18-55mm + MCEX-11 Macro Adapter - Whoa!
Started 11 months ago | Discussions
GreatOceanSoftware
GreatOceanSoftware Senior Member • Posts: 1,222
I was bored and decided to try Fujifilm's macro adapter with my 18-55mm. I think I've tried it with every other lens I own, just out of curiosity, but for some reason this one never crossed my mind.
To my surprise, at 18mm you can almost touch the subject with the front lens element. This is not unlike the minimum focus distance of the Tamron 18-300. At 55mm, it's only a couple of inches away. I was manually focusing, and I couldn't figure out why it wouldn't focus until I moved in this close.
18mm
55mm
Randy
 GreatOceanSoftware's gear list:GreatOceanSoftware's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +11 more
fotoword
fotoword Contributing Member • Posts: 520
Re: 18-55mm + MCEX-11 Macro Adapter - Whoa!
I believe if you set the lens to around 35mm you can get a little bit of distance from the subject.
Cheers Paul
 fotoword's gear list:fotoword's gear list
Pentax Q7 Fujifilm X-T1 Panasonic Lumix DMC-GM5 Canon EOS M5 Olympus E-M1 II +36 more
GreatOceanSoftware
OP GreatOceanSoftware Senior Member • Posts: 1,222
Cheers Paul
Yes, I get better separation at the longer focal lengths.
Just out of curiosity, I took this shot to estimate the magnification at 18mm. It's only about 0.7x if my thinking is correct. Not scientific, but fun.
At 18mm. The front of the magnetic filter/cap ring is touching the ruler, which leaves the front element only a few mm from touching.
Randy
fotoword
Hi Randy
I have the mcex-16 which I think has a larger magnification.
The Fuji chart says 0.69 for the wide end with the ex11 for the 18-55 (if I read it correctly).
https://fujifilm-x.com/en-au/products/accessories/mcex-16/
The above link has the chart for both extension tubes (if you don't already have it) in PDF form of you scroll down the page a little.
Cheers Paul
GreatOceanSoftware wrote:
Cheers Paul
GreatOceanSoftware
Thanks, Paul! Good stuff. I wasn’t too far off! I’ll keep this PDF for reference.
I have an old Olympus 50mm 1.8 that I shoot with an adapter and the extension tube sometimes. It makes great macros with some unique characteristics. So many gizmos, so little time!
Randy
MrSee
MrSee Senior Member • Posts: 2,604
Thanks for sharing that info.
Jim from Ontario Canada
Fuji X-H1
Fuji 18-55 f2.8-4, Fuji 50-140 f2.8
 MrSee's gear list:MrSee's gear list
Fujifilm X-H1
Robmas4229
Robmas4229 Senior Member • Posts: 1,272
And so much dust on my sensors, LOL.
 Robmas4229's gear list:Robmas4229's gear list
Fujifilm X-E3 Fujifilm X-T3 Fujifilm X-T30 II Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS +7 more
GreatOceanSoftware
I prefer to think of it as grain 😜
Randy
Robmas4229
So you're one of those glass half full guys, eh?
bclaff Forum Pro • Posts: 13,933
fotoword wrote:
Hi Randy
A version of that information with some additional computed values is available at PhotonsToPhotos, see Fujifilm MCEX-11 and MCEX-16 on XF and XC Lenses
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
