RF 16/2.8 a no-brainer?
Started 11 months ago | Questions
Texchappy Contributing Member • Posts: 598
Just ordered an R6 kit with the 24-105/4. I’ll probably get the RF 100-400 immediately or soon after. Looking at the lineup and reviews., it seems like getting the 16/2.8 is pretty much a no-brainer.  Is it?
(coming from the Fuji X cameras for the last decade)
 Texchappy's gear list:Texchappy's gear list
Fujifilm X100F Fujifilm X-Pro1 Canon EOS Rebel T4i Canon EOS R6 Fujifilm XF 18mm F2 R +10 more
Canon EOS R6 Canon RF 16mm F2.8 STM
RDM5546
RDM5546 Senior Member • Posts: 3,654
Re: RF 16/2.8 a no-brainer?
It depends on what you take pictures of and what other lenses you might buy.   I have several RF lenses but no 16mm yet since I have the RF15-35.   I do have the RF 35 and RF50f1.8 which are similar compact lenses.
 RDM5546's gear list:RDM5546's gear list
Canon RF 100-500mm F4.5-7.1L IS USM Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV +47 more
Sinawang Regular Member • Posts: 133
Depends on what you mainly shoot.
For me the RF 16/2.8 STM is no brainer because it's my solution to be able to get compact motion timelapse setup. I can shoot motion timelapse with RP+16/2.8 on Zhiyun Crane M2 which has 720gr payload and it still can take my RP+16/2.8 combo comfortably.
I can manually correct the distortion & vignette to get wider than 16mm fov, or auto lens correction when I'm feeling lazy.
Don't expect too much on edge sharpness. Sunstar is good enough for me.
CameraCarl Veteran Member • Posts: 9,193
The RF 16mm is only the second non-L lens that I have bought in the last 20 years and I can't believe how much fun it is to use. Some may dismiss it for being an STM lens, or for being less than "L" level sharp, but I find it great for the kind of photography I do. I am even tempted to leave my EF 16-35mm lens at home most trips.
FotografMagnus
FotografMagnus Regular Member • Posts: 268
I recently picked up the RF 16 and it's a fun little lens for a lot less money than the other a lot more expensive zooms. It might not be optically perfect but i consider it good enough since you can correct most of those optical issues and the rest of them don't really bother me that much.
It's small light compact size is a big advantage compared to the other zooms.
/ Magnus
 FotografMagnus's gear list:FotografMagnus's gear list
Canon EOS-1D X Canon EOS R5 Canon EF 15mm f/2.8 Fisheye Canon EF 24mm f/1.4L II USM Canon EF 400mm f/2.8L IS USM +4 more
Maxmolly7
Maxmolly7 Senior Member • Posts: 1,481
Yes, it is a no- brainer because it is small, light and fun to use. IQ is really good, with the exception of the outer corners being slightly soft. Worth the money for sure.
I had it for a while, but I finally decided against FF due to bulk and weight.
May THE LIGHT be with you!
 Maxmolly7's gear list:Maxmolly7's gear list
Sony RX10 IV Sony RX100 VII Canon EOS M6 II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +16 more
Canon_Guy
Canon_Guy Senior Member • Posts: 1,486
As mentioned, RF 16/2.8 is small, lightweight and cheap. These are its biggest assets. It has fairly good yet not great optical quality, strong barrel distortion and CA. If you could live with these, the overall price/performance value is great with this lens.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
BearInDespair Junior Member • Posts: 36
5
If you post process in Lightroom with corrections applied lens is wider then 16mm when compered to camera jpg. I do not have different uva but it's closer to 15mm I think.
STM motor with such wide lens is no issue, apart for horrible noises it makes.
I'm causal UVA user and for me it's sharp enough, due to small size and weight I didn't mind to carry it all day in my backpack.
I took it for my last trip few days ago and took hundred fotos with it as complementary lens to 24-105L.
24-105L with 16mm makes great travel kit.
