in play has never sought to adopt a universal ML (mirrorless) mount system. The Pentax Q apparently only suits very small sensors and to all extent is dead in the water. The PK mount flange focal distance is too long.
Years ago there was a reference on the is forum to a collapsing PK mount that could handle both existing PK mount lenses and those with the same mount (collapsed) which would be genuine ML mount lenses. Nothing seems to have come of it.
So the obvious choice would be for Ricoh to join the M4/3 mount consortium and have immediate access to a huge range of lenses. They could add some of their own - this would give them access for such lenses to a considerable established base of M4/3 camera bodies.
However would the 'new' base of GR owners accept 'downgrading' the sensor from ape-c to 4/3? If so it would be a new breed of user as there were many happy users of the sliver-sized sensor GRD model - which had the advantage in the MkIV of image stabilisation way back when and was a much smaller package as well.
More the pity that the Pentax Q was preferred to a GRDIV with a Q mount. The GRDIV was a much more sophisticated camera than the Q ever was.
Ricoh also needs to get over its evf phobia - small evf units such as that in the Panasonic GM5 are actually very good. But maybe adding an evf might price the GR right out of the market? How about a swap? M4/3 mount system instead of a lens and an evf included?
Starts looking like a GM5 ... but whilst the GM5 is 'resting' (as the out of work actor might say) the month before such GR body with mount hit the market the GM5 update would already be in the shops. Such is the camera business.
Sounds like win-win for the consumer but might be the kiss of death for Ricoh.
Best stay where they are in a handy little niche of their own ...
