Damage to Canon EF 50 mm f/1.4 USM
Started Apr 30, 2022 | Questions
JJCuriosus New Member • Posts: 6
Is it possible to damage a lens like Canon EF 50 mm f/1.4 USM by applying pressure to the front element which extends while focusing?
When I was attaching the lens to the camera, I forgot to retract the above-mentioned front element and as a result pressed it quite hard with the palm of my hand.
Could the pressure have caused damage to the lens?
gipper51 Veteran Member • Posts: 5,904
Re: Damage to Canon EF 50 mm f/1.4 USM
Yes you can.  This lens is known to be fragile and very easy to damage the focus system with front impact.  If it's acting up this probably caused some damage, unfortunately.
 gipper51's gear list:gipper51's gear list
Canon EOS 5DS Panasonic Lumix DMC-GX85 Canon EOS R6 Mark II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +20 more
rmexpress22 Senior Member • Posts: 2,304
Sure, it can. But if it works fine, then you're probably okay.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
Scott Larson Veteran Member • Posts: 7,505
If it still focuses then it's OK. But don't do that. Just one tap against a hard surface can destroy the focusing mechanism and you won't even be able to manually focus it.
 Scott Larson's gear list:Scott Larson's gear list
Sony RX10 IV Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +17 more
bridge77 Contributing Member • Posts: 959
thanks for the warning.  i use the 1.8 and use a rubber lens hood to act like a rubber bumper on most of my lens.
Ray UK Contributing Member • Posts: 977
With the 1.8 you are probably safe because they are stronger but with lenses like the 1.4 where the front section moves in and out when focusing a rubber hood is not a good idea.
The reason is that a rubber hood fits into the filter threads so a knock could still cause damage whereas the correct canon hood fits onto the body of the lens and any knock on that does not affect any moving parts.
ok, then i am comparing apples and oranges.
the rubber i feel offers some shock absorption to lenses, until the lens becomes a frisbee or bumper car.
it would seem that any lens shock would affect moving parts regardless of the lens?
the 1.8 lens seems to have it's own stories of the thing failing after much use, the new EF STM lens  has a metal lens mount to the camera body, perhaps an improvement?
OP JJCuriosus New Member • Posts: 6
Thank you for the warning! I honestly thought lenses were more durable.
Would you say I can judge if there is any damage by checking whether the lens can autofocus or not? Or do I have to evaluate the sharpness of the pictures (which would be a bit problematic as my pictures aren't really all that sharp even under the best circumstances)?
Thank you. I will be keeping an eye on this lens to make sure it works correctly.
Thanks for the heads-up! I will definitely try to be more careful from now on.
Would you say I can judge if the focusing mechanism is damaged by checking whether the lens can autofocus or not (by which I mean, notify me it achieved focus through focus confirmation light and beeping)? Or do I have to evaluate the sharpness of the pictures?
If it's broken, it will not focus at all, no AF, no manual focus. You'll turn the focus ring and nothing will happen. It's not subtle at all.
I've broken two of them.
What happens when the 1.4 is damaged, is as follows:
As the front assembly rotates during focusing it relies on small lugs which run in sloping grooves of plastic tube affixed to the main body. This plastic tube is quite flimsy and any pressure on the front can cause this to be damaged by the lugs.
If the damage is only slight then focusing will still work but the lugs will cause an indentation in the grooves so the focus will tend to stick in this position, this can usually be felt when using manual focus
If the lens has sustained greater damage then the  plastic tube will be broken and the front section will not turn at all, so neither AF or MF will work.
Damage caused by pressure on the front of the lens will not affect the lens sharpness unless of course if the lens is unable to focus.
msowsun
msowsun Contributing Member • Posts: 740
This is the part that is easily damaged by pressure on the front filter threads.
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS D30 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 80D +27 more
Sittatunga Veteran Member • Posts: 5,413
The metal bayonet feels and looks nicer, but it's the other end of the lens that breaks.
The hood clips into a groove in the main body of the lens, outside the lens cell that moves for focussing.  It is plastic, not the same plastic as a crash helmet or a riot shield, but still one that absorbs a lot of impact energy.  The bayonet lens hood stops any impact directly onto the focussing mechanism, while a rubber hood screwed into the filter thread just reduces minor impacts on the focussing mechanism.
East Gothia New Member • Posts: 22
If the lens falls face down and is at the longer part of the focus range the groove can/will be forced open (in the area shown in red). Sloppy focus with lots of backlash is one of the possible outcomes in both manual and auto focus. Unpredictable and difficult to diagnose from a single picture.
I got a used one cheap with this fault and was able to press the "distorsions" back but it took some fancy mechanical measuring equipment to get the ring round and the groove width constant (with a DIY round feeler gauge).
CameraCarl Veteran Member • Posts: 9,204
One other advantage to an OEM-type hood is that it provides slightly more rain deflection than a rubber hood screwed into the lens threads. The rubber hood moves with the lens, exposing the lens barrel to rain. Since the OEM-style hood fits to the lens body it provides a bit of shelter to the lens barrel when it is extended in shooting position.  This does not make the lens any more weather resistant, but may keep a few drops off the lens barrel if one is caught out in the rain without a rain cover for the camera.
ZX11
ZX11 Veteran Member • Posts: 6,156
Thanks guys.  I always thought it was the cheap motor and its gears that would strip out.  Mine has the Canon hood always on and is stored on its side or mount.  Works fine so far.
"Very funny, Scotty! Now beam me down my clothes."
"He's dead, Jim! You grab his tri-corder. I'll get his wallet."
 ZX11's gear list:ZX11's gear list
Canon EF 85mm F1.8 USM Canon 70-200 F2.8L III Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F1.2L USM
Thank you for clearing it up. The lens seems to be working normally so I'll go ahead and assume there is no permanent damage.
Thank you for the in-depth explanation. I think I understand the inner workings of this lens much better now. There seems to be no serious damage but I'll be on the lookout for indentations making the focus stick.
thank you all for warning us concerning this lens.  it may  be better to just use canon's 40mm or the 50mm 1.8
both are cheaper and the 1.8 is plentiful used.