 BearInDespair's gear list:BearInDespair's gear list
Canon EOS RP Tamron SP 90mm F2.8 Di VC USD Macro Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Samyang AF 85mm F1.4 RF +1 more
PMUK
PMUK Senior Member • Posts: 2,999
+1
Phil
siLvErStoRm New Member • Posts: 21
Just out of curiosity, can you handheld this with an R6 and used it as a selfie ? or will the distortion makes it too wacky 🤔
 siLvErStoRm's gear list:siLvErStoRm's gear list
Canon EOS R6 Canon RF 28-70mm F2L USM Canon RF 70-200mm F2.8L IS USM Canon RF 50mm F1.8 STM
SteveinLouisville
SteveinLouisville Senior Member • Posts: 1,586
For $299 it is, indeed, a no brainer.
 SteveinLouisville's gear list:SteveinLouisville's gear list
Canon EOS RP Canon EOS R7 Canon EF 17-40mm f/4.0L USM Canon EF 40mm f/2.8 STM Canon EF-S 24mm F2.8 STM +9 more
Sittatunga Veteran Member • Posts: 5,406
The distortion will come from having the camera within arm's reach of your head. It will be only slightly worse than doing a selfie with a phone, except that you can possibly include a bigger group of your friends or of people or places you want to impress your friends with. There is no other distortion if you output jpg from your camera or a RAW converter with a decent lens profile for it.
jwilliams Veteran Member • Posts: 6,385
Look here ...
Look here for a good review
Review: Canon RF 16mm f/2.8 STM - Admiring Light
I just got one. Fun and easy to carry lens. Price is easy on the wallet too. Not much else in the UWA department available in RF mount that's affordable. I also use an adapted EF 16-35 4L IS that produces great results, but it's a lot bigger and heavier lens. Very good IQ and probably the best combo of IQ, flexibility and price out there but the little 16 is easy to carry along and if you're not obsessing over the corner sharpness it can take some nice pics.
Jonathan
Thanks, i just might give this lens a try, and maybe a solid gorilla pod might do the trick.
RDM5546
I feel the same way about the RF 35f1.8 and RF 50f1.8.    Neither lens is without faults but they perform well in many cases and are small and light to bright along on trips.
rmexpress22 Senior Member • Posts: 2,304
For how inexpensive it is and how little I use UWA, I would have considered it over the Sigma 14-24mm Art I have if it existed when I bought the Sigma. I know the Sigma is better, but it's large and sometimes I just don't take it with me for that reason.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
Canon_Guy
RF 16/2.8 and Sigma 14-24/2.8 are very hard to compare. Both are from a very different worlds in basicaly all possible meanings:
- 14 mm vs 16 mm widest angle
- zoom vs fixed
- weather sealed vs unsealed
- metal body vs plastic
- Sigma made to be excellent, Canon made to be cheap
- Sigma much better at 16mm f/2.8 than Canon although Sigma is a zoom: much sharper off the centre and in the corners, much less vigneting, aberrations free vs a lot of aberration on Canon
Sigma is even much sharper, less vignetting and less aberrating at f/2.8 than Canon at f/8!
https://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=1573&Camera=1508&Sample=0&FLI=0&API=0&LensComp=1182&CameraComp=979&SampleComp=0&FLIComp=1&APIComp=0
But of course, the absolute superiority of IQ, build and features have their trade off in the size, weight and price of Sigma. Although its price/performance ratio is much better than with RF 15-35/2.8.
R5D4
R5D4 Contributing Member • Posts: 968
Yes it is. For $300 too!
I bought the 14-35 f4 and returned it because it was pretty soft at the 35mm end. I ended up buying the 16mm and I'm perfectly happy. This is not a common focal length for me to use, but when I need it, it is always there in the camera bag.
 R5D4's gear list:R5D4's gear list
Canon EOS R5 Fujifilm X-T3 Canon EOS R6 Canon EF 35mm F1.4L II USM Fujifilm XF 35mm F2 R WR +9 more
lonewolf1983 Contributing Member • Posts: 654
pretty much everyone with an R camera should have this lens.
Its always in my bag (usually with my samyang 85mm 1.4 for my "day to day" kit)
Love it for video on a gimbal too
 lonewolf1983's gear list:lonewolf1983's gear list
Sony RX100 III Canon EOS-1D X Canon EOS-1D X Mark II Fujifilm X-T3 Canon EOS R6 +11 more
R2D2 Forum Pro • Posts: 26,530
How is it as a video lens?  (tripod and/or handheld cage).  Pros/cons?
Thx,
R2
